spacebiscuit Samba Member
Posted: Sun Feb 10, 2019 3:45 pm Post subject: Kienzle Clock Repair - Help |
I've started this thread as I am going to attempt the repair of my Kienzle dash clock.
First up how do I remove the back cover. I have removed two small nuts (green arrows), but I remember reading that there is another step required.
Anyone able to give me a pointer? Thanks! _________________ 1972 Type 2 1600cc
1990 MKII Golf 1.6 CL |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun Feb 10, 2019 6:06 pm Post subject: Re: Kienzle Clock Repair - Help |
spacebiscuit wrote: |
Anyone able to give me a pointer? Thanks! |
The third nut is undef that blue disc shaped "seal". That is an anti-tamper seal.
Do some searches. There is a lot written about these clocks including a few people that got deep into them and fixed some serious problems.
They need to be cleaned with the correct cleaners....made for clocks....and for jeweled bearings. They also need to be lubed....in exact places. Not every parf gets lubed because it can wreck things. They also need to be lubed with oil made for clocks.
In the short term...it may just be the fusible solder link that finally gave out.
But at this age....just like with fine watches over time.....its time to replace the old oxidized lubricants. Ray |
SGKent Samba Member
Posted: Sun Feb 10, 2019 6:25 pm Post subject: Re: Kienzle Clock Repair - Help |
yes - learn how to use Google. There are plent of places that repair them and several articles including a PDF on this Samba website. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 11, 2019 1:29 am Post subject: Re: Kienzle Clock Repair - Help |
Thanks for confirming it is the blue plastic that I need ot break off.
I have trawled the Samba and Google and Youtube extensively and I have the PDF which explains the tear down and reapair process. But it's all just theory until I have the clock in front of me to look at. _________________ 1972 Type 2 1600cc
Posted: Mon Feb 11, 2019 8:37 am Post subject: Re: Kienzle Clock Repair - Help |
For the record.....decades ago.....I was just a guilty as anyone....of just cleaning these clocks with circuit cleaner and lubing them up with tri-flow or similar instrument oil like Starrett M-1.....thinking I was doing the clock a favor.
In virtually every case....I got the clock working. In most cases along with my lube and cleaning....the fusible link needed repair.
But.....in almost every case.....a handful of months later or less.....the clock is off (slow or fast)....and I have to get inside again and adjust the +/- adjustment..... or a year or so later....they start having the start and stop problem. I just assumed they did not have a great lifespan......so I would just pick up another clock or two from the junkyard.
In later years I would come to understand that these are relatively fine clocks....by the way....my parents have a 110 year old Kienzle grandfather clock in their hallway just ticking along...and that my sloppy cleaning and lubing....is what did them in....not that fact they they are just some kind of cheap automotive clock.
These are real clocks with jeweled bearings. They can last a looooong time....but the cleaning, lubing and adjusting needs to be done correctly....no different than what you would do for a fine watch.
Ray |
Posted: Mon Feb 11, 2019 1:19 pm Post subject: Re: Kienzle Clock Repair - Help |
raygreenwood wrote: |
Ray |
Ok so today I visited a jeweller to hav e apin put in my watch strap. It is an old family run business with a real old vintage look and feel - the type of place where they're passionate about their profession. They also advertise as "watchmakers" so having read the above I think I might return tomorrow with the clock to see what they say! _________________ 1972 Type 2 1600cc
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Mon Feb 11, 2019 5:05 pm Post subject: Re: Kienzle Clock Repair - Help |
Ray |
Ok so today I visited a jeweller to hav e apin put in my watch strap. It is an old family run business with a real old vintage look and feel - the type of place where they're passionate about their profession. They also advertise as "watchmakers" so having read the above I think I might return tomorrow with the clock to see what they say! |
Clocks and watches are not something to mess with unless you are ok with them maybe being worse off. I try to cycle my watch/clock servicing so I don't have to do it all at once. Unlike a car, this is where you want to buy the one on the best mechanical shape! _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Mon Feb 11, 2019 8:35 pm Post subject: Re: Kienzle Clock Repair - Help |
I have had the "fusable link" burn on two of my Mercedes clocks. Simply replace it with a thin wire of solder. It is a solder wire. When it gets too hot it melts.
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
Posted: Tue Feb 12, 2019 4:09 pm Post subject: Re: Kienzle Clock Repair - Help |
I've removed the back cover, looks like the fuse is the issue?
Otherwsie it looks fairly clean I guess. _________________ 1972 Type 2 1600cc
wihr Samba Member
Posted: Tue Feb 12, 2019 4:22 pm Post subject: Re: Kienzle Clock Repair - Help |
Easy repair!
Posted: Tue Feb 12, 2019 4:33 pm Post subject: Re: Kienzle Clock Repair - Help |
I'm not sure how to solder this though, anyone got in pics of a repaired solder joint? I have the low temp solder for the job but the gap is not insignificant. I can see solder dripping where I don't want it to if this goes wrong! _________________ 1972 Type 2 1600cc
wihr Samba Member
Posted: Tue Feb 12, 2019 5:43 pm Post subject: Re: Kienzle Clock Repair - Help |
With a short length of solder "wire" simply 'touch' both ends with your iron. That is what I did.
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Wed Feb 13, 2019 6:13 am Post subject: Re: Kienzle Clock Repair - Help |
No photos but I do remember (carefully!) wedging a small piece of wood in there (toothpick or popsicle stick?) to hold the contacts together while I soldered the joint. Also be sure and use flux. _________________ 1970 Crew Cab |
Posted: Wed Feb 13, 2019 6:47 am Post subject: Re: Kienzle Clock Repair - Help |
So the two contacts shuld be together when I solder, rather than bridging them together with a piece of solder "wire".
I've just read back over some of the other threads on the repair process it seems that when the fuse has blown the contact have "sprung apart". So I should be able to move the top contact down to make contact with the bottom? _________________ 1972 Type 2 1600cc
70Crew Samba Member
Posted: Wed Feb 13, 2019 7:50 am Post subject: Re: Kienzle Clock Repair - Help |
Correct, you will be able to push them together. There should probably be a small gap left for the solder to fill, but not much of one - say 1/32 of an inch or so. Heated solder flows easily and will fill that gap. _________________ 1970 Crew Cab |
Posted: Wed Feb 13, 2019 2:07 pm Post subject: Re: Kienzle Clock Repair - Help |
OK make sense now, I used a very small screw drive to pull the upper contact down. When using flux, do I add this to the top iron or should I try to get some on the contact, or both? _________________ 1972 Type 2 1600cc
70Crew Samba Member
Posted: Wed Feb 13, 2019 4:15 pm Post subject: Re: Kienzle Clock Repair - Help |
Both.
From Wikipedia: As cleaning agents, fluxes facilitate soldering, brazing, and welding by removing oxidation from the metals to be joined. ... By preventing the formation of metal oxides, flux enables the solder to adhere to the clean metal surface, rather than forming beads, as it would on an oxidized surface. _________________ 1970 Crew Cab |
Posted: Sat Feb 16, 2019 1:37 pm Post subject: Re: Kienzle Clock Repair - Help |
Here is my repair:
I tried it in my box, initially there was some activity then nothing. I removed the white plastic back cover and manipulated a few of the gears manually and I had some life. I then wiggled the time adjustment knob on the front of the clock and it was running intermittently. I'm not sure if my battery wasn't a little low so need to test again after I have charged it, or it could be there I need to lubricate the item a little? _________________ 1972 Type 2 1600cc
Posted: Sun Feb 17, 2019 11:55 am Post subject: Re: Kienzle Clock Repair - Help |
Tried the clock agian today, it runs for about 30-45 seconds, once it stops if i wind the adjuster on the front very slowly it comes back to life until it stops again.
With the power disconnected if I turn the 3/4" steel wheel the clock runs for about 3-4 minutes and the hands move to show this. So perhaps I need to lubricate the mechanism, I found this does it look suitable:
https://www.amazon.co.uk/Precision-Oiler-Clocks-Wa...=clock+oil _________________ 1972 Type 2 1600cc
Posted: Tue Feb 19, 2019 7:32 am Post subject: Re: Kienzle Clock Repair - Help |
For those who have oiled these clocks, are there points that should be oiled. I am guessing given this is a precision piece I shouldn't be indiscriminately spraying oil. _________________ 1972 Type 2 1600cc
