Kadrons "popping" when I hit the throttle...why?
fifthcenturycheese Premium Member
fifthcenturycheese is offline
PostPosted: Wed Feb 20, 2019 7:35 pm    Post subject: Kadrons "popping" when I hit the throttle...why? Reply with quote
The motor:
1776
Dual Kadrons (new) Berg linkage
Pertronix flamethrower SVDA + flamethrower coil
110 engle cam
8:1 compression
Timing 7.5 initial
91 octane
pump shots on both kadrons measure to .6 cc
idle jets 55 , mains 135's
carbs synched, butterflies match...
Installed vacuum port on driver side kadron and changed out German 009 with Pertronix flamethrower. Very pleased with results so far, stumble has smoothed out, but when throttle is punched I get a pop from both sides. Not everytime, but a couple times. I feel like I am real close to having it dialed in... Any suggestions on what is happening here? Thanks, Mike
Mikedrevguy
Mikedrevguy is offline
PostPosted: Wed Feb 20, 2019 7:50 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
How are they synced?
74 1303 (RevBug): plan for German Look
74 914
76 914 with 2260
79 VW Iltis
69 Baja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Wed Feb 20, 2019 7:59 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
What's the fuel pressure?
https://www.amazon.com/Complete-Kadron-Manual-Fran...adron+book
76 Beetle sedan
vwracerdave
vwracerdave is offline
PostPosted: Wed Feb 20, 2019 8:07 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
With 8.0 compression ratio I'd try some 87 octane gas.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
nsracing
nsracing is offline
PostPosted: Wed Feb 20, 2019 8:14 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Are you sure the distributor is advancing properly?
Also, you might want to add more squirt --maybe you need to adjust the fuel advance.
yes, check the synchronization on the carbs.
The American dream is alive for those unversed in the ideology of victimhood. - Thomas Sowell
PostPosted: Wed Feb 20, 2019 8:32 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Fuel pressure is around or slightly above 1.5 lbs.
modok
modok is offline
PostPosted: Wed Feb 20, 2019 9:30 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Appears you haven't installed the airfiter or........ the rest of the car yet.
Won't even be able to get it warmed up with no load on the engine.
oprn
oprn is offline
PostPosted: Wed Feb 20, 2019 10:00 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Excellent point!
Also make sure you have the thermostat and flaps installed and working correctly. My Kadrons would not stop popping and farting at part throttle until the engine was fully warmed up - as in - several miles at highway speed. Then without the thermostat they would start popping again after 4 or 5 sets of lights back in town and the engine was too cool again.
Once I added the thermostat there was no more popping in town.
PostPosted: Wed Feb 20, 2019 11:16 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Modok and Oprn:
Took the engine out to do some adjustments, but I guess I am at the point where I can now "install the rest of the car"...I'm still on my learning curve. Thanks for the input. You guys are absolutely correct, the engine has not been getting hot enough, thermostat is installed and works perfectly.
Will install and post results.
Thanks, Mike
andk5591 Premium Member
andk5591 is offline
PostPosted: Thu Feb 21, 2019 6:17 am    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Yeah - it should run a bit crappy until fully warmed up unless you have it jetted too fat.
D-Dubya Manx clone - 63 Short pan,1914.
Max - 73 standard Beetle hearse project
There's more, but not keeping them...
andk5591 is offline
PostPosted: Thu Feb 21, 2019 6:18 am    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Alstrup
Alstrup is offline
PostPosted: Thu Feb 21, 2019 8:30 am    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Yeah, not enough cr and not enough timing at idle.
The timing is easy to change. Set it up for 10-12 degrees at idle and limit the advance to 30 max 32 without vacum. That'll help some. The rest is jetting.
PostPosted: Sun Mar 31, 2019 10:57 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
So, the engine went back in the car and I am extremely pleased with the results! The Pertronix 034 svda cured the problem. The engine needs to warm up for the Kadrons to operate efficiently. The svda really smoothed out the performance of the engine over the German 009. Opening the "already provided" vacuum port was very easy to do without having to send the carburetor off somewhere for a while and at no added expense! Just need a black distributor cap!
PostPosted: Mon Apr 01, 2019 5:45 pm    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
With black cap!
earthquake
earthquake is offline
PostPosted: Thu Apr 04, 2019 1:12 am    Post subject: Re: Kadrons "popping" when I hit the throttle...why? Reply with quote
Do the discharge tubes for the accelerator pump squirt straight down the vent?
Some times they need to be tweaked over a bit because the squirt on top of the Aux vent and just kinda splash fuel allover when you open the throttle.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
