ernstben Samba Member
Joined: April 30, 2005 Posts: 621 Location: Manchester, Mi
Posted: Sat Apr 06, 2019 3:51 pm Post subject: Re: Ben's '56 Ragtop Project |
Alrighty! It's warmed up and I had a couple minutes to poke around in the garage. Got the body off the chassis:
I think the rust in the beam might be terminal and the frame horn is not much better:
_________________ Ben
'63 Ghia Coupe Project
'59 Panel Project
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu Apr 11, 2019 10:47 am Post subject: Re: Ben's '56 Ragtop Project |
Agree on the beam. It's toast. Luckily they're cheap and easy to come by.
Need to cut into the frame horn and further investigate. Might just need a patch but it was definitely loaded with water for a period of time so you'll need to treat what must be extensive rust inside the tunnel.
Good luck. Lots of interesting work ahead of you. |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Thu Apr 11, 2019 6:09 pm Post subject: Re: Ben's '56 Ragtop Project |
If your plans call for lowering that car, the beam is still useable if you do a 4 or 6 inch narrow NOS beam patch kits pop up every once in awhile here, but I bet that metal is thin everywhere. You can always find another Oval beam, hack off the bumper stop with the number on it, and weld it onto the new beam. Easy job. |
Posted: Fri Apr 12, 2019 4:59 pm Post subject: Re: Ben's '56 Ragtop Project |
The car came with a pair of floor pans, but they probably weighed in at a couple pounds all together. I took some calipers to them and they came in at .7 to .9 mm depending on where you measured. Like... dental floss thin...
So, I ordered some from WW. Let the games begin!
'59 Panel Project
Posted: Fri Apr 12, 2019 7:38 pm Post subject: Re: Ben's '56 Ragtop Project |
I just fit a set of WW floor pans into my 56 Ragtop this week. Very minimal trimming involved. I was extremely impressed. I did have to reshape the front outers just a little to fit the curve of the napolean hat brace. Definitely worth the money, I won't be messing with any other brands if I can help it. I did need to order floor mat pins, and battery tray hold down parts. And for some reason, the pedal stop bracket area on the floor pan only has one hole/ nut instead of 2.
I have another 56' pan with original metal that has a locating pin for the front hole of the pedal stop, and one hole/ nut. I will probably just fit the pedals on the WW pan, and drill a hole and weld a nut on the back side. |
Posted: Fri Apr 19, 2019 5:03 pm Post subject: Re: Ben's '56 Ragtop Project |
I built a little body stand for the oval to make room in the garage for other things while it's under construction:
Then, I took the angle grinder and the ol' hammer and chisel to the old pans:
After a little bit of grinding and general clean up, I laid the new floor pans where they'll live:
It's still in the lower 40's here and rainy/windy, so I haven't had a chance to really get into it out in the garage yet. The 7-month old doesn't help matters much either! _________________ Ben
'59 Panel Project
Posted: Fri Apr 19, 2019 5:05 pm Post subject: Re: Ben's '56 Ragtop Project |
motofly196 wrote: |
So far, I totally agree on the WW pans. Interesting that they had a variety of different choices for floor pans based on the year, and yet they don't have the correct mounting nuts for the pedal bracket. Ah well, I'm going to do the same as you and just weld a nut on the backside. _________________ Ben
'59 Panel Project
Posted: Sat Apr 20, 2019 11:28 am Post subject: Re: Ben's '56 Ragtop Project |
I'm trying to make the most of little bits and pieces of time that I can free up. Today, I removed the carpet retainer piece from the driver's side heater channel as it was welded on backwards:
Then, I cut out the vents that are in the forward position and welded in the original ones in what should be their original positions nearer the firewall:
'59 Panel Project
Posted: Mon Apr 29, 2019 8:46 am Post subject: Re: Ben's '56 Ragtop Project |
Figured out the source of the rust in the pan head:
F$%#ing mice! I spent a really, really gross couple of hours evicting their mummified corpses from their previous home. In the end, I think a couple spray-downs with acid and some metal patching and all will be well again. Started with some exploratory surgery:
'59 Panel Project
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Sat May 04, 2019 1:15 pm Post subject: Re: Ben's '56 Ragtop Project |
Great job Ben! Keep working! The weather in CLE is just as cold and rainy as in Michigan. Our Great Lakes are GREAT for cold weather! |
Posted: Sat May 04, 2019 3:44 pm Post subject: Re: Ben's '56 Ragtop Project |
SixVolt wrote: |
Thanks Sean! I think we've finally broken through to the 60's around here, so I was able to get out in the garage again today.
Welded in the battery hold down stuff and the jack points:
And then did some patching on the front pan area. I'm super excited with how it turned out (even though it doesn't look that great in pictures for some reason):
'59 Panel Project
Posted: Thu May 09, 2019 6:38 pm Post subject: Re: Ben's '56 Ragtop Project |
Did some serious clean-up on the pan over the last week or so. Finished up patching small spots here and there:
Removed the swing arms and only sheared off 1 bolt which I was able to successfully remove using the "weld on a nut" method. Only the second time in my life I've been successful at it:
You can also see there that I had to replace the end of the floor pan support due to corrosion.
Then I hit it with a couple doses of phosphoric acid:
After that, I gave it a dose of primer and laid the WW floorpans in place:
I'm really close to welding the pans down (I even popped a bunch of rosette weld holes in advance as you might notice), but I have 2 questions for the experts. First, on fitment. When I bolted the heater channels down lightly to see how it all fit together, I noticed that they hit the jackpoints before seating:
Is that normal? I can't see any other way to have welded those jack points on.
Also, I'm a little bit taller than most people (6'4''ish, but long in the legs I think) and I've found my old bug and ghia to be uncomfortable to get into and drive for long periods of time. I'm considering moving the seat tracks back a bit:
My only concern is that the rubber floor mat someday might look goofy ending several inches before the seat track. Anyone had that happen? Is it better to make some sort of adapter? Thanks in advance! _________________ Ben
'59 Panel Project
Posted: Sat May 11, 2019 1:25 pm Post subject: Re: Ben's '56 Ragtop Project |
Well, too late, I did it!
In the end, I moved it back about 3 1/2 inches. I also trimmed off the top of the jack points and welded on a little cover plate to give it a little rigidity:
I also was a bit worried that the WW seat tracks might not fit all that well based on some users' reviews here. They were perfect though:
'59 Panel Project
Posted: Sat May 25, 2019 5:00 pm Post subject: Re: Ben's '56 Ragtop Project |
Got out the ol' protractor and set the spring plates by first zeroing out the tunnel:
And then setting the arms to 13 degrees:
It seemed like there was some disagreement as to what to set them at, but in the end, I think I'm fairly sure that a '56 should be at 12 degrees +/- 30 minutes. I decided to give it a little extra spring because I plan on putting a slightly larger engine back there.
After hitting the pan with some black paint, I dug out parts of the old mouse-piss-corroded fuel line:
And started the process of feeding a new one in the tunnel:
'59 Panel Project
Posted: Fri May 31, 2019 9:04 am Post subject: Re: Ben's '56 Ragtop Project |
So, the roughest part of this project going forward, I think, will be the nose. It definitely got hit pretty darn hard at some point. There was a repair done at some point (and a NOS nose piece was used as there is no VIN stamped to the body by the brake reservoir), but it was done poorly to say the least. I'm thinking a full-blown front clip replacement is necessary here, at least back to the gas tank mounting rails. Photos of the carnage:
'59 Panel Project
Posted: Fri Jun 07, 2019 4:00 pm Post subject: Re: Ben's '56 Ragtop Project |
Work continues! I finished up back-dating my heater channels to be appropriate for the '56. This included welding in the original vents in the forward position, cutting out and smoothing over the later-model vent area by the seat, smoothing the area where the rear of the front fender sits, and deleting the existing vents. Here's some pictures of the driver's side channel in situ:
The chassis is all painted up, the swing plates are installed with new baby-powdered bushings and fuel line run. Here's a cool view of the chassis that won't be possible going forward:
Then, I welded some supports for the body before I remove the heater channels:
I've been thinking about what to do about the rear cross member:
But decided to remove it entirely and replace instead of patching:
'59 Panel Project
Posted: Fri Jun 07, 2019 4:06 pm Post subject: Re: Ben's '56 Ragtop Project |
The W decklid is in really decent shape except for the area where the spring mounts. At some point, that entire section ripped out. I picked up a donor decklid at the most recent MVVC festival. You can see both the damaged original piece and it's donor piece here:
I drilled out the spot welds on the newer decklid:
Did the same for the W decklid and put in in place and did some plug welding:
'59 Panel Project
rich caramadre Samba Member
Joined: August 22, 2014 Posts: 145 Location: United States
Posted: Tue Jun 11, 2019 5:56 am Post subject: Re: Ben's '56 Ragtop Project |
I need to do the same repair on a W decklid. Do you know what years would correctly fit as a donor? |
Posted: Tue Jun 11, 2019 6:24 am Post subject: Re: Ben's '56 Ragtop Project |
rich caramadre wrote: |
I don't know the year of the decklid that I ended up using, but there were some subtle differences that I decided I can live with. In the photo below, the red circle shows where there is an extra tang to hold the license plate light wires, the yellow arrow points to an extra little tongue/wire holder piece from the original W decklid I had to transfer, and the red arrow points to a little bulge on the newer piece I left in place that wasn't on the W:
Other than those differences, the contours and dimensions of the newer piece were the same. _________________ Ben
'59 Panel Project
Posted: Tue Jun 11, 2019 8:26 am Post subject: Re: Ben's '56 Ragtop Project |
Thanks for the detailed reply. Pretty much what I was thinking. I guess as long as the spring mount is the same I should be good. |
