derRHDmeister Samba Member
Posted: Sun Feb 17, 2019 8:05 am Post subject: VW cyclone header off a 36hp |
I found this 36hp smoker motor with this header attached, & ended up selling the motor and keeping the header. I see it says VWc1 on one of cast ends. Want to make sure it is correct for the 36hp or probably a 40hp?
Anyone have old cyclone catalog or brochure? Want to look into it
_________________ Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote: |
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt. |
Check us out @
Instagram: DeafVolks & BarndoorBuggy |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
Posted: Sun Feb 17, 2019 12:23 pm Post subject: Re: VW cyclone header off a 36hp |
I noticed that too but it doesn’t give much information except for other header model # and design. I’m hoping to see some sort of catalog that can signify what vwc1 model was intended for- perhaps a 36hp application or 40hp, etc
Check us out @
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Mon Feb 18, 2019 3:07 pm Post subject: Re: VW cyclone header off a 36hp |
Check the heat riser bolt hole pattern orientation. 36hp is clocked different than a 40hp/15/1600 based motor. The 36hp headers that were available from treuhaft etc had a hole on one side, with a slot on the other to accommodate both the 36hp vs 1200 40hp intakes.
Mount up a stock 36hp intake and see if the m6 holes line up. That would be quick and easy.
I have just the collector piece on my shelf the same as yours with VWC1 cast into it. it looks like 1" 3/8" primaries with a 1 1/2" outlet for the glasspack. I was goint to use it to make a custom header at some point for my 36er. _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
