110V 15 Amp Electrical Hook-Up Inlet Location
Page: Previous  1, 2
Where should the 110 electrical hook-up box be located if it could be anywhere?
Original location
54%
 54%  [ 6 ]
Under the van
0%
 0%  [ 0 ]
Near the rear of the van, close to engine bay
18%
 18%  [ 2 ]
Somewhere else (please let us know where)
27%
 27%  [ 3 ]
Total Votes : 11
oldskewlsk8ter
oldskewlsk8ter is offline
PostPosted: Wed Jan 30, 2019 4:45 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
VanagonVentures wrote:
oldskewlsk8ter wrote:
What I did...
I like this. Iím gonna look into doing the same.
Are you happy with it?
Wished you had done something different?
How do you like that specific inlet?
Whatís the other plug you have?
m
Itís works perfect for me in that location. The one beside it is for 12v. I wired the 120v NOCO receptacle into a regular household receptacle installed in the kick panel under the rear seat.
1986 Hightop w/EJ25 DOHC
danfromsyr
danfromsyr is offline
PostPosted: Wed Jan 30, 2019 4:51 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
honestly you can have multiple inplets for 110v power as you can have multiple outlets for 12/5v power.
if you feel the live prongs a safety issue. you can buy a replacement end that acts as a cap for the unused socket.
Abscate wrote:
These are the reasons we have words like ďwankerĒ
T3TRIS
T3TRIS is offline
PostPosted: Thu Jan 31, 2019 9:33 am    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
Thanks for the feedback. So far this is our favorite spot, however I was noticing last night that this particular body panel does point upward a little. If we're plugged in when it's raining and the wind blows from behind (lots of "ifs" sure), I'd be afraid of water pooling up in there. Maybe I can drill a little relief hole on the lowest part of the outlet.
Sodo
Sodo is offline
PostPosted: Thu Jan 31, 2019 10:21 am    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
There's always a lot of ifs, more than you can imagine. Wink
I'll bet you're correct that drilling a drain hole will solve that 'if'.
In my case I have to avoid the "when".......
....when that rear tire rolls onto the extension cord.
Dan you just gave me an idea. Rather than a "hook" I can attach a cutoff female cord end as a "holder" for my dangling cord. It will cover the prongs while the inverter is ON (and they're "live" with 120vAC).
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
Gear oil is like underwear.
oldskewlsk8ter
PostPosted: Thu Jan 31, 2019 4:12 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
Iíve left mine plugged in during rainy weather many times with no issues whatsoever. The rear door acts as a pretty good rain deflector.
rmcd
rmcd is offline
PostPosted: Thu Jan 31, 2019 6:34 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
The plug thing I bought is water tight. I have to work to pull the cover off. The hole is caulked with silicon.
VW LT40 build.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
Syncro panel van camper build. Taking Offers.
http://www.thesamba.com/vw/forum/viewtopic.php?t=575458&highlight=
uberaudi
uberaudi is offline
PostPosted: Thu Jan 31, 2019 9:50 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
What I did...
I use the same Noco receptacle for my block heater on the front of my Audi 4kq...it's always dry when I lift the cover. Pretty nice unit.
T3TRIS
T3TRIS is offline
PostPosted: Thu Jan 31, 2019 10:25 pm    Post subject: Re: 110V 15 Amp Electrical Hook-Up Inlet Location Reply with quote
The rear spot by the driver side tail light won! Thanks for the suggestions.
Page: Previous  1, 2
Page 2 of 2
