ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Feb 15, 2019 2:13 am Post subject: Crazy Ass Ford Stuff |
I heard that Ford Triton V8 that you can't get the spark plugs out, but I never knew that they also blew out their spark plugs out the holes too.
Check out this crazy ass repair
Part 1
Part 2
_________________ Good Luck
Al |
cbeck Samba Member
Posted: Fri Feb 15, 2019 5:05 am Post subject: Re: Crazy Ass Ford Stuff |
I just unloaded my 99 f250 w/a 2v 5.4. 5 sparkplug inserts, wore out chain guides, and at least 1 lash adjuster ticking when under 2k rpm. Used it to charge camper battery at remote deer camp for 3 hrs every evening. Past fall developed a miss w/ no codes. Finally unloaded it after 14 years and only added 50k to the odometer. Picked up a clean 7.3, couldn't be happier. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
typ914 Samba Member
Joined: October 19, 2012 Posts: 230 Location: Atlanta, Ga
Posted: Fri Feb 15, 2019 6:27 am Post subject: Re: Crazy Ass Ford Stuff |
Blowing out spark plugs is a problem for Ford triton V8 and V10. I have a 2000 F250 with the V10 but have only had one spark plug blow out about 5 years ago, knock on wood. The truck now has 375,000 miles on it. I finally retired it last year. Best truck ever made. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12736 Location: Western Canada
Posted: Sat Feb 16, 2019 2:01 am Post subject: Re: Crazy Ass Ford Stuff |
I cannot begin to imagine the cost of the fuel it would take to put 375K miles on a Ford V10!
Back when they first came out my company gave me one to drive. I had problems getting to the worksite and back on one tank. I had to refill it every day. It had about 2.5 hours range between refills! The next truck was a Duramax that did the same trip 4 times on the same tank.
And the Chevy was a dually to boot! |
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Sat Feb 16, 2019 2:12 am Post subject: Re: Crazy Ass Ford Stuff |
The local dealer has a tech whose only job is to remove & install the bodies of any truck that comes in for repair, the chassis is then sent downline for the other techs to do whatever repair is necessary to the driveline. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
typ914 Samba Member
Posted: Sat Feb 16, 2019 5:19 am Post subject: Re: Crazy Ass Ford Stuff |
My F250 with V10, crew cab, long bed, with a single axle. It averaged about 11mpg. No mater what it was doing or where it was going. I pulled a 26 foot bayliner, several times, from Atlanta to Tampa. Didn't feel the boat at all during the trips. Averaged 11mpg with or without the boat. On our first trip going down I75S my brother was driving and I was asleep. I woke up when he hollard "OH S@$T". I yelled back WTF. He said we're doing 90mph! To which I said slow down. My F250 was pulling a 26ft bayliner at 90mph on the interstate. Everything was running so smooth my brother didn't realize he was going so fast. I later did the same thing when we switched. Didn't feel the load at all and still averaged 11mpg. Best truck ever built. Its retired right now but I still use it for heavy loads or oversized loads. |
oprn Samba Member
Posted: Sat Feb 16, 2019 8:43 am Post subject: Re: Crazy Ass Ford Stuff |
That is 34,090 gallons of gas. Our gas price today is $4.396/us gal so that comes to $149,859.64 in my world! Wow eh?
Yes that is what the truck they gave me got for mileage too. |
cbeck Samba Member
Posted: Sat Feb 16, 2019 8:30 pm Post subject: Re: Crazy Ass Ford Stuff |
My 5.4 got 11.25hwy, 8.5 towing anything over 2k. My 7.3 is getting 13.5 on this last tank. All around town, no highway, half of it in 4wd. _________________ My cut in half and rebuild thread
oprn Samba Member
Posted: Sat Feb 16, 2019 10:36 pm Post subject: Re: Crazy Ass Ford Stuff |
When I was looking to replace our Chevy pickup I wanted a good towing engine with decent mileage. I chose a Dodge because of the reputation of the Cummins. It gets 18mpg empty and 16.7 loaded to the nines through the mountains pulling a 24' cargo trailer. Rarely ever have to drop a gear to crest the hills even loaded. Burns no oil and starts without being plugged in at -25.
So - did I win? In 470K, two complete $2500 front end jobs, one $2100 set of brakes, a $1100 broken rear spring, a set of $5000 injectors, multiple electrical issues, a rear door that is permanently locked and a $500 parking brake that will never work later - nope!
These modern monster 4X4 trucks are the biggest money pit ever invented. They are hugely expensive no matter which way you go! |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sun Feb 17, 2019 6:49 am Post subject: Re: Crazy Ass Ford Stuff |
oprn wrote: |
470,000 miles? $2100 brake job? $5000 injectors? Wow. |
oprn Samba Member
Posted: Sun Feb 17, 2019 7:29 am Post subject: Re: Crazy Ass Ford Stuff |
I don't know what shops charge where you live but here at $120 to $150 door rate anything more than an oil change is going to run you a grand. That $5000 injector change by the way included a 1 hour tow bill to the shop as the truck would not start. |
typ914 Samba Member
Posted: Sun Feb 17, 2019 7:48 am Post subject: Re: Crazy Ass Ford Stuff |
When I first purchased my F250 in 2000/2001 gas prices were still close to a $1/gal. Ga had some of the lowest gas prices in the country at the time. Then the politicians figured it out and increased the gas tax to put Ga closer to the national average. Gas now is just over $2/gal. Every once in a while you Can catch it under $2.
As for diesels my nephew has a Ford diesel and he is also a heavy equipment mechanic. According to him nothing is cheap on any kind of diesel. |
typ914 Samba Member
Posted: Sun Feb 17, 2019 7:53 am Post subject: Re: Crazy Ass Ford Stuff |
I retired the F250 and purchased a used 2018 ford transit for a service truck. So far so good. However I don't expect to see a site like the samba for my ford transit van in 20 or so years.
It's a 5 window panel van. Should I consider it a bay window body style? |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun Feb 17, 2019 8:43 am Post subject: Re: Crazy Ass Ford Stuff |
Dwayne1m wrote: |
oprn wrote: |
I just did brakes for a client with a 2016...yes a '16 Ferd F350 with 18k miles on it. what an epic piece of shit:
this is after taking a sledge to the rotor
this truck got new calipers too because the steel shield on the phenolic pistons rotted...can't get them separate
and on top of all of that...I ended up sand blasting the hub extenders so I could get this thing back together
total bill was a hair under 2K parts and labor. again, this was a 3 year old truck with under 20k miles on it. the dealer replaced a p/s hose under warranty because it rotted. dealer quoted about 2900 for brakes due to rust. I had almost 3 hours PER SIDE getting all the parts off, cleaned and reassembled...train wreck job.
I wouldn't buy ANY domestic truck...especially a ford. never in my life have I seen such shitty materials used on domestic products.
the owner of the truck is a freak...he washes his fleet religiously and uses fluid film. it's gotten to the point where he almost can't afford to stay in business because his trucks rot out in 4-5 years. sad.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Zeen Samba Member
Joined: July 24, 2004 Posts: 1308 Location: The Sunny Part of Michigan
Posted: Sun Feb 17, 2019 9:22 am Post subject: Re: Crazy Ass Ford Stuff |
skills@eurocarsplus wrote: |
I wouldn't buy ANY domestic truck...especially a ford. never in my life have I seen such shitty materials used on domestic products. |
Which foreign truck with a 5000# payload capacity uses better materials? _________________ The consequences of your decisions should not be confused with fate. |
Posted: Sun Feb 17, 2019 11:09 am Post subject: Re: Crazy Ass Ford Stuff |
Zeen wrote: |
Which foreign truck with a 5000# payload capacity uses better materials? |
I would buy an Isuzu NPR cab and chassis before I bought any domestic toilet..but to your point they are all overpriced garbage these days.
the guy who owns that truck I pictured had a GMC of the same vintage and it is nowhere near as crispy.
the only truck in their fleet that isn't an epic rot box is a 2008 F250 that they drove off the dealer lot and straight to ziebart for a spray of whatever poo they use.
forgot to mention...that 350 is on its SECOND set of exhaust manifolds already. every ford they own has had multiple sets of manifolds.
I swear they stripped the nickel out of the steel. I have never seen steel that new "delaminate" like that...it's scary. all of their ford engine blocks look like you took a bag of chips and smashed it with a mallet...flakey delaminating messes
if you look in my first pic, look behind the rotor to the front axle. when this truck was brand new they had the chassis painted with some type of rust preventing paint....it's coming off in sheets. sad....I think the rust is built into the steel these days _________________
Jake Raby wrote: |
Brian wrote: |
cbeck Samba Member
Posted: Sun Feb 17, 2019 11:27 am Post subject: Re: Crazy Ass Ford Stuff |
2017 tundra 10,500#. 2017 f350 32,000# w/goose neck. I like toyota, but.... Also seems like the term bulletproofed is thrown around more than freeway flier. The early 6.7 also has a problem with the injectors being ejected, ruining the hood. Hoods are stacked like cord wood outside the shop my oldest works at. _________________ My cut in half and rebuild thread
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sun Feb 17, 2019 12:26 pm Post subject: Re: Crazy Ass Ford Stuff |
So , it would seem to me more prudent to buy an 84 k20 from az/nm than a 2001 any make truck _________________ "Albatross"! |
Posted: Sun Feb 17, 2019 12:43 pm Post subject: Re: Crazy Ass Ford Stuff |
calvinater wrote: |
So , it would seem to me more prudent to buy an 84 k20 from az/nm than a 2001 any make truck |
yes. if I needed to haul some big stuff, I would go that route. LS swap, a/c and you can have a cool truck that won't snap in half when you wash it.
or, buy a new truck and cash it in every 3-4 years I guess. I don't know the real answer anymore. I keep telling my wife that it almost isn't worth it to buy a car you plan to keep for more than a few years....as in when factory warranty is up get ready to cash out _________________
Jake Raby wrote: |
Brian wrote: |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
