TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
JeffL Samba Member
TRS63 Samba Member
TRS63 Samba Member
halbug Samba Member
kingkarmann Samba Member
Posted: Thu Dec 08, 2022 9:12 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
halbug wrote: |
Antoine, I envy your dedication
It is almost like building a dreamcar body fram scratch. Keep going! |
I'm thinking Antoine worked for Karmann in a previous life _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Thu Dec 08, 2022 9:34 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Bravo!! Seems there is no repair too tricky for you. It’s been great following this thread and seeing every nook and cranny getting some love. |
TRS63 Samba Member
TRS63 Samba Member
Marcdeb Samba Member
Posted: Fri Dec 16, 2022 6:53 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Takes a lot of skill to achieve proper alignment of all these body parts properly. There's so much to consider with so many parts not being removed at the same time. Incredible work. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Braukuche Samba Member
Posted: Fri Dec 16, 2022 8:55 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Lot of thin, thin metal on that lower A. That’s going to be a major hurdle jumped when it’s done. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
halbug Samba Member
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Sun Jan 29, 2023 6:54 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
Antoine, WOW!
That A-pillar was a nightmare ! But perfectly fixed!
I think the same like halbug. What an dedication! I am not sure if I would have the patience for that. But that's the way how Ghias are rescued. Keep Going!
Can you give a feedback regarding the Atelier K parts? They seam to fit quite well and have a good quality? |
TRS63 Samba Member
TRS63 Samba Member
TRS63 Samba Member
Posted: Fri Mar 24, 2023 5:39 am Post subject: Re: Restoration thread: my 60 strato blue coupe |
So, long time no updates but doesn't mean I did nothing.. I mostly work on the interior of my 62 ragtop to make it ready for the summer but some small steps were done on the ghia. If you remember well, I already did start the part for the bottom of the back of the right rear fender:
So I finished adjusting it:
And marked for the cutting:
And started to make some cutting:
Under it, more panels are needed so as usual, first build the repair panel and then cut:
Ready:
But before welding it, I want to make the repair panel under the bumper fixation. And before that, I needed to solve an issue with one of the screw for the rear bumper. Someone in the past tried to remove the broken screw by welding it..but did really bad :
So no chances other than removing the fixation :
So I removed it:
And found the great previous work..
So, time to redo the fixation, the new one next to the rest of the old one:
Oh, maybe better seen here :
The built one in details:
Test fit:
As I didn't have a square nut, I built one with a normal nut and a cut disc:
And repaired:
Next: built the bottom patch panel, and then weld all these panels to finish this area!
Bests
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
