Maine Samba Member
Joined: September 21, 2010 Posts: 150 Location: Maine
Posted: Sat Jan 26, 2019 1:59 pm Post subject: Another Van Rust Question |
There is some seam rust on my 85 Westy (see pics) my questions are:
Would you tackle it now or wait?
How would you go about it?
Some of the rust appears to be along side the seam.
I have a POR kit form Gowesty and some 3M seam sealer.
Thanks
Maine
jimf909 Samba Member
Posted: Sat Jan 26, 2019 2:17 pm Post subject: Re: Another Van Rust Question |
What’s on your van to-do list and what’s your tolerance for seam rust?
For the last five years, seam rust repair has always been on the bottom and of my to-do list (after safety maintenance items (always first), engine conversion, high-top, trans rebuild/Peloquin, suspension rebuild, camping/storage solutions, etc.j
But seam rust moves slowly in Seattle and I consider it to be an appearance item at the stage it’s at on my van (it’s worse than yours) so I go camping instead of worrying about it.
If having a pretty van (an absolutely reasonable objective and one I aspire to someday) is important and all the safety items are in good shape then tackle it now this year.
Also consider if you want to do a full-on restoration (windows out, cabinets, etc. out and all rust obliterated), or just a temporary touch-up from the outside (the rust WILL return). _________________ - Jim
Abscate wrote: |
HackAl Samba Member
Joined: March 12, 2016 Posts: 338 Location: Bergen County, NJ
Posted: Sat Jan 26, 2019 2:52 pm Post subject: Re: Another Van Rust Question |
I have a similar problem, both in severity and location, and I appreciate Jim's answer about where this fits in the long list of things that need doing.
I would have to pull my hatch and passenger side rear windows to get additional rust under the rubber gaskets. It means tools, chemicals and know-how I lack. So I can buy & learn or trust some else to do it. Problem is, few professionals around here have any experience with doing what needs to done for a price that makes sense.
I keep hoping I'll find someone local who I can pay while lending a helping hand and learning in the process. In the meantime, I watch the tiny rust bubbles slowly get bigger and bigger. _________________ 91 Westy.
Ever consider temporarily trading your van? Join the list. |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Sat Jan 26, 2019 3:22 pm Post subject: Re: Another Van Rust Question |
The thing about rust is the sooner you tackle the problem the better.
And as for the Por15, I would not use it for this application (in fact I no longer even like the stuff)
Best bet is to clean out the seams (check some of the threads on the subject), use a converter like Ospho, and paint.
Also, remember that the Samba has a great resource right here in the body/paint forum if you need some reading.
Rust never sleeps, it will get worse. Like others have said, safety items are priority, but even a quick repair job is better than nothing when it comes to rust.
Of course it takes a bit of time to do a real quality show room repair, but again, stopping the rust from spreading will help your van last even if the repair spots are noticeable. You can always go back and redo the finish work when you have more time/experience or have a complete respray.
Just don't leave only primer as a finish coat, it's not weather proof, get some enamel over the top.
So, basically, it's tape off the area needing work, sand/scrape, feather the edges, use a rust converter, primer, paint, let the paint cure, seam sealer as needed, and paint again after the sealer cures.
You can buy color matched paint in aerosol cans based on your vans paint code for about $20 a can (but be aware that some of these paints are not high quality and a decent clear coat over the top will help the paint protect the van). _________________ Currently:
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Sat Jan 26, 2019 3:54 pm Post subject: Re: Another Van Rust Question |
maine is brutal , especially where i live (coastal island) lots of rust...you gotta get on it ! i also have to do this and have been putting it off until the cold breaks. i would definitely sand blast what you can, to truly eliminate the oxidization, however you also have to degrease and wash it down with denatured alcohol and then seal ASAP to even stand a chance to stave it off. seam rust has its own challenges but there are plenty of abrasives for this very purpose, whatever you use be thorough. i am fortunate that i am a metal worker by trade so i have lots of stuff i can use, and honestly im going to just rip out and replace a few panels above the wheels and along the rockers , all those repairs are actually fairly easy these days since the quality of body panels has gotten a bit more consistent. in short its best to just replace the panels and paint from there, that way you know that nothing is hiding beneath the surface or in the cracks to continue. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Maine Samba Member
Posted: Sun Jan 27, 2019 8:01 am Post subject: Re: Another Van Rust Question |
Jim good points about safety, as you said those should be the first things on the to do list and I checked those off the first year when I bought the van 4 years ago. I don't think I'm up for a full restoration financially or age wise (not the van but me I am approaching 70). My tolerance for seam rust is pretty high the pictures posted are the only spots of rust that I can see and they haven't changed much in the last 2-3 years.
As others suggested I think when the weather warms up I'll give it a go. In the meantime I'll read some threads on how to do the repair. I'm not particularly good at these types of thing but as HackAl said I would gladly pay some one to do the work good local help is hard to find. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Maine Samba Member
Posted: Sun Jan 27, 2019 10:00 am Post subject: Re: Another Van Rust Question |
We do keep the van in the garage (while my truck sits outside in the snow) and we never drive the van in the winter. |
Posted: Sun Jan 27, 2019 10:13 am Post subject: Re: Another Van Rust Question |
where ya at? if you need help with anything and im around just let me know. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
zuhandenheit Samba Member
This, here:
MsTaboo wrote: |
The efficacy of POR15 is hit or miss, IME, depending on known and unknown variables. It generally adheres well to heavy not-flaking surface rust. It SOMETIMES adheres well to clean metal. But sometimes, for no obvious reason, it can be peeled or scratched off very easily.
I don't think it is at all a good choice for seams.
Instead, if possible, use epoxy primer. You can even get it in a spray can (e.g., 'spraymax') with two bladders that mix when you remove a plug. If you treat with phosphoric acid (e.g., ospho or POR15 metal ready), make sure the epoxy primer is compatible. Some should not be applied over acid treated metal.
The whole process (after removing paint and rust, and possibly phosphoric acid treatment) would be epoxy primer, seam sealer, filler / high build primer if needed, primer, paint.
Terry Kay (before his ban) used to recommend 3M 8115 panel adhesive as a seam sealer. A number of us have tried it. Before doing so, I called 3M and told a technician people were using it as seam sealer, and asked if he had any particular concerns. After emphasizing that it wasn't designed for that purpose, the tech didn't have any specific concerns about failure.
It's actually flexible, sandable, and adheres so well it can be pretty much treated like body filler. As an epoxy glue with extremely high bond strength, the theory goes, it should adhere to metal with the tenacity of epoxy primer.
Anyway, this is experimental, but I think it's another option you might consider. My seams look good still after four years. I haven't heard about failures from anyone else who tried it. |
Maine Samba Member
Posted: Mon Jan 28, 2019 5:48 am Post subject: Re: Another Van Rust Question |
outcaststudios wrote: |
where ya at? if you need help with anything and im around just let me know. |
I'm in Belfast |
Posted: Mon Jan 28, 2019 8:08 am Post subject: Re: Another Van Rust Question |
ha im out in deer isle hey neighbor! offer stands _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
?Waldo? Samba Member
Posted: Mon Jan 28, 2019 8:29 am Post subject: Re: Another Van Rust Question |
Maine wrote: |
Rust is only active when there is water (liquid) present. Because of this, cars that are driven in salty snow and parked in a garage often rust faster than the same vehicle parked outside where the water stays frozen. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Mon Jan 28, 2019 8:44 am Post subject: Re: Another Van Rust Question |
There should be a single thread related to long term results when dealing with seam rust. Maybe a sticky? Personally, I cut it out and replace it with good metal, though I understand that is a lot of work and possibly more than some are willing to spend.
The best ideas I've heard on here are scrub it out if it's lightly bubbling, wicking Ospho or some other brand of Phosphoric acid into the seams, then epoxy, though I've yet to see how long term this solution would last. It would be nice to document these type of repairs and have annual updates. It would go a long way in helping folks become more informed prior to spending $$$ on a paint job.
If I had a dollar for every Bus I've seen with recent paint and rust bubbles at the seams... _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Mon Jan 28, 2019 8:52 am Post subject: Re: Another Van Rust Question |
?Waldo? wrote: |
Maine wrote: |
In the Mid Atlantic parking in a garage makes a huge difference. If left outside the vehicle gets wet from dew every night.
Not sure about the salt freeze issue in the winter. Never had that happen enough to study it. _________________ Dave O
The Western Syncro build
Posted: Mon Jan 28, 2019 9:34 am Post subject: Re: Another Van Rust Question |
?Waldo? wrote: |
Maine wrote: |
true, its the oxygen in the water , but also sodium and other acidic compounds catalyze the oxidization super fast. where this gentlemen lives is directly along the atlantic coast, seabreeze and salinated air year round. its a killer because the sodium and the water work in concert 24 hrs. i moved my bay window from philly to maine and within one year its rust began to double in its return. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
DuncanS Samba Member
Posted: Tue Jan 29, 2019 5:24 am Post subject: Re: Another Van Rust Question |
Same issue for me in NH and previously VT. At our age and climate, i think it's like a slightly raised PSA prostate number. Watchful waiting. I'm a daily driver and when salt is on the roads, I go to the wand washer and pummel the hell out of the underside and especially around the wheel wells and front step foot wells. This seems to keep it at bay, but.............. A time comes when it needs to be addressed. The problem is that these seams are made of two 90º bends and welded together. The water gets into the space between the bends and sits there and the rust migrates to the outside painted surface and then we see the blistering of the paint and sealer. By that time, there is a problem back inside that sandblasting and so on from the outside won't really fully address. I say this is like having prostrate surgery where most of the bad areas are removed, but there is still plenty of tissue/metal issues that can resurface--pun intended here. I've always thought the solution would be to remove the backward bends of metal and weld a strip across the gap. Then treat the bejazus out of the back side in terms of protection and then there is no more seam. Plus you get a cleaner looking vehicle with no panel interruptions. I did that on a 181 I had and it worked really well.
It looks like the shallow groove just forward of your DS wheel well has some body putty with rust underneath pushing it out. I would definitely attack that area and clean it up. The horizontal seams bother me more than the vertical ones as it can happen quicker with those. Do you have a Westy with built-ins on the left side? They are prone to problems behind the cabinet work and would check that out thoroughly as once the lower panel starts going, it can become something pretty nasty. |
Maine Samba Member
Posted: Wed Jan 30, 2019 7:21 am Post subject: Re: Another Van Rust Question |
The three rust spots that I posted are the only ones that are visible and are all on the drivers side which is the same side as the cabinets. There has not been much progression in the last 2-3 years.The van is garaged year round and never driven in the winter which others have mentioned helps slow things down. However, I think its time to address the rust that I can see. My biggest concern is once I start the process who knows where it will lead. I have the same problem as hackAl (only more so I am sure) I lack the tools and knowledge. Once the weather warms up i'll give it a try, in the meantime I'll educate myself as much as possible. Other than the rust the van is in really good shape.
Posted: Wed Jan 30, 2019 8:00 am Post subject: Re: Another Van Rust Question |
Do you have any rust at the edges of the glass where the rubber meets with the tin? You will need to get some stuff from Harbor Freight. I would start with a fine grit disc in an electric drill and just try working around the areas where there seems to be some body putty in front of your rear wheel and see what’s underneath there then you can decide what different tools and so on you may need. |
