ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Fri Feb 15, 2019 9:08 pm Post subject: Hook up box location measurement |
Hey all-
It has been a couple of years since I converted my van from a Weekender to a Camper and I held off on doing hook up boxes. I wanted to see if I would be happy without them, and I also wanted to wait until I had saved up for paint before cutting into the van. I have decided that I do indeed want them (120v, solar and water fill) and paint is just around the corner. I would like to install them in the stock location, but haven't found any measurements (I swear, I used the search!). If anyone has those measurements, or wouldn't mind taking some, I would greatly appreciate the info! _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Paulbeard Samba Member
Posted: Fri Feb 15, 2019 9:38 pm Post subject: Re: Hook up box location measurement |
what do you need? measurements from the top/bottom and from the edge of the door?
I can get them tomorrow if no one else has them. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Fri Feb 15, 2019 9:53 pm Post subject: Re: Hook up box location measurement |
The easiest might just be from the bottom of the belt line to the top of the boxes, and from the seam to the right of the boxes to the vertical edge of the rightmost box. I know how they are spaced from there thanks to the GoWesty 4th hookup box install video. I appreciate the help! _________________ 1986 Westy Weekender
Now a full camper
Westified Samba Member
Posted: Fri Feb 15, 2019 9:56 pm Post subject: Re: Hook up box location measurement |
Hope this helps
And this
_________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sat Feb 16, 2019 9:43 am Post subject: Re: Hook up box location measurement |
Many thanks to all! Now I just have to make sure I don't screw up this cut... _________________ 1986 Westy Weekender
Now a full camper
cmayna Samba Member
Joined: August 18, 2014 Posts: 1143 Location: SF Bay area, CA
Posted: Sun Feb 17, 2019 9:40 am Post subject: Re: Hook up box location measurement |
Don't know if the '90 boxes are in the same exact location as your rig but I can always come up to SF and let you measure away. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
