grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Wed Jan 30, 2019 8:32 am Post subject: Cable Lube? |
Is it a good idea to use cable lube in all of the cable tubes or will it gunk up over time? |
bluebus86 Banned
Posted: Wed Jan 30, 2019 8:44 am Post subject: Re: Cable Lube? |
grandpa red wrote: |
Operating them with no lube is a sure way to wear them fast. I lube them upon instal with grease, never had them "gunk up". The Official VW Service Manual states the brake cable is to be lubed upon install.
My old 58 Bug had grease fittings on the brake cables, later they made them without the grease fittings, lubed for life I suppose, but that was probably a marketing thing.
At the least, grease them prior to install.
same for clutch, and accelerator cables, and manual choke cables on the really old Bugs.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Brian Samba Moderator
Posted: Wed Jan 30, 2019 9:40 am Post subject: Re: Cable Lube? |
You must at minimum grease the cables.
When I install cables I wear a nitrile glove and hold a dollop of grease in my palm, then I'll feed the cable through the grease and into the tube. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Wed Jan 30, 2019 10:28 am Post subject: Re: Cable Lube? |
Ok thanks.
I have the motor out right now so it will be easy to do all of them.
I think I'll blow the tubes out with air first if I can. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Wed Jan 30, 2019 12:54 pm Post subject: Re: Cable Lube? |
Brian wrote: |
When I install cables I wear a nitrile glove and hold a dollop of grease in my palm, then I'll feed the cable through the grease and into the tube. |
This. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Jan 31, 2019 1:13 am Post subject: Re: Cable Lube? |
If you go to all that trouble, try sourcing the boots for every single cable as VW intended it. Why go through that work just to have the grease attract dust and grit?
One on the clutch cable bowden tube, one long tube for the accelerator cable to the fan shroud pass-through, and one for each heater cable tube. One or two on the speedometer cable? It's been a while since I've done a proper T1 speedo cable…
www.airschooled.com |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Fri Feb 01, 2019 4:25 pm Post subject: Re: Cable Lube? |
I just do a thin grease film. If it's a dusty condition, I found the grease is a dirt attractant, so silicone spray was the way to go there.
I would agree to get all the boots - ends of the heater cable tubes, end of the bowden tube. The accelerator cable and clutch cable should exit the chassis into flexible tubes. Often I've seen the accelerator flex tube is missing.
Be sure to grease the front hook end of the clutch cable too, and the cables/wires at the hand brake could use a dab of grease.
Not that they need grease, but there are also rubber stopper/valves that go in the bottom of the rockers as well as the bottom of the tunnel, just in front of the rear torsion housing. These boots are also usually missing! _________________ 1972 Standard Beetle
1969 Baja Beetle |
Posted: Sat Feb 02, 2019 7:34 am Post subject: Re: Cable Lube? |
Yep new boots ordered. |
