Syncro Jael Samba Member
Posted: Mon Feb 18, 2019 6:59 pm Post subject: Vanagon 2wd fuel filler neck hole template??? |
Does anyone have a template for the 2wd fuel filler neck hole. It is the slotted hole like this.
Thanks way in advance.
Ron
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Mon Feb 18, 2019 7:24 pm Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
You seem to be up to something. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Tue Feb 19, 2019 7:43 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
dobryan wrote: |
Ron,
If you still need one I can pull the filler of my euro bus project and make a template to send you. Let me know. |
That would really be helpful. I’m surprised there is not one in the community available. Once I get one I will make it so.
Thanks so much.
Ron
PS. It’s for an auxiliary fuel tank to get weight off the back using RotoPax. _________________ 1987 Syncro Westfalia Hightop - NAHT
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Tue Feb 19, 2019 9:43 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
I have that section that I cut from a 2wd, will try to dig it out tonight. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17122 Location: Retired South Florida
Posted: Tue Feb 19, 2019 12:00 pm Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Funny, I thought about welding mine up, but pack ratted enough parts to have a filler ready to go if I ad an auxiliary tank some day. _________________ ☮️ |
Posted: Tue Feb 19, 2019 11:06 pm Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
The best that I can measure, the diameter of the inner circle tips are 125mm and the diameter of the largest outer circle is 133mm.
Posted: Wed Feb 20, 2019 6:52 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
syncrodoka wrote: |
Thanks again!
Ron _________________ 1987 Syncro Westfalia Hightop - NAHT
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Wed Feb 20, 2019 7:15 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
If Syncrodoka can scan the traced sketch and email that scan to me, I'll put it in cad and post. |
?Waldo? Samba Member
Posted: Wed Feb 20, 2019 8:39 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Here it is in AutoCAD scaled so the outer circle is 133mm in diameter and the inner is 125mm in diameter. You'd have to reference the prior pictures of the cutout on the van to get the rotation correct.
PM your e-mail address for a pdf that will print it out to scale. I would recommend card stock and make sure the scale for printing is set to 100%. |
Posted: Wed Feb 20, 2019 10:28 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Thanks again to all of you.
The CAD file should be in the archives for others. _________________ 1987 Syncro Westfalia Hightop - NAHT
Posted: Sun Feb 24, 2019 6:32 pm Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Thanks everyone. I have the tank installed and the template was perfect. The smallest notch goes directly at the bottom. Once you spin plastic filler housing it will be perfectly straight. _________________ 1987 Syncro Westfalia Hightop - NAHT
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Sun Feb 24, 2019 7:22 pm Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Are you using this for a diesel tank for the heater? I ask because im doing the samething using my existing 2wd fuel port on my converted syncro. I ordered a chinese plastic gas tank to play around with. Curious what youre up to Ron |
Posted: Mon Feb 25, 2019 6:32 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
candyman wrote: |
Syncro Jael wrote: |
PS. It’s for an auxiliary fuel tank to get weight off the back using RotoPax. |
_________________ Dave O
The Western Syncro build
Posted: Mon Feb 25, 2019 7:25 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
dobryan wrote: |
candyman wrote: |
I dont read so good |
Posted: Mon Feb 25, 2019 9:32 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
candyman wrote: |
I’m planning to fabricate another aluminum tank to store fuel for the diesel heater on the drivers side. So I will be doing this again. _________________ 1987 Syncro Westfalia Hightop - NAHT
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Mon Feb 25, 2019 9:35 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
so 3 gas caps!? _________________ Brandon
Instagram @joannthevan |
Posted: Mon Feb 25, 2019 9:40 am Post subject: Re: Vanagon 2wd fuel filler neck hole template??? |
Yes, (3)three. Everyone is coming up with different ideas for heater fuel storage. I have a 2.5 gal tank that replaced my propane saddle tank. So I’m planning to make a System that’s easy to fill and use. _________________ 1987 Syncro Westfalia Hightop - NAHT
