420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Thu Feb 14, 2019 3:29 pm Post subject: Has Anyone Actually used the Cheap Diesel heaters? |
please only respond if you have done as the title asks. i dont need ten answers as to why i should not, tell me why i should. thanks. please refrain from telling me how much you love your super-expensive name brand heater. _________________ once you realize im not impressed we will get along just fine |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
buckswilde Samba Member
Joined: June 26, 2010 Posts: 131 Location: Lexington, KY
Posted: Thu Feb 14, 2019 4:37 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
There's someone in my local club that installed one in his beetle and really likes it. Based upon his experience I ordered one but have yet to install. Hope there are others that can provide more info and experience on their installs. If not, I'll post mine here once the install is complete. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Thu Feb 14, 2019 4:41 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
Pretty solid thread n hem in the Vanagon forum. Consensus is they aren’t bad for the price.
Edit: VWWestyman beat me too it, _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Thu Feb 14, 2019 4:42 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
since i saved a bus that has no duct system, this is my best option for the harsh winters here in Los Angeles. _________________ once you realize im not impressed we will get along just fine |
Posted: Thu Feb 14, 2019 4:44 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
i saw that but only one guy had used it, lol. the topic was derailed and 1k heaters were then discussed. I may get it and use rubber lines for the fuel. _________________ once you realize im not impressed we will get along just fine |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Thu Feb 14, 2019 5:24 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
No but you know we've talked about it several times. I still wouldn't mind just getting one. At $120, what the hell.
I think there is plenty of shit to talk about running a 35 year old one, and several of us are. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
bajajoe16 Samba Member
Joined: August 03, 2011 Posts: 88 Location: eatonville
Posted: Thu Feb 14, 2019 8:11 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
I put one of the 5K heaters in my late bay and it worked good for about a week and then it started throwing a code and not starting I guess the glow plug was shorting out |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu Feb 14, 2019 8:52 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
Have a 5KW installed in my '75, have run 6-7 gallons of kerosene (burns cleaner than diesel) through it by this point.
Had a glow plug failure early on, which is a known issue, but the $18 Chinese replacement plug has been working just fine and for longer than the original. Had to replace the exhaust pipe because I did a stupid and didn't watch where the jackstand was going to contact the chassis. Oh, and it showed me that my aux battery was no good and needed replacement -- thought it was fine but the only thing connected were the LED interior lights, no load of any real substance.
It works just fine and I'm totally happy with it. Recently picked up another 5KW to mount permanently in the garage for the primary heat out there instead of the Mr. Heater I'm always bumping in to... |
Posted: Fri Feb 15, 2019 9:39 am Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
thanks for the input, sounds like there may be a few hiccups but over all a good product. im just looking to warm the bus on those frigid LA mornings and cool spring and late summer nights. _________________ once you realize im not impressed we will get along just fine |
dstimm Samba Member
Joined: June 29, 2018 Posts: 153 Location: Encinitas, CA
Posted: Fri Feb 15, 2019 9:58 am Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
I have been reading up on these heaters a lot, and watching youtube videos and they seem to be very well built. Obviously they copied the bigger more expensive heaters that were made, but as anything once it gets to china we see imitations, some times good (like these) and sometimes bad (like the Chinese parts we have seen). What I have noticed about the different models is there is an LCD version and a physical switch version. The LCD as many Chinese cheep electronics looks like it has one of the worst user experiences out there, it is confusing, and touchy, while the physical switch seems like it is durable and easier to use (with less functionality).
I have also seen many different ways of installation. Personally I don't want to give up any room inside my Westy (nor do I want to drill large holes), so I would go for an under the bus installation that taps into the existing heat piping.
Since there is heater ducts in the front, and in the back flooring I think this would be adequate. I would however try to run the controls up into the cabin so I could control it.
I have also been thinking about the propane Propex options because it would be nice to use a Westy propane tank since it is more durable than having an additional tank of diesel (and much easier to refill). Vanagon owners that have diesel tanks already have a big advantage here.
Just be sure to do regular maintenance to what ever heater you get. They can get filled with soot (running them on low) and the glow plugs can go bad. Luckily all the ones I have seen are very easy to take apart to clean and if worst comes to worst you can buy a replacement for very little money. _________________ 1979 Sage Green California Westy. |
Posted: Fri Feb 15, 2019 10:27 am Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
It would be very easy to mount one underneath the bus and have, say, the rear heat outlet be the cold air return, and outlet between the front seats be the hot air vent or vice versa. (With a Westy, I'd have the heat come from the front for sure, because then the heat isn't blocked by the bed.) I thought about doing that, but decided I wanted both of those to have hot air going to them, for a bit more even distribution and also to help if one happens to have luggage or something over it, so it isn't just blocked.
I put mine together so that the cold air return comes from the very back of the space under the front passenger seat. So I did drill a hole, but it is basically invisible.
A couple of the guys in that Vanagon thread are saying they're going to remove the propex heaters in favor of the cheap diesel, because they think finding places to refill the propane tank is a pain, and you can't really tell how much you have. It shouldn't be very difficult to mount a small diesel tank someplace in the Bus or engine compartment. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Feb 15, 2019 1:30 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
dstimm wrote: |
Just be sure to do regular maintenance to what ever heater you get. They can get filled with soot (running them on low) and the glow plugs can go bad. Luckily all the ones I have seen are very easy to take apart to clean and if worst comes to worst you can buy a replacement for very little money. |
Ill let you check out my 77 Westy mit Eberspacher. Maybe we can convince you to mount it where it was meant in the engine bay. _________________
t3kg wrote: |
1964 1500 S
dstimm Samba Member
Posted: Fri Feb 15, 2019 2:53 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
notchboy wrote: |
Ill let you check out my 77 Westy mit Eberspacher. Maybe we can convince you to mount it where it was meant in the engine bay. |
You have the best toys! Where did you get the Eberspacher heater? _________________ 1979 Sage Green California Westy. |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Feb 15, 2019 3:10 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
which one? he has 20 of them |
Posted: Fri Feb 15, 2019 3:42 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
alman72 wrote: |
I have a problem. _________________
t3kg wrote: |
1964 1500 S
dstimm Samba Member
Posted: Fri Feb 15, 2019 3:54 pm Post subject: Re: Has Anyone Actually used the Cheap Diesel heaters? |
notchboy wrote: |
dstimm wrote: |
notchboy wrote: |
You have the best toys! Where did you get the Eberspacher heater? |
See round these parts, I am Mr. Eberspacher Heater
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Drool... _________________ 1979 Sage Green California Westy. |
