Aearon Samba Member
Joined: December 29, 2014 Posts: 69 Location: Huntsville AL
Posted: Tue Jan 22, 2019 3:35 pm Post subject: Transaxle center mount Difficulties |
Hello All
I got one of the nice Mendeola center mount supports for my tranny. Problem I am having is It bolts on to the studs that hold on to the nose cone and once I get it on I cant get several of the nuts to start. Not enough thread left to lock them down. The studs look like all thread. Am I asking for trouble trying to back those studs out a turn or 2 so I can get the nuts started? Otherwise anyone have any good ideas.
Thanks |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Jan 22, 2019 4:05 pm Post subject: Re: Transaxle center mount Difficulties |
Use the correct studs _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Jan 22, 2019 4:11 pm Post subject: Re: Transaxle center mount Difficulties |
Most good hardware stores should have a selection of different length studs.
Get a set with longer threads on one side and replace one at a time. Just double nut the original and turn it out. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Tue Jan 22, 2019 4:12 pm Post subject: Re: Transaxle center mount Difficulties |
You spent good money, don't cheap out now.
mcmscott wrote: |
Use the correct studs |
What he said. _________________ Glenn
Member #1009
#BlueSquare |
Aearon Samba Member
Posted: Tue Jan 22, 2019 4:14 pm Post subject: Re: Transaxle center mount Difficulties |
Happy to. So the recommendation is to pull the studs that came on it and get some that are a hair longer. Seems like a fair thing to do
Thanks |
Posted: Tue Jan 22, 2019 5:37 pm Post subject: Re: Transaxle center mount Difficulties |
This guy sells mid mounts with the correct hardware _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Tue Jan 22, 2019 6:01 pm Post subject: Re: Transaxle center mount Difficulties |
On a personal project last Summer I got some full thread longer 8 x 1.25 bolts from Belmetric, and simply cut the heads off them to use as studs. Double nut the factory studs, and tap on the ends a little like you were driving a nail, and they should unscrew fairly easily. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Jan 22, 2019 6:32 pm Post subject: Re: Transaxle center mount Difficulties |
[email protected] wrote: |
I bought full thread 8mm x 1.25mm bolts at local Ace Hardware last year, used on the alternator adjust on my 1998 Frontier. I think in the drawers there (and don't get me started on drawers !!!). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Tue Jan 22, 2019 6:50 pm Post subject: Re: Transaxle center mount Difficulties |
mcmscott wrote: |
This guy sells mid mounts with the correct hardware |
That's a pretty nice mid-mount.
Do you have any idea what the guy that makes those want's for one? LOL!
I might need to order one from your guy. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jan 22, 2019 8:01 pm Post subject: Re: Transaxle center mount Difficulties |
Cusser wrote: |
I bought full thread 8mm x 1.25mm bolts at local Ace Hardware last year, used on the alternator adjust on my 1998 Frontier. I think in the drawers there (and don't get me started on drawers !!!). |
Yeah, everyone around me had the longer bolts with only the 20mm, or so worth of thread, and the rest shank. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Tue Jan 22, 2019 8:17 pm Post subject: Re: Transaxle center mount Difficulties |
Since hardware stores mainly sell decorations now, so you may have to buy and stock your own hardware.
Try Bell Metric for a good selection. |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Tue Jan 22, 2019 8:37 pm Post subject: Re: Transaxle center mount Difficulties |
I would try to use original VW studs if you can...
Its hard to match the quality of the material.
If you can post the new length that you need, maybe old engine case studs or other hardware can be determined. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
modok Samba Member
Posted: Tue Jan 22, 2019 9:33 pm Post subject: Re: Transaxle center mount Difficulties |
Type 5 Joe wrote: |
Ok, I suppose only furniture and fences use grade 5.8 anymore, but
What is the problem with using stronger hardware? |
Posted: Wed Jan 23, 2019 6:22 am Post subject: Re: Transaxle center mount Difficulties |
modok wrote: |
Type 5 Joe wrote: |
Since VW never really intended those studs to be used as a mount, I actually would go with stronger hardware. I wound the thread through the case enough to put a nut on it, so there are nuts on each side of the case, and gear carrier.
Everything VW is purpose length for its application, so if you want more than 20mm worth of thread on a stud that’s longer than 50mm, I don’t think you’re going to find it. |
slalombuggy Samba Member
Posted: Wed Jan 23, 2019 9:08 am Post subject: Re: Transaxle center mount Difficulties |
I used exhaust studs off of a ford 5.4 got a stock of them in my tool box
brad |
Olli from NJ Samba Member
