BigPaul Samba Member
Joined: December 21, 2014 Posts: 14 Location: Troy, NY
Posted: Mon Feb 04, 2019 5:29 am Post subject: Question about using a FWD donor VW for project |
Hello,
I have seen several people over the years take a FWD vehicle and use it as a donor for a trike. While I wasn't there for the builds they seem to work well. My question is, how would you address locking the steering? The wheels on the ones I have seen no longer turn steering wise.
Is that simply welded in place once you determine it's straight?
Just wondered. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Tue Feb 05, 2019 7:27 am Post subject: Re: Question about using a FWD donor VW for project |
depends on what vehicle is the donor I think, but I have seen a citroen 2cv with the engine/drive put in the back to make it mid engined. he welded the track rods to the suspension arms, both rods have adjusters so the toe-in can be adjusted.
http://kitcar.bb-fr.com/t6063p15-le-citrod |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Tue Feb 05, 2019 10:25 am Post subject: Re: Question about using a FWD donor VW for project |
Maybe use Fiero spindles. They are probably narrower than most FWD. so you get axles, too. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
