airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Thu Jan 31, 2019 12:12 pm Post subject: Type 4 alternator belt tension square nut |
Hi everyone,
I was assembling a Type 4 engine last week and came across a hex nut installed where the square nut should have been tucked in on the front of the alternator bracket. Since it's such a PITA to get that nut replaced, and we couldn't find a good used VW nut by our deadline, we made one.
If anybody else is struggling to find that special M8 square nut, one can be made out of a Unistrut nut and a few minutes of drilling/tapping.
The Unistrut nut came pre-tapped to 1/4x20, which was easy enough to drill out with a 17/64" drill bit. (An H bit would be better but we didn't have one.)
Follow with a well-oiled M8x1.25 tap…
And then you can carry on with the 96,832 other minute details that make the Type 4 engine such a pleasure.
We used PN P3006. For the over-achievers, pre-drilled M8 nuts can be found here: (clip the spring!)
https://www.amazon.com/Oglaend-Spring-Channels-Sta...annel+nuts
See you on the road,
www.airschooled.com |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Jan 31, 2019 12:35 pm Post subject: Re: Type 4 alternator belt tension square nut |
How did you make the raised section that rides in the groove of the alternator bracket?
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
buckswilde Samba Member
Joined: June 26, 2010 Posts: 131 Location: Lexington, KY
Posted: Thu Jan 31, 2019 12:39 pm Post subject: Re: Type 4 alternator belt tension square nut |
Nice solution. I was dealing with a mangled square nut on my 79 last fall. Big PIA. If anyone is looking for a direct replacement without making one, Fastenal carries them. https://www.fastenal.com/. I took my old one in and they were able to find a match and order it for me next day. I'll try and find my receipt for the part number. |
Posted: Thu Jan 31, 2019 1:01 pm Post subject: Re: Type 4 alternator belt tension square nut |
hazetguy wrote: |
How did you make the raised section that rides in the groove of the alternator bracket? |
We did not. The makeshift nut is much larger and doesn't rotate at all.
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Jan 31, 2019 2:11 pm Post subject: Re: Type 4 alternator belt tension square nut |
Great fix!
Anyone have caliper handy? What is the width of the slot in the bracket?
I ask....because you can buy these nuts at McMaster Carr.....
8mm x 1.25 thread....to fit a 10mm wide slot.
11mm total height with a 6mm thick flange
16mm wide
22mm total length...which you can trim shorter with a grinder
Part #: 90510A213.....black oxide....fully threaded ....$4.82 each
Catalog page 2661
Ray |
SGKent Samba Member
Posted: Thu Jan 31, 2019 2:17 pm Post subject: Re: Type 4 alternator belt tension square nut |
raygreenwood wrote: |
Great fix!
16mm wide
Catalog page 2661
Ray |
or you can buy the VW part from Hazetguy. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 31, 2019 2:18 pm Post subject: Re: Type 4 alternator belt tension square nut |
Thanks Ray. I'll mic the slot this weekend. The length won't be an issue, there's about 10mm of dead space on the fan shroud side of the slot before you hit the M8 securing stud/nut. Our Unistrut piece was about 25mm long.
Ours is a NOS bracket too; the slot on the old one was so worn out I worried about it lasting another 40 years.
We had trouble sourcing a nut that had the correct flange that wasn't too deep. If the nut flange is taller than the bracket is thick, the assembly will never torque down. So if the flange is 6mm but the bracket is 5mm, I'm nut sure the replacement will work. Am I understanding the dimensions of the nut correctly?
Here is the page it's from, hopefully their links work:
https://www.mcmaster.com/catalog/125/2661
Posted: Thu Jan 31, 2019 2:32 pm Post subject: Re: Type 4 alternator belt tension square nut |
SGKent wrote: |
or you can buy the VW part from Hazetguy. |
uh, no. the newest of my two pics (yes, my pics) is 8 years old. the other is 11. those are long gone/sold/used.
if the nut flange is taller than the bracket is thick, sand/file the flange.
bracket metal is ~3.1mm thick
slot width is ~9.5mm "wide" (varies slightly through the travel of the opening)
width of "flange" on nut is ~8mm
height of flange is ~2mm
nut is ~14mm square.
nut height (total) is ~8.7mm
measurements are "~" taking wear, paint thickness, light dirt into account. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Thu Jan 31, 2019 2:36 pm Post subject: Re: Type 4 alternator belt tension square nut |
hazetguy wrote: |
SGKent wrote: |
I was going to say, I checked his ads this morning and would have felt real silly if I missed them…
Thanks for the measurements!
Posted: Fri Feb 01, 2019 8:20 am Post subject: Re: Type 4 alternator belt tension square nut |
I'm all for buying original stock when someone has it. Keeping new, corrct parts in circulation....and paying the seller a bit for the trouble of investing on that stock and storing it.
I also....HIGHLY appreciate when someone posts an EFFECTIVE....not crappy....way to fabricate or replace a part with a functional alternative....like was done here.
There is also somethingelse I try to do a lot (you may have noticed over the years).....I try to get people to think "descriptivly" about the alternate names and uses for hardware parts......and search for them in other places.
Do not always think that a VW hardware part is a unique automotive product. Yes...far too many times it is....unique to either automotive....and/or......even further unique to VW or even to one vehicle.
These particular nuts are an example. While unique in actual factory dimensions (they are short and shallow).....they really are just a "T" nut....like that used on mounting slots for mills and work tables.
This insanity on my part to always be thinking of where a usable, similar hardware, material metal or plastic product might also be used....comes from the huge range of industrial sites and factories I have worked in.
I cannot tell you how many times I have been in room with a handful of very skilled and experienced engineers, machinists and operators.....with a pile of broken equipment on the table....with all of the usual suspect catalogs out...grainger, Mcmaster, Fastenal (and many more)......looking for a part...and we cannot find it because no one knows the "real" or most common name for the odd fastener or part....so it shows up in no searches or catalogs.
Many times we saved our asses with a picture put into google image search....only to find a part or fastener....identifed by a name....we had never heard or thought of.
Always look for factory parts yes....but also...sharpen those description and searching skills! Ray |
Posted: Fri Feb 01, 2019 10:06 am Post subject: Re: Type 4 alternator belt tension square nut |
asiab3 wrote: |
We had trouble sourcing a nut that had the correct flange that wasn't too deep. If the nut flange is taller than the bracket is thick, the assembly will never torque down. So if the flange is 6mm but the bracket is 5mm, I'm nut sure the replacement will work. Am I understanding the dimensions of the nut correctly? |
It looks to me that the height if the part that fits in the groove is only 5mm, but even if it were taller it could easily be shortened with a grinder in only a minute or two. The problem I see is the width of the "insert" is it may be too wide for the groove in the bracket.
I think your idea of using the Unistrut nut is great as they are widely available and made from decent material. One could probably hit up any electrical contractor or utility lineman for one in a pinch. |
