BIG_TEXAS_PETE Samba Member
KrisBalfe Samba Member
Posted: Tue Feb 09, 2021 8:37 pm Post subject: Re: Making my 1961 Riviera syncro |
Trying to stay on target for all welding completed by the end of February. Fingers crossed...
Connecting vanagon a pillar support to the split. I like having this extra piece of strengthening on the front of the bus along with the completely boxed frame.
Finishing off the dogleg cap/wheel well
Finishing the front floor shifting shifter shift pod.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Feb 09, 2021 10:32 pm Post subject: Re: Making my 1961 Riviera syncro |
Favorite build. Hands down. _________________ nothing |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Tue Feb 09, 2021 11:29 pm Post subject: Re: Making my 1961 Riviera syncro |
This build just makes me smile |
Posted: Sat Feb 13, 2021 6:12 pm Post subject: Re: Making my 1961 Riviera syncro |
Found enough T4 16” steel wheels to have a complete set, pretty excited about that. Started on the support structure for the vanagon Brake/clutch pedal cluster and that is a big check off the list.
Oh man... if this were 10 hours closer would I have plans for it!
https://www.thesamba.com/vw/classifieds/detail.php?id=2413368
Someone else want to do something stupid? Perfect candidate. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Wed Feb 24, 2021 11:56 am Post subject: Re: Making my 1961 Riviera syncro |
I never expected you to get this far or to have done the work to the standard that you have. So many details still ahead of you before you even get to body and paint, but I have no doubt you will take the time to get them right.
What a cool project!! |
Posted: Wed Feb 24, 2021 8:52 pm Post subject: Re: Making my 1961 Riviera syncro |
Major Woody wrote: |
Thanks, much appreciated. I keep thinking I am almost finished with the big welding/melding jobs and one more thing pops up, but I am definitely on the downward slope of that part of the job. Hopefully primer will go on by the end of March and paint by the end of April. Then it’s just electrical, mechanical and a camper kit away from beers at the top of mineral basin🤞🏼 |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Feb 25, 2021 10:12 am Post subject: Re: Making my 1961 Riviera syncro |
are you putting the gas tank where it goes in a Vanagon or where it goes on a split? or somewhere else? _________________ regards
Uli
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Thu Feb 25, 2021 10:14 am Post subject: Re: Making my 1961 Riviera syncro |
favorite project on here! |
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Thu Feb 25, 2021 10:27 am Post subject: Re: Making my 1961 Riviera syncro |
What a Brutzelfest!
Everytime this thread pops up, I can’t wait to see the images of the progress!
Keep it going! |
Posted: Thu Feb 25, 2021 9:11 pm Post subject: Re: Making my 1961 Riviera syncro |
mandraks wrote: |
are you putting the gas tank where it goes in a Vanagon or where it goes on a split? or somewhere else? |
The vanagon syncro fuel tank sits in the same place as a split tank, unfortunately I removed 3” width from the chassis of the vanagon before putting it under the spilt so I was unable to use it. I will be using a late bay tank in the split stock location. It will give a little breathing room for the transmission compared to stock vanagon and make the starter change worlds easier. Going with the late bay tank for a few more gallons and it is already set up for fuel injection which will help with the bostig engine conversion I’m likely installing.
Thanks everyone. |
mtnbus Samba Member
Posted: Fri Feb 26, 2021 6:58 am Post subject: Re: Making my 1961 Riviera syncro |
Another great build Kris !
Amazing |
Posted: Mon Apr 19, 2021 9:44 pm Post subject: Re: Making my 1961 Riviera syncro |
Started searching for the best radiator location and I think I’ve decided on this spot.
Been hanging onto this old tow bar because I thought it could be useful, should make a good skid plate.
Likely will end up building a swing away carrier for the spare located here.
Pulled the trigger on this speed hut all in one speedo to avoid having to mount a bunch of gauges in a cluster, downside I did have to open up the pod.
Rear deck back in its spot.
Welded the two lids together to accommodate the bigger access for the engine
Just for the hell of it sanded more paint off of the nose and bumper and happy to find that silver white. |
Posted: Mon Apr 19, 2021 9:55 pm Post subject: Re: Making my 1961 Riviera syncro |
The dizzying array of lines and patterns in this shot is truly striking. Wow.
Posted: Mon Apr 19, 2021 10:06 pm Post subject: Re: Making my 1961 Riviera syncro |
cdennisg wrote: |
The dizzying array of lines and patterns in this shot is truly striking. Wow. |
Maybe that’s why sometimes when I should be working I find myself just staring at this thing for what could be considered too long? Damn flashbacks must be brought on by all the twisting of my back 🤔 |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Tue Apr 20, 2021 5:05 am Post subject: Re: Making my 1961 Riviera syncro |
KrisBalfe wrote: |
It’s never considered too long. Stare at it for as long as you need in order to plot your next move. This is a complex layout that deserves to be finished. Turning out great so far. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
Posted: Tue Apr 20, 2021 6:27 am Post subject: Re: Making my 1961 Riviera syncro |
cdennisg wrote: |
the cat agrees been looking at it too long
Uli
Two Glove Boxes Samba Member
Posted: Sat Apr 24, 2021 1:01 am Post subject: Re: Making my 1961 Riviera syncro |
Absolutely astonishing craftsmanship!! |
SplitBusVanatic Samba Member
Joined: August 16, 2005 Posts: 338 Location: Co. Mayo. Ireland
Posted: Sat Apr 24, 2021 1:16 am Post subject: Re: Making my 1961 Riviera syncro |
Epic thread. My favourite on here at the moment. |
