av8shunmeckaneck Samba Member
Posted: Mon Feb 11, 2019 10:55 pm Post subject: Home built side curtains |
Starting my own project to make side curtains using 1" x 3/16" flat stock. I am using flat stock that is wider than the original to use a retainer around the inside to hold the plastic windows in.
I started by drilling out the rivets in the door supports and removed them.
I took the measurements with a digital protractor to make it easier to miter the corners.
I tig'ed it together on some plates to try and keep it flat.
More pictures to come. |
BlissBignall Samba Member
Joined: June 20, 2016 Posts: 72 Location: San Angelo, TX
Posted: Tue Feb 12, 2019 10:52 am Post subject: Re: Home built side curtains |
I'll be interested to see how this turns out! My side curtains are pretty bad. _________________ 1963 Beetle...My mom's car that got sold in 2012
1969 Beetle...That was fun!
1972 Beetle...Never ran right
1974 Thing....Daily driver on sunny days |
FJBLF Samba Member
Posted: Tue Feb 12, 2019 5:57 pm Post subject: Re: Home built side curtains |
Contact this guy, he is in Monterrey Mexico, I've seen his work, he did mine, takes his time but he does quality work at a good price, Tell Him Francisco from the "Club Safari de Mexico" sent you. I'm sure he can ship internationally. I got mine on a trip to Mexico. You can either send them your frames or he makes new once.
https://www.facebook.com/lcca.miky _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Tue Feb 12, 2019 11:49 pm Post subject: Re: Home built side curtains |
Sending out my frames to be redone would take the fun out of it.
Didn't spend much time on the curtains today. I knocked the rivets out of the posts and the holes were just the right size for m5 x .8 screws. The frame holes are countersunk for countersunk stainless socket head screws.
Here is a profile picture of the seal that I found on Amazon. I bought this just before I ordered the replacement seal for my hood. Turns they are exactly the same profile but the Amazon seal has a neoprene flap. The hood seal is all rubber. I am going to use the Amazon seal to replace the one on the decklid.
FYI, I haven't measured how long the seal is for the hood but I guesstimate that the Amazon seal and Jbugs seal are about the same price per foot. The Amazon seal was $45 for 30 feet with free next day shipping. I'm thinking the neoprene seal will be a little more delicate and flexible against the soft top anyway. |
Posted: Wed Feb 13, 2019 10:43 pm Post subject: Re: Home built side curtains |
Found the short piece that was left over after replacing the hood seal. Here is a comparison. Amazon seal on the right.
Found this seal on Amazon today. If the first one has too much curl to it I may get this one to try.
Added a retainer lip to the inside of the window frame.
I was originally going to sandwich the window against the frame from the outside with an L shaped retainer but changed my mind after picking up some acrylic today. I got 3/16" thick acrylic which is the same as the flat stock for the frame. Tomorrow I will make an aluminum retainer for the outside and drill and tap the frame to screw it in place. |
Posted: Thu Feb 14, 2019 11:30 pm Post subject: Re: Home built side curtains |
Made an aluminum retainer today for the outside of the window frame. Tapped the frame for m4 countersunk screws.
obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Serpent7 Samba Member
Joined: May 26, 2008 Posts: 410 Location: Temple Hills, MD.
Posted: Wed Feb 20, 2019 9:29 am Post subject: Re: Home built side curtains |
Man! You should tart selling these??? _________________ 2019 Audi Q5
2014 Volkswagen Touareg X
1997 Honda Shadow
1979 Kawasaki KZ1000
1979 Volkswagen Transporter
1973 Volkswagen Thing |
Posted: Mon Feb 25, 2019 12:48 am Post subject: Re: Home built side curtains |
Jimmy rigged the drill press to a motorcycle to use as an adjustable height table. Needed a larger surface to support the frames while I drill all of the holes for the retainers and support studs. Finished cutting and welding the other 3 frames. Also cut and welded the other 3 retainers. I will take some more pictures later but here is what the drill press looks. It actually works pretty well.
Posted: Mon Feb 25, 2019 12:49 am Post subject: Re: Home built side curtains |
Serpent7 wrote: |
Man! You should tart selling these??? |
Maybe. Would definitely have to come up with a more efficient way of making them. |
Posted: Thu Feb 28, 2019 12:30 am Post subject: Re: Home built side curtains |
Getting closer. Made some plastic snow today. I have one frame fully assembled. Need to finish cutting out three more windows. I'm also waiting on more screws for the retainers. The next big step is to start fitting the knock on seal around the edge. The corners are going to be fun.
Posted: Thu Mar 07, 2019 9:45 am Post subject: Re: Home built side curtains |
Just amazing! Keep it up! _________________ 2019 Audi Q5
1997 Honda Shadow
Posted: Thu Mar 07, 2019 9:57 pm Post subject: Re: Home built side curtains |
Finished one. The others are ready to assemble but been working on fixing the corner rot at the jack point. He are some pics of the finished one. Went with a different style seal.
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sat Mar 09, 2019 2:13 pm Post subject: Re: Home built side curtains |
very nice work
rob _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
KAmes Samba Member
Joined: February 16, 2014 Posts: 877 Location: Illinois
Posted: Sat Mar 09, 2019 3:31 pm Post subject: Re: Home built side curtains |
Looks good! I like this sort of project. |
Posted: Sat Mar 09, 2019 9:59 pm Post subject: Re: Home built side curtains |
Its been fun. Nice being able to see through the windows now. I made hinge mirror mounts a while back which made the mirrors contact the windows. I'll need to put rubber on the door restraints so they don't open too far. Don't want the mirrors damaging the new windows. Next I'll need to make a rack to hold them under the hood. I'm thinking sockets for the pins to fit into and some kind of latch over the top to keep them spaced apart.
I'll post some daytime pics with all the windows in. |
Posted: Tue Mar 12, 2019 10:22 am Post subject: Re: Home built side curtains |
I ended up powder coating the aluminum retainers. Got a good deal on the powder coating system at HF.
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Sun Jun 09, 2019 10:52 pm Post subject: Re: Home built side curtains |
Those are Great!!!
my thought was also for a thin sheet metal skirt around it so fabric has a Full size area so there Is overlapping of front windows to back
also for a better seal at door
are you Making them?
so u riveted them To the frames from the outside?
is there anywhere we could get proper top material to cover than I'm
then the PC windows can be Within the fabric Not just riveted to the inside
I have also thought of almost a thin poster frame inserted used as a rail to Slide part of the window open _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Fri Feb 14, 2020 3:21 pm Post subject: Re: Home built side curtains |
sharkskinman wrote: |
Those are Great!!!
I have also thought of almost a thin poster frame inserted used as a rail to Slide part of the window open |
Yes- I made them. The windows aren't riveted in. It's 1/8" acrylic. The basic frame has 1/4" wide flat stock welded in as a lip for the inside of the acrylic to rest against. There is an aluminum retainer screwed on from the outside with countersink m3 screws (maybe why they look like rivets). The frame is 3/4" wide 1/8" flat stock from HD tug welded so I would have to do a bunch if finish work. The outside retainer is 3/4" aluminum flat stock from HD. I think it's 5052 with either some kind of coating or anodized. Whichever it is, it's truffle to weld. Should have gotten proper aluminium from the metal yard. |
