72vwtype2 Samba Member
Posted: Wed Jan 23, 2019 9:18 am Post subject: 1972 Double Cab? |
What are the differences between the 1972 Double Cab and the earlier low lights (1968-1971)? Visually (other than the larger tail lights) they appear the same. Are there any significant differences?
Thanks. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Jan 23, 2019 9:41 am Post subject: Re: 1972 Double Cab? |
There are other differences that are also manifested in all 1972 Type 2s.
Notably the engine changed from the Type I upright 1600 to the Type IV pancake engine, 1700 cc. This means that with the redesigned engine bay, you could install any Type IV engine, including the later '70s 2000-cc fuel injected engines, which are great. This was done for my 1978 double cab, and it is a dream. This refit would also require switching out some other parts for their FI versions, including the fuel tank and fuel pump. You will also need to mount the ECU somewhere in the engine bay, but that's easy. On this point alone (Type IV engine bay) the 1972 is superior to the 1971.
There are a lot of other 1972-only parts, like bumpers 'n' stuff, that make owning a '72 a bit of a pain, but others find the uniqueness charming. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Jan 23, 2019 9:49 am Post subject: Re: 1972 Double Cab? |
I think the removable apron on the rear for engine removal is gone? |
Posted: Wed Jan 23, 2019 9:50 am Post subject: Re: 1972 Double Cab? |
jtauxe Samba Member
Posted: Wed Jan 23, 2019 9:55 am Post subject: Re: 1972 Double Cab? |
alman72 wrote: |
Sadly, yes. That was a great feature. _________________ John
http://vw.tauxe.net
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Jan 24, 2019 12:44 am Post subject: Re: 1972 Double Cab? |
Yes, the engine bay made to accomodate the type 4, even though probably most commercials sold in 1972 had the 1971 spec type 1 engine. (those sold in a few markets might even have had smaller engines. parts book shows them as 44kw!)
So, that means if you find one of these babies with no engine and want to put in a type 1 engine, you have to find that tin and rear engine hanger for the later 72-79 bus. Pretty sure the air cleaner and hose might e different too, from a 1971 version. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Jan 24, 2019 9:04 am Post subject: Re: 1972 Double Cab? |
72vwtype2 wrote: |
Thanks. |
You didn't put a location in your profile. They answer can vary depending on where you are and where your truck was originally sold.
All Type 2s built for the US market had the Type 4 engine starting in 1972. But the US market didn't get a lot of trucks generally in the '70s relative to the number of Buses we got.
A truck made for other markets may have still had the Type 1 engine as standard with the Type 4 being an extra cost option. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Jan 24, 2019 4:09 pm Post subject: Re: 1972 Double Cab? |
I am in Canada, so I am referring to the VW trucks imported to North America.
VW trucks up to and including 1971 model were freely imported to North America. So there is a healthy stock of 1968-1971 bay window trucks. In 1972 the "chicken tax" stopped the flow of 1972-1979 trucks. So finding one in this range is difficult (in North America) as there are not many.
Looking at pictures and comparing the 72 model to earlier bays, the most notable differences are: Tail lights, rims (flat hub cap), rear deck lid and lip around front wheel well. Other than that everything else looks the same (vents, gas flap location, etc...).
Maybe there are differences in the interior? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jan 24, 2019 5:20 pm Post subject: Re: 1972 Double Cab? |
The hubcaps and wheels are the same as a 71.
The noticeable differences will be perforated Y members in the front frame corner crash outriggers, the usual 72 cab and cab door differences just like a bus, carb air intake louvers in the RR cab corner outside behind the door, a widened frame aft of the torsion tube and a cross member under the fuel tank to support the transmission, different engine surround metal and apron (as already mentioned), different rear corners and tail lights, different tailgate with windows for the tail lights and different bumper brackets. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
