burner208 Samba Member
Posted: Mon Feb 04, 2019 9:24 pm Post subject: Need more heat? |
Made this, works well.
Brings the heat to the front where its needed and can be tucked in my shirt for added comfort.
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Feb 04, 2019 9:36 pm Post subject: Re: Need more heat? |
You should fix whatever is wrong with your heat. If your heat were working properly it would melt the shit out of that. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34014 Location: Conejo Valley, CA
Posted: Mon Feb 04, 2019 11:03 pm Post subject: Re: Need more heat? |
My ex had this setup on her '65 with a 36HP motor for years, before I fixed it to work like stock. It was a pool vacuum hose, but same idea... it plugged into the rear outlet just fine.
Of course, it made her smell like oil/VW, but since she worked in a machine shop, nobody noticed.
gt1953 Samba Member
Posted: Tue Feb 05, 2019 7:27 am Post subject: Re: Need more heat? |
OMG man repair the heating system in the vehicle. My vehicles heaters all work. I could never use a contraption like that as I would have second degree burns. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
74 Thing Samba Member
Posted: Tue Feb 05, 2019 7:57 am Post subject: Re: Need more heat? |
That should burn your skin |
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Tue Feb 05, 2019 8:21 am Post subject: Re: Need more heat? |
When I finished taking care of my '66 heating system and seals I had to crack open a window in winter time or it would get too hot inside.
Fix what's wrong, or post it here instead: https://geniebelt.com/blog/there-i-fixed-it |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Feb 05, 2019 8:52 am Post subject: Re: Need more heat? |
sjbartnik wrote: |
You should fix whatever is wrong with your heat. If your heat were working properly it would melt the shit out of that. |
Heater will work better (and sooner) if the fan shroud flaps & thermostat are present.
The heaters in my two take at least 10 minutes to put out decent heat, but I don't have flaps/thermostats (Arizona). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Tue Feb 05, 2019 9:28 am Post subject: Re: Need more heat? |
I like it!
Perfect for those "freezing your balls off" mornings.. |
Posted: Tue Feb 05, 2019 6:41 pm Post subject: Re: Need more heat? |
Mine gets really hot. I have to crack the windows at times. BUT i work in a cold warehouse and i hate being cold when ever i dont have to be. |
