TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
Posted: Sun Feb 24, 2019 10:37 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hi all,
@Inchpincher61: I will list what I still need for metalwork and keep you in touch
@Viktor Cz: wow, really great work man, well done!
@Ghia: Cyril, tu as mal vu! J'ai encore la tôle, qui est tordu mais que je vais réparer, et dans tous les cas en conformité avec l'origine! Tu me connais, je suis un "vintageux"!
I will update more this week but can't load the pics from my phone so I need to find some time for the computer..
Antoine |
GHIA Samba Member
Posted: Mon Feb 25, 2019 11:02 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Tu as raison, j'ai cru que les deux dernières photo étaient de toi |
TRS63 Samba Member
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Fri Mar 01, 2019 9:16 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Sort of like metal origami.
Beautiful work - you make it look very simple, which is surely a sign of your skill level and experience. |
art_lessing Samba Member
Joined: February 20, 2014 Posts: 154 Location: Sacramento
Posted: Fri Mar 01, 2019 10:50 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
can you show how you put that little fold into the ends? I need to make patches for the battery trays and other places..This little crimp would be good for putting in patches where unseen butt welds are not neccessary, ie engine compartment, pans etc..... |
TRS63 Samba Member
Posted: Fri Mar 01, 2019 12:04 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hi Guys,
really happy you like it!
@KGCoupe: I am not that experienced and only learn by doing but I spent quite a lot of time studying the art of metalshaping and try to put now all into practice. I hope I can help other members here and I am open to any criticism or advice on how to do better
@art_lessing: sure, please feel free to ask any question!
I used my vice and 2 piece of steel, here are two pictures:
I hope it's clear, otherwise please ask!
Well, I see that you like to see some metalshaping so here comes the next update
I know you can buy the splash guards but: I want to learn more and I try to keep this project on a reasonable budget so I built mine..
As usual, first is the drawing:
Then I build myself a hammerform out of wood:
Ready to cut:
cut and I started to bend the sides using my bead roller:
and then it's time for the hammerform:
and after some hammering, some shrinker/stretcher action,... I have it:
Fitment check:
and it's time for the second side:
check:
and after making the holes, all in primer:
Just to give you an idea of the condition of my ghia..this felt down just by moving the body:
Stay tuned
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1047 Location: Jacksonville, FL
Posted: Fri Mar 01, 2019 3:10 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks for sharing your tips and progress. I created a template/drawing from my mangled seat rail crossmeember. Can you confirm or correct my measurements. I too want to get functional at metal shaping. I did not see a seat return spring clip on your crossmember. Is that a later model feature?
I have another favor to ask which may benefit others as well. Could you create a 1:1 tracing/scan, in PDF format, of the wooden form you built for the splash guards and share it? How wide is the lip on the guards. My car did not include them and I would like to fab those myself as well.
...we're all in this together,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
TRS63 Samba Member
Posted: Sun Mar 03, 2019 11:54 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hi Emil,
For your measurements, I will check them next time I am in the shop and will confirm them to you. But there is a difference in the width between the seats before/after 68, I can only confirm you for my 60.
Good point concerning the spring, to be honest I did not think about it. If anybody can tell me if my 60 need and if yes how does it looks like (picture?)
For the splash guard: I don't know how to scan it 1:1. If you're ok, I can draw it on a paper and send it to you in a letter. Would be happy to help you and if you can scan it with the good scale for everybody, that would be awesome!
So, next update. Once again, I know that you can buy it but..love to build as much as I can so I started on the airboxes..
First cut my metal sheet:
Found a tube with the good radius and folded it:
Then it was again time to use my bead roller for the folding on the side:
On the first attempt I made it wrong and it did not follow the original curves where it will be welded so I made some hammerform and started again:
And it fits:
Cut the middle part:
Same method for the bottom part, also used a hammerform as the shape isn't that easy..
And adjusted:
Final adjusting will take place after I changed the front part of the wheel well
Oh.. and I also made the second side:
Stay tuned
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Mar 04, 2019 6:34 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Fantastic work Antoine, I am sure many here, like me, had the ability you posses with metal work! Awesome!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
TRS63 Samba Member
Mrfun2fly Samba Member
Joined: November 29, 2015 Posts: 548 Location: New Mexico
Posted: Mon Mar 04, 2019 7:49 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Hey bud, I'm restoring a 60 also but don't nearly have the skills you do.
I was pretty fortunate w my ghia, it was pretty complete so havent had to find many parts.
If you can find the time, think you could post a list of what is different with the 60 compared to other ghias?
Thank you sir:)
Lee |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Mar 04, 2019 9:40 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Interesting to see your use of the hammer forms. I made my own hinge pillar cover plates and fresh air ducts too. I turned the edges using a swaging tool then used a hammer and dolly and the kick shrinker/stretcher. The hinge pillar cover plates weren’t too bad but I spent many hours on the ducts.
Don’t forget the drain slots and the wiring holes in the ducts. I formed the recess drain slot using a bolster between the jaws of a vice but haven’t done the wiring holes yet because these are like a formed fishmouth. I am thinking of just doing a hole in front of the duct and using a trimmer like newer models use instead of having the wiring going into the duct. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
TRS63 Samba Member
Posted: Mon Mar 04, 2019 10:42 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
Thanks guys for your support
@Lee: I will make a list with everything I know and maybe some more experts here can complete/correct it!
@Mellow Yellow 74: thanks a lot. Never used hammerform before and wanted to try it, I think it turned out ok. But I also had to use a shrinker/stretcher concerning the holes: thanks for the reminder, I noted they are still needed before welding but I want to try an idea on how to make the wiring hole.. if it works I will share it here!
So, next small update..
One of the worst part of my ghia is the dashboard. Have a look:
I did not started the rebuild of it yet but it rusted so much that even the glove box door was rusted. I decided to rebuild it as a small side project.
Here the rusty start:
Opened it and realised it never had any primer or paint from the factory..of course it rusted..
So I cleaned everything, welded where needed and put some rust protection:
And closed it back:
TRS63 Samba Member
Posted: Wed Mar 06, 2019 8:02 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
I can appreciate this, mine had various random holes in and under the dash and on the inner wheelhouse panels that I had to weld up - holes for an aftermarket wiper bottle bracket, holes for a relocated brake fluid bottle bracket and hoses, holes for a rheostat to use the 6V wipers with 12V power, a hole for a separate wiper wash button and holes for speaker wires etc. _________________ 1962 Karmann Ghia
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
Posted: Tue Mar 12, 2019 3:28 pm Post subject: Re: Restoration thread: my 60 strato blue coupe |
kiwighia68
TRS63 Samba Member
