69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 536 Location: Talbott, TN
Posted: Fri Feb 01, 2019 2:15 pm Post subject: Window Washer Valve - Where to buy? |
So the window washer valve started leaking in my 1978 Bus. It still works but it leaks out of the plunger stem whenever you activate it and drips washer fluid onto the floor mat. The one I need looks like this circled pic.
That one is available only as a complete assembly with wiper switch for $134. It's China quality, though, so don't want to waste money on it.
This one is available from Cip1 for a Beetle. Does anybody know if these can be made to work on a late Bay?
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Feb 01, 2019 2:22 pm Post subject: Re: Window Washer Valve - Where to buy? |
If your original isn't physically broken or cracked you can remove the 2 screws and replace the o ring...or flip it over. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Sat Feb 02, 2019 6:00 am Post subject: Re: Window Washer Valve - Where to buy? |
Interesting. Mine looks like you would have to drill off the back of the 2 open rivets to pull the metal backing plate off to replace anything rubber, and the rubber I could see did not look like a standard O-ring. |
Posted: Sat Feb 02, 2019 3:34 pm Post subject: Re: Window Washer Valve - Where to buy? |
I am only familiar with the one you circled _________________ "Always waiting for tomorrow ruined everything"
SGKent Samba Member
Posted: Sat Feb 02, 2019 3:42 pm Post subject: Re: Window Washer Valve - Where to buy? |
I believe those are part of the whole wiper assembly although maybe someone will have a source. One common conversion is to add a micro-switch there and an electric pump and assembly so it no longer relies on compressed air to work.
Part number is 211 953 553 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Feb 12, 2019 5:43 pm Post subject: Re: Window Washer Valve - Where to buy? |
Thanks to another generous Samba member, I now have a working washer valve. I had to take 2 non functioning valves to make 1 good one, but I thought I'd share a pic for anybody who's interested in what they look like inside. I should also point out that after cleaning all the crust off the spring loaded valve in the picture, the washer system sprays at least 3-5X more volume than it did previously. Major improvement
What’sHisName Samba Member
Posted: Sun Oct 24, 2021 1:54 pm Post subject: Re: Window Washer Valve - Where to buy? |
69BahamaYellow wrote: |
I have the exact same leaking problem with the same part. What did you do exactly that fixed the leak? Is there an o-ring in there that you can replace? And how did you dismantle it without breaking the plastic all to pieces? Mine seems quite brittle… |
Posted: Sun Oct 24, 2021 2:00 pm Post subject: Re: Window Washer Valve - Where to buy? |
Read my previous post regarding o ring. New o rings are available at any hardware store _________________ "Always waiting for tomorrow ruined everything"
Posted: Sun Oct 24, 2021 3:53 pm Post subject: Re: Window Washer Valve - Where to buy? |
pioneer1 wrote: |
Read my previous post regarding o ring. New o rings are available at any hardware store |
Is it simply the small o-ring sitting on top of that spring valve contraption? (If so, how do you separate the pieces of plastic it sits inside? Do they just pull apart?). |
