tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Sun Jan 27, 2019 8:11 am Post subject: Throttle Grommet Size Hard to find? |
I am wanting to shore up my throttle tube where it goes through the fan shroud. I found them in the UK here
http://www.machine7.com/product.php?xProd=2805
But I am finding nothing at ACE Hardware, or Lowes etc. It seams that a Grommet with 8mm inside and 12mm outside should be simple to find, but not for me. Any ideas? I have checked all common VW vendors.
Thanks _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Sun Jan 27, 2019 8:24 am Post subject: Re: Throttle Grommet Size Hard to find? |
I bought a bunch of them through the VW dealer about 15 years ago. Might be worth a check. _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
Dale M. Samba Member
Posted: Sun Jan 27, 2019 8:45 am Post subject: Re: Throttle Grommet Size Hard to find? |
tpinthepack wrote: |
Thanks |
Try online electrical supply like Digikey...
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Sun Jan 27, 2019 8:47 am Post subject: Re: Throttle Grommet Size Hard to find? |
I got mine at ACE.
5/16ths by 9/16ths should work and be easy to find.
I just take a micrometer along and find the closest one. I first check the hole size in the shroud with the mic.
You can always drill the hole slightly larger to fit the one you find since the inner diameter is easy at 5/16ths.
5/16ths brake line with a flare on one end works good as a cable guide through the shroud. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sun Jan 27, 2019 8:58 am Post subject: Re: Throttle Grommet Size Hard to find? |
clonebug wrote: |
I got mine at ACE.
5/16ths brake line with a flare on one end works good as a cable guide through the shroud. |
Yeah... Forgot about the little drawers with misc "stuff" at ACE or TRUE VALUE...
rodjr Samba Member
Joined: October 12, 2015 Posts: 223 Location: stanwood washington
Posted: Sun Jan 27, 2019 10:03 am Post subject: Re: Throttle Grommet Size Hard to find? |
Pick up one of these or similar. I built my entire buggy with this kit, and on all but one occasion, (because the glass was too thick) I had what i needed. I did have to open a hole or two slightly along the way, for a perfect fit.
One of the best things i ever put in my garage.
https://www.amazon.com/Swordfish-21010-Rubber-Grom...&psc=1 |
Posted: Sun Jan 27, 2019 10:31 am Post subject: Re: Throttle Grommet Size Hard to find? |
I will head back to ace again today. When I was there last week, they had a horrible supply of rubber grommets. But I agree, this should be a no brainer Grommet to locate.
1990 Vanagon DOKA
1972 Super Beetle
74 Thing Samba Member
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Sun Jan 27, 2019 2:15 pm Post subject: Re: Throttle Grommet Size Hard to find? |
74 Thing
I purchased those already, my engine is super tight on the front Tin, and where the tube exits the fan side of the shroud. My issue is the Front side by the Carb, that rubber grommet is the one I need, like the link I shared. I went to Advanced Auto Parts today and got an assortment, and it looks like I found one, but the rain is so bad now in Florida I can't go test it.
Thank You. _________________ TP in the Pack (I am a cyclist)
1990 Vanagon DOKA
1972 Super Beetle
Posted: Sun Jan 27, 2019 7:39 pm Post subject: Re: Throttle Grommet Size Hard to find? |
I would use some silicone spray on it so the guide tube slides it |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Sun Jan 27, 2019 8:27 pm Post subject: Re: Throttle Grommet Size Hard to find? |
Find one with the right i.d. and drill the hole for the correct size, not sure what the issue is lol. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Dec 31, 2019 2:58 pm Post subject: Re: Throttle Grommet Size Hard to find? |
I have never used or saw one of those - why is it absolutely necessary, to use it? _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
