AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Sat Feb 23, 2019 5:55 am Post subject: Extending my wireless signal without 110 or an inverter. |
Hows this done?
I use my weekender as an office. I park near starbux and public libraries but have to be up against the front door to get a decent signal. Ive seen antennas for this type of thing but cant comprehend how they work. Mind you I am not a tech guy in any way. My 14 year old has surpassed me on the tech front like Usane Bolt passing a man with a walker.
Is it possible to pull public wifi from these joints while 100 yards away from the building. My phone will connect to my comp but thats an expensive option in regards to my data plan being quite limited.
wha'dayasay?
Oh yeah. Gracias. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Sat Feb 23, 2019 7:04 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
you need a USB wifi adapter that has an external antenna port and then add a high gain directional antenna. you'll need to aim the antenna at the establishment providing wifi, it should be outside the van, and up high as possible.
$200 in parts should get you on your way for the USB adapter, cable adapters, cable, and directional antenna. the directional antennas usually come with a pole mount and a 3/4" aluminum rain fly pole works well.
if have the 4G/LTE dongle to supply your wifi, if it has an external antenna adapter the same parts other than the USB adapter are used except you 'sweep' the area for strongest signal, locating on a cell tower.
you may also use an omnidirectional antenna on a suction or mag mount, again best to use outside the van. you'll get less gain with an omni but not have aim it at the establishment. _________________ -dan
www.thefixitworkshop.com |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Sat Feb 23, 2019 7:34 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Set up you phone as a mobile hot spot. Ask your 14 year old how. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Abscate Samba Member
Posted: Sat Feb 23, 2019 8:00 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Doesn’t have data plan to cover, discussed in post
We use a WiFi’s antenna to beam cable around four houses and split bill, even though it’s Communism
About $200 for hardware. _________________ .ssS! |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Sat Feb 23, 2019 8:18 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
I have a vertical WiFi antenna out the top of my van, it gets a great signal. It is a 5dBi gain Pulse NMO5E2400B and fits into a NMO standard hole. The coax terminates in a RP-SMA Female port. I have a tiny Ubiquity airGateway in the ceiling that runs in Bridge mode on 12v. It has an ethernet cable running into my computer.
That may be overkill for your needs. A simple USB WiFi dongle may suffice. I have one attached by a magnet glued to the window. I only resort to the big unit when I am some distance away.
The sad fact is, wireless data plans have become so common that mobile WiFoi technology has stagnated. I don’t think there has been any good new products for 5 years. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sat Feb 23, 2019 8:51 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
and just putting the USB wifi dongle on the end of a 6' USB M-F extension cable can do wonders... it gets the antenna away from the RF of the computer as well as allows you to position it higher. _________________ -dan
silversync Samba Member
Joined: September 01, 2005 Posts: 185 Location: San Pasqual Valley, CA
Posted: Sat Feb 23, 2019 11:07 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
I appreciate the words of advice. I’m too cheap to up my phone data. I already pay way too much for my phone. If you have spent an hour in one of these joints you know there are lots of non paying surfers in there. Now the library has little to sell. Either way I’m more comfy in the van doing estimates listening to my tunes.
Thanks again. Have a great weekend. Stay warm.
Jay. _________________ Support Small Business.
Previously
and a 67 bug. |
Paulbeard Samba Member
Posted: Sat Feb 23, 2019 11:40 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
OT for this forum but maybe there are cheaper phone options… I only have cell service (no land line/home phone) and pay less than $50/month, well under $40 for the past couple of months. It would go up if I was on the road but if it doubled, I will be paying less than when I was with one of the big telcos… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Sat Feb 23, 2019 12:07 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
My phone is through my business and serves 6 phones. The change would be a big pain as well as my marketing is related and attached.
I’m looking at a unidirectional antenna. _________________ Support Small Business.
Previously
and a 67 bug. |
jimf909 Samba Member
Posted: Sat Feb 23, 2019 12:12 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
AZ Landshaper wrote: |
Jay. |
Um, this is a Vanagon forum so that's assumed.
I'm a huge fan of public libraries. Especially a Carnegie library if you have one in your area. I've got one where I get the WiFi outside in the parking spaces outside. Go into the library, check out some new-to-you CDs, return to the van and listen to music while you work. Total cost: $0.00.
Carnegie libraries...
https://en.m.wikipedia.org/wiki/Carnegie_library _________________ - Jim
Abscate wrote: |
beanjammin Samba Member
Joined: February 24, 2019 Posts: 1 Location: Vancouver
Posted: Sun Feb 24, 2019 6:00 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Long time lurker... 1st time poster. I'm a geek, this topic scratched my itch enough to finally create an account.
DanHoug's suggestion of using a USB wifi adaptor and a directional antenna is definitely the easiest option and can be done for much less than $200. Searching Amazon for "wifi directional antenna" turned up this for $30CAD and it looks like it includes everything you'll need (antenna, usb wifi adaptor, usb cable). The one linked to wouldn't be stealth, and you'd probably want to come up with a way to easily mount/remove it as needed rather than keep it up. Around here flags like this litter the streets shortly after the local team bows out of the playoffs and look like they'd work well for an easily set-up/removed window antenna mount.
If you search for "wifi directional antenna" you'll see there are many other options, just be sure you get a USB wifi adaptor that plugs into the antenna and a usb cable that goes from the adaptor to your laptop and you should be good to go. The USB cable can be up to 6m long so you should be able to get your antenna pointing where you need it while still lounging in your VW.
I have been planning to do a somewhat more ambitious variation on this that you might want to consider. By the sounds of it you'd need to lean on your 14 year old, but if s/he's up to it it might make a good project. The basic idea is to turn the VW into a wifi hotspot / media server that you can connect multiple computers/phones/etc to and when you're in the range of a wifi access point you would have internet access and when you're not you'll still have access to the local media files.
It would use the same directional antenna set-up as above plus a Raspberry Pi 3 Model B+ ($35USD), a 12V to 5V DC power adaptor ($10CAD) a microSD card (price varies with size) and optionally a tv/computer monitor, keyboard and mouse.
The Raspberry Pi is basically the innards from a low-end smart phone and is used to run Open Source Media Centre, which is based on Linux. OSMC provides the kodi media centre (mp3s, videos, etc.) and with a little extra configuration using the instructions here will create a wifi hotspot using the Raspberry Pi's built-in wifi adaptor. It can be set up to automatically connect to open wifi access points so that whenever you are near one you will automatically get an internet connection.
The Raspberry Pi draws between 2.5 and 12W so shouldn't kill the battery too quickly. There is a power related gotcha in that the Raspberry Pi can't be powered off without first being properly shutdown or you risk corrupting the filesystem. I haven't tried it yet, but something like the solution here or here ought to work without drawing any power when the key is off or having to manually shut it down.
Maybe it's finally time for me to get going on this... thanks for getting me thinking about it again (and finally creating an account on thesamba).
Cheers,
- Ben |
Posted: Sun Feb 24, 2019 6:12 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Hey Man
Great 1st post. Very helpful contribution to the site (or at least to my post which is as usual off topic).
Thanks for taking the time to ring in and answer my Q.
I appreciate the links. This is a foreign language to me but I knew it was possible. You have made assembling the parts and pieces a lot easier on me.
Have a great night.
Jay _________________ Support Small Business.
Previously
and a 67 bug. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Feb 25, 2019 9:08 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Abscate wrote: |
About $200 for hardware. |
"Communism"? Sounds like plain old theft to me. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Mon Feb 25, 2019 10:42 am Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Jake de Villiers wrote: |
Abscate wrote: |
"Communism"? Sounds like plain old theft to me. |
Theft is when you have ONE provider in your town and no other options. Hold on, that's a monopoly! And if you only get internet, they will charge you more than if you get the internet and cable TV. I get package deal discounts, but charge more money? WTF?
Anyways, with the title, I was thinking it was about extending a Cellular signal. W/O derailing this thread, is an external antenna the best option for such? If so, I can start a new thread (after a search). _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Mon Feb 25, 2019 12:13 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Abscate wrote: |
Feel free to research the different classes of internet access where sharing is allowed on your time.
Watch out for that theft accusation - it bounced off my Samba shield pretty hard and elastic. _________________ .ssS! |
?Waldo? Samba Member
Posted: Mon Feb 25, 2019 12:28 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Abscate wrote: |
I don't see how that would be theft. Hacking someone's internet connection and using their bandwidth without them being knowledgeable is theft, but that isn't the case, but that isn't the case. The internet provider is being paid fully for the data connection and all people sharing the connection are sharing the cost. Seems legit to me.
Posted: Mon Feb 25, 2019 12:29 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Most TOS probibit you sharing your wifi with others. Some do not.
It is not theft, it is breach of civil contract. _________________ .ssS! |
Posted: Mon Feb 25, 2019 12:32 pm Post subject: Re: Extending my wireless signal without 110 or an inverter. |
Who are the 'others' you aren't supposed to share your wifi with? I've had friends stop by and log onto my wifi. Am I in breach? What if they park their van in my driveway and log on, breach of contract? Sounds like nonsense to me. I'm not even going to try to read the fine print... |
