harrymarlin Samba Member
Joined: June 07, 2018 Posts: 723 Location: Washington, DC
Posted: Thu Jan 31, 2019 2:05 pm Post subject: 1967 Beauty Ring part number? |
I am trying to find NOS beauty rings for my 1967 Beetle convertible, and I have found a few which have the right number of vents (10), but say they are for 4 lug nut wheels (Ghia 1967 was 4 lug nut?). As the 1967 was a 5 lug nut wheel, would these still work? What would be the difference (fit a slightly different hub cap)?
Does anyone know the part number for this part (such as 311 601 155)?
Thanks!
-Harry
aa390392 Samba Member
Posted: Thu Jan 31, 2019 2:22 pm Post subject: Re: 1967 Beauty Ring party number? |
I like to think there 2 types of rings, can you send pic. To be specific.
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Thu Jan 31, 2019 2:40 pm Post subject: Re: 1967 Beauty Ring party number? |
Here is an example of one:
Posted: Thu Jan 31, 2019 2:54 pm Post subject: Re: 1967 Beauty Ring party number? |
Not certain, but that ring should fit all VW's . Flat caps and baldies. _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Thu Jan 31, 2019 3:06 pm Post subject: Re: 1967 Beauty Ring party number? |
Great! If I'm understanding correctly, you are saying that the # of lug nuts has no impact on the design of the beauty ring or hubcap?
Thanks! |
KTPhil Samba Member
Posted: Thu Jan 31, 2019 3:57 pm Post subject: Re: 1967 Beauty Ring party number? |
4-lug wheels had hubcaps that fit over bumps in the wheel; 5-lugs fit inside. Whether this affects the trim ring or not I can't say, but I would worry it might unless KNOWN otherwise. |
mukluk Samba Member
Posted: Thu Jan 31, 2019 3:59 pm Post subject: Re: 1967 Beauty Ring party number? |
I'm seeing 141 601 155 B listed for '66 convertibles (specifies 5 hole mount), and 311 601 155 for '67-'69 convertibles (specifies 4 hole mount). _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Posted: Thu Jan 31, 2019 4:09 pm Post subject: Re: 1967 Beauty Ring party number? |
mukluk wrote: |
I'm seeing 141 601 155 B listed for '66 convertibles (specifies 5 hole mount), and 311 601 155 for '67-'69 convertibles (specifies 4 hole mount). |
Hmmm... the Type 3s had a different wheel offset; whether that affects the trim ring or not I'm not sure, but I always assumed it did. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Thu Jan 31, 2019 6:15 pm Post subject: Re: 1967 Beauty Ring party number? |
KTPhil wrote: |
mukluk wrote: |
I'm not 100% sure but I think 4-lug wheels are all the same.
5-lug trim rings are definitely different for 5-lug Type 3 wheels, Bug 5-lug ones don't fit properly. _________________ How to Post Photos
Posted: Thu Jan 31, 2019 7:26 pm Post subject: Re: 1967 Beauty Ring party number? |
mukluk - where are you seeing those part numbers? 141 would be Karmann Ghia, right (which is a type 1, which would make sense), and 311 is a 1500?
-Harry |
mukluk Samba Member
Posted: Thu Jan 31, 2019 8:02 pm Post subject: Re: 1967 Beauty Ring party number? |
The part numbers are pulled from the parts catalog.
Yes, 141 would be KG and 311 a Type 3, but VW's numbering system used the vehicle the part was first used on in the initial three digits -- if the part was subsequently used on a different line/type the part number retained the original three digits. A good example of this is with your typical 1600 dual port heads: their part number starts with 311 as they were originally designed for and used on the Type 3. _________________ 1960 Ragtop w/Semaphores "Inga" |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Jan 31, 2019 8:31 pm Post subject: Re: 1967 Beauty Ring party number? |
mukluk wrote: |
Yes, 141 would be KG and 311 a Type 3, but VW's numbering system used the vehicle the part was first used on in the initial three digits -- if the part was subsequently used on a different line/type the part number retained the original three digits. A good example of this is with your typical 1600 dual port heads: their part number starts with 311 as they were originally designed for and used on the Type 3. |
Exactly right ^^. An easy, popular example is the horn bar used on beetles from '64 to some time later. They have a 311 number. _________________
EverettB wrote: |
FU#5 |
codycat Samba Member
Joined: July 18, 2006 Posts: 1169 Location: Mobile, Alabama
Posted: Fri Feb 01, 2019 9:54 am Post subject: Re: 1967 Beauty Ring party number? |
call me 'old-school' but i prefer not to cover the two-tone wheels so famous to beetles...
the chrome is cool yes...so to me is a toss up -- but i dig my two-tone wheels tho _________________ Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 336 Location: Sunny So Cal.
Posted: Tue Oct 06, 2020 4:02 pm Post subject: Re: 1967 Beauty Ring part number? |
Harry, did you ever figure out the answer to this question? I'd like to pick up an NOS set as well but don't want to buy the wrong set. _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin |
Posted: Wed Oct 14, 2020 1:13 pm Post subject: Re: 1967 Beauty Ring part number? |
Jos.Hall wrote: |
Harry, did you ever figure out the answer to this question? I'd like to pick up an NOS set as well but don't want to buy the wrong set. |
Whoa - somehow I missed this post! It's probably too late, but the original part number is CK 141 601 155 B. *HOWEVER* The exact same ring also has a different part number CK 311 601 155 - that just wasn't the original for the Bug (but only a purist will know). As long as they aren't too damaged, you *can* find the part number stamped on each ring.
I hope that helps! _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Wed Oct 14, 2020 7:10 pm Post subject: Re: 1967 Beauty Ring part number? |
harrymarlin wrote: |
Jos.Hall wrote: |
I hope that helps! |
The 141 is what are on my '66 KG, and I bought an NOS set in the original box (also 141) and they are remarkably nice. Given the wheels and wheel covers are interchangeable for '66 and '67 Type 1s and KGs, who would know unless you looked at the part number stamped in the inner edge of the trim ring. I don't know if there's even a specific one for the Type 1 with a different part number, since they are interchangeable wheels. The guy I bought my set from in England has one more NOS set, unless he sold it in the last 6 months. Message me for his info if you're interested in his contact info.
These are the ones I have.
_________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
Last edited by 67 Florida Deluxe on Wed Oct 21, 2020 7:27 pm; edited 1 time in total |
Posted: Sun Oct 18, 2020 6:15 pm Post subject: Re: 1967 Beauty Ring part number? |
67 Florida Deluxe wrote: |
Jos.Hall wrote: |
The 141 is what I have for my '66 KG, I bought an NOS set in the original box and they are remarkably nice. Given the wheels and wheel covers are interchangeable, who would know unless you looked at the part number stamped in the inner edge of the trim ring. The guy I bought my set from in England has one more NOS set, unless he sold it in the last 6 months. Message me for his info if you're interested in his contact info.
I'd love to know who the guy in England was if you don't mind passing the info! They seem like a part you can't buy too early in the process _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
daven Samba Member
Joined: January 13, 2009 Posts: 351 Location: Dayton OH
Posted: Tue Jan 25, 2022 3:12 pm Post subject: Re: 1967 Beauty Ring part number? |
Reviving an old post.
Since the late (?) 1966 and 67 bugs used a specific rim/hubcap (5 lug) are the beauty rings different also?
I got a set of rings and compared them to the beautiful rings posted and the interior portion of my rings are flat while the ones in the pics have a "bump"?
Any help?
Dave |
Posted: Tue Jan 25, 2022 6:16 pm Post subject: Re: 1967 Beauty Ring part number? |
daven wrote: |
Any help?
Dave |
Post some photos _________________ -Kent (BaT "daleallen")
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
