Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu May 06, 2004 3:52 pm Post subject: steering wheel 90* off center |
My steering wheel is off center by exactly 90 degrees. This is not a tie rod issue as the bus runs as straight as an arrow. The spoke interferes with my abiltity to see the speedometer. There is a centering key on the bus steering shaft and that is installed correctly too. So I'm left with drag link or the steering box itself any ideas out there? |
Bart Samba Member
Joined: March 18, 2002 Posts: 2516 Location: Chapel Hill, TN
Posted: Thu May 06, 2004 3:53 pm Post subject: |
possible the wheel was put on like that. Could pull it and reposition it. _________________ http://www.sundial-camper.com |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Thu May 06, 2004 3:56 pm Post subject: Re: steering wheel 90* off center |
[email protected] wrote: |
straighten your wheels, disconnect the draglink, count the turns your steering wheel makes then center it, then adjust your draglink until it meets up with the steering box arm. any fine tuning will have to be done through your tierods at an alignment shop. _________________ flossin, tossin, dippin, and trippin |
rizzag Now Wut?
Posted: Thu May 06, 2004 3:59 pm Post subject: |
Sundial Camper wrote: |
possible the wheel was put on like that. Could pull it and reposition it. |
he didnt mention the year of the bus but as long as it is a split and not an early barndoor then the steering wheel has a keyway and not splined so it cant be repositioned like a bug. _________________ flossin, tossin, dippin, and trippin |
travelvw Samba Member
Joined: February 15, 2004 Posts: 913 Location: Ozarks
Posted: Fri May 07, 2004 6:15 am Post subject: |
Rizzag is right, it can't be repositioned like a bug. You've gotta' adjust the drag link. If the rest of your front end is aligned correctly, you can adjust the drag link as he explained and won't have to go to an alignment shop. Its really simple, good luck,
K _________________ 1963 SO-34 camper
1969 sunroof beetle
1963 Adam's parts gilla |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Fri May 07, 2004 6:19 am Post subject: |
There is a 'stamped' line on the shaft that comes out of the steering box and one on the drop arm they should line up, check this before adjusting drag link. _________________ 64 356 C Coupe |
Liveonjg Samba Member
Joined: March 14, 2006 Posts: 430 Location: Eugene, Oregon
Posted: Wed Sep 26, 2018 9:58 am Post subject: Re: steering wheel 90* off center |
Reviving an ancient thread...
I have the same problem as the OP.
I have a 62 Single Cab.
Looking at things, it seems a simpler solution would be to remove the Pitman arm as it is more easily accessible.
I haven't done this before so I'd like some advice from the experts.
Thanks,
John _________________ Keep it acoustic.
77 FI 2L Westfalia - Ripple
77 FI 2L Westfalia - Althea
62 Dual Carb Single Cab - Lou |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Sep 26, 2018 10:26 am Post subject: Re: steering wheel 90* off center |
rizzag wrote: |
straighten your wheels, disconnect the draglink, count the turns your steering wheel makes then center it, then adjust your draglink until it meets up with the steering box arm. any fine tuning will have to be done through your tierods at an alignment shop. |
this procedure is also outlined in the service manual. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed Sep 26, 2018 1:11 pm Post subject: Re: steering wheel 90* off center |
Liveonjg wrote: |
Looking at things, it seems a simpler solution would be to remove the Pitman arm as it is more easily accessible. |
Sure, but problem is that when the Pitman arm becomes parallel with the drag link the steering will lock up on you at speed. _________________ In Stereo, Where Available! |
Posted: Wed Sep 26, 2018 5:19 pm Post subject: Re: steering wheel 90* off center |
Thanks for the replies. I will disconnect the drag link. _________________ Keep it acoustic.
