halbug Samba Member
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1000 Location: Stuttgart - Germany
TRS63 Samba Member
Posted: Mon Jul 27, 2020 4:29 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
So, still doing some progress on that project
After finishing the right side, I started on the left.
First checking/adjusting the parts I made for the left airbox:
And then removed the old rusted airbox:
Under it.. well some holes
So I started checking the replacement panel:
As for the other side, the top curve doesn’t fit:
So I corrected it:
And also made the hole for the wiring:
Then marked how big this panel is:
And where I should cut to remove all the rust but keep the original indent:
Then.. cut!
And putting the panel to cut it precisely, cut and adjusted for welding:
Sadly I then discovered that my argon bottle is empty.. so welding next time!
I also prepared the next steps by grinding down the old welding points:
Cheers
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
Braukuche Samba Member
Posted: Mon Jul 27, 2020 6:25 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Looking good! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed Jul 29, 2020 1:32 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hi can you please provide some more details on how you did the fish mouth holes for the wiring? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Marcdeb Samba Member
Posted: Wed Jul 29, 2020 3:32 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Your work along with these great pictures are very educational and provide much information so useful to understanding the construction of the Karmann Ghia. I am learning a lot from seeing your work. The hard part for me would be getting new inner metal lined up perfectly so that exterior metal will line up properly and have correct gaps! You have a lot of skill.
Votre projet est très intéressant.
Nice work Antoine. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
TRS63 Samba Member
Posted: Fri Jul 31, 2020 12:11 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks a lot guys for the nice words!
@Mellow Yellow 74: sure, here is how I do it:
1)First cutting the opening (if I remember well 2cms long but not sure..) with the angle grinder
2) Push a bit each side of the hole using something softer than steel to not mark it ( I love my corking tool from Cornfield custom but you can use whatever you want!):
3)push through a tube with a growing diameter (I used my tool to point before boring holes, I don’t know the name in english):
So basically, I use an angle grinder and these tools:
So, I finished welding my panel after picking up a new bottle of Argon:
And after planishing:
I also continued the front axle assembly:
Putting grease wherever needed:
And started cleaning the 60 only gearbox:
-before:
-Current Status:
Cheers
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Fri Jul 31, 2020 2:08 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Great work as always Antoine. As for the name of the tool with the point, it is called a Punch...Peut-être un coup de poing?
Not sure if that translates correctly in French. Love watching your build!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
TRS63 Samba Member
Posted: Tue Aug 11, 2020 1:48 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks for the tool name.. and the kind words
So, sometimes you have to take a few steps back to get it as wished.. I had welded my pan halves almost 1,5 years ago and even if robust, the welding aspect wasn’t that good.. i had left it, but I decided that I can’t let a part of the build not making me proud so.. I redid it
Primer removed, welding cleaned, rewelded where necessary, ground down and back in primer
And as it’s good for regular checking, I mounted the front panel back with some grips and this time didn’t forget to take some pictures:
And my favorite, my motivation-boosting picture:
Cheers
dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Tue Aug 11, 2020 9:03 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Well Done!
Starting to look like a car
Clamping on the fenders and the nose has to motivate you - keep going _________________ 1963 Karmann Ghia |
slalombuggy Samba Member
Posted: Fri Aug 14, 2020 11:21 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
WOW. Thanks for taking the time to archive your build and show all the detailed work that you have done. It will help a lot of people with their cars and be a great source of information for years to come. Well done Sir. You have inspired me to begin my long stalled project.
brad |
Ant B Samba Member
Joined: December 24, 2019 Posts: 157 Location: surrey, UK
Posted: Sat Aug 15, 2020 1:32 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Looking real good now sir.
wonderful work.
Ant B. |
TRS63 Samba Member
Posted: Tue Sep 08, 2020 3:14 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Always excited to see your posts Antoine. Your project is especially helpful as you are showing the deepest parts of
the Karmann Ghia that are not normally visible. It is a great way to document how these cars are built. Your work is motivating. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Tue Sep 08, 2020 12:34 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Antoine,
very nice to see continious progress.
You even made the best of the less hours you had for the 60. Looks pretty good and I am always inspired of the creative way you´re making new parts. I really like the Pizza-technique!! AWESOME
Keep going! |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Fri Sep 11, 2020 1:15 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
TRS63 wrote: |
-before:
-Current Status:
Cheers
Antoine |
When I first pulled the split case trans in my 59 the thing looked like the Mother Alien had gooped the thing. I replace the front seal and re-torqued everything. After driving it a bit I had a leak in the nose cone area and assumed it was from the shift rod tube. Pulled it out and stuck it in a corner. After a good coat of dust settled I realized the shift rod was totally dry. There was mild indication of some weeping at the case halfs but not much. All the oil was coming out of the breather then trailing back from there. I have recently installed a small small brass L hose connector that I will connect a hose vent to. Hopefully this will stop the leaks. Lots of other people have had issues with early vent holes.
Your metal work looks great and makes me want to work some more metal. |
VeloMikey Samba Member
Posted: Sat Sep 12, 2020 9:33 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
What makes a 60 split case one year only? I know he front mount is one year only. Your work is amazing! Keep it up! _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
61karmann Samba Member
Joined: January 01, 2004 Posts: 119 Location: south San Francisco
Posted: Tue Oct 13, 2020 5:00 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
TRS63 wrote: |
Saying I was excited to come back home on friday is under the reality as I knew of a box waiting for me
Here it is:
Yes you guessed:
Oh man how great are these mats:
Thanks a lot Luis for making it available
Cheers
Antoine |
Awesome!! What color mats? I just ordered some in olive with extra paint for the shifter & ebrake boot. _________________ www.tonydegrazia.com
www.analogtattoo.com |
TRS63 Samba Member
Posted: Thu Oct 29, 2020 5:59 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
VeloMikey wrote: |
What makes a 60 split case one year only? I know he front mount is one year only. Your work is amazing! Keep it up! |
I am no expert there but I think the front part that connect to the chassis mount is the différence..maybe someone knows it better?
@61karmann: the mats are grey like they would have been originally
So, long time no updates, and this is a really small one but I had some issues the last months on the daily drivers and they are the time priority.. I want to work on the ghia without stress to enjoy the journey
So I had only a couple hours this week but put back the tab holding the spare wheel on the driver‘s side
Here on the original part I cut, doing a Template for the position:
Position marked:
Holes ready to weld it from the back:
And then welding-primer and it's welded:
Back side cleaned:
And a small coat of primer to protect that part until I can continue:
Cheers to all,
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Fri Nov 20, 2020 10:53 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
I congratulate you on the quality of your work! So many small details I especially like the coated, protected floorboards I really like when someone tries to improve the original design in order for it to last longer
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
