TrollFromDownBelow Samba Member
Joined: January 04, 2005 Posts: 414 Location: Metro Detroit
SGKent Samba Member
Posted: Mon Feb 25, 2019 5:01 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
unless the case is really bad it should not be bored. There are only a couple places in the whole USA that still do it on T4 engines, and usually they don't need it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 25, 2019 6:00 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
SGKent wrote: |
unless the case is really bad it should not be bored. There are only a couple places in the whole USA that still do it on T4 engines, and usually they don't need it. |
Okay, thanks for the input. Still need to have it cold tanked, and most likely need the crank polished and/or ground and new main bearings.
Any machine shop suggestions would be welcomed. _________________ 1976 Westy (aka Tripod)
2.0 liter FI solid lifters
212k miles |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Feb 25, 2019 8:30 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
The last time I had a type 4 built I sent it to Adrian at Headflow Masters in Vista CA. I hear there’s a guy in NY called Suburban. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Mon Feb 25, 2019 8:48 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
TrollFromDownBelow wrote: |
SGKent wrote: |
Any machine shop suggestions would be welcomed. |
Any reputable machine shop there can put it in an aluminum washer. It may take some scrubbing too so be sure to ask the hourly rate on that. You'll probably want to consider pulling the main oil line gallery plugs and then tapping them for screw in plugs. Be sure to study up on it before diving in.
Also, any good machine shop can measure the crankshaft and send it out to polish. These crankshafts don't wear much unless they are damaged. The cases are good unless a bearing spun and the crank blued from that heat. The heads you buy new from Len Hoffman at Hoffman Automotive Machine. And the cam comes from WebCam Camshafts in Riverside CA. If the cam gear is badly worn or has a "B" after the part number then it will want to be replaced. A "C" after the gear number means it is aluminum. A "B" is magnesium and they get brittle with age. Be sure to keep it around until you find a replacement near the number it is now. There will be a small - or + number on it which is the intermesh.
If you have done this before great, if not find a mentor who has. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 25, 2019 9:08 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
SGKent wrote: |
SGKent wrote: |
If you have done this before great, if not find a mentor who has. |
Thank you. These bits of knowledge is appreciated. Engine ran great, but when I pulled it hoping to do just heads (yes, purchased from Len) and P's and C's it was determined (by Colin) that my camshaft is toast. If I have to crack the case, might as well do a full rebuild. I have bookmarked WebCam, so will purchase both cam and lifters from them. As for mentors...I have Wilson's book and forums like this.
Cheers,
Mike _________________ 1976 Westy (aka Tripod)
212k miles |
SGKent Samba Member
Posted: Mon Feb 25, 2019 9:17 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
SGKent wrote: |
SGKent wrote: |
Cheers,
Mike |
Colin wrote me yesterday that he is back on the road again so you might even consider trying to time the install when he is in Detroit. There is a place called RecycledJack in Auburn Hills MI. You might ask them who they use for washing blocks and machine work. You should have the rods, both big and small end, checked 360 degrees for roundness to be sure they are still in spec. Make sure a good shop does it because a shop that doesn't know what to really do can make matters worse. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Feb 26, 2019 5:17 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Recycled Jacks brought me back to the early marriage-dirt poor 1970-80s when he helped me keep my Bus and Rabbit(s) on the road for cheap.
Hope he still doing well, sure to be retired by now _________________ .ssS! |
Hoody Samba Member
Posted: Tue Feb 26, 2019 6:23 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Ummmm you may want to check his feedback before you even attemp to deal with that guy. |
danfromsyr Samba Member
Posted: Tue Feb 26, 2019 7:02 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Still around and a Samba advertiser too at times.
I used to get their paper catalogs.
http://recycledjack.com/
Abscate wrote: |
Hope he still doing well, sure to be retired by now |
Abscate wrote: |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Tue Feb 26, 2019 8:52 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Quote: |
I hear there’s a guy in NY called Suburban. |
Gary Leblanc ran Suburban Engine Exchange out of Waltham, Massachusetts. He was Boston Bob's subordinate for years. He did my Type IV 3 years ago, I love it. But, his advertisement here is gone and his website has been down for a couple of years. I think he's done. _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Feb 26, 2019 8:54 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Hoody wrote: |
I found nothing on the guy |
Hoody Samba Member
Posted: Tue Feb 26, 2019 11:47 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Search realrecycledjack on here. |
veg-head Samba Member
Joined: June 17, 2014 Posts: 108 Location: Metro Detroit
Posted: Tue Feb 26, 2019 12:14 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Try looking up Norris Racing out of Milford. _________________ 1972 Bus Camper :motor 74 2.0l
1974 Thing 1915 cc
Metro Detroit, Michigan |
Posted: Tue Feb 26, 2019 5:02 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Hoody wrote: |
ah I didn't know it was the "real' jack
is that like the "real" ghostbusters? |
Posted: Tue Feb 26, 2019 8:54 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
I'm truly going off of memory here...but if it serves me well, believe recycled Jack was one of the original owners of Recycled Bugs....then they got sued by VOWA and renamed themselves The Parts Place.
Regardless, appreciate all of the responses, gives me something to go on. _________________ 1976 Westy (aka Tripod)
212k miles |
Posted: Wed Feb 27, 2019 7:52 am Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
how about MOFOCO?
I see they're in Wisconsin, but they do T-IV motor.
https://www.mofoco.com/category/Type_4_Longblocks/c163 _________________
Abscate wrote: |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Feb 28, 2019 1:07 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
I have not gone very deep yet, but these seem like some kick ass guys. (leakoil) |
Hoody Samba Member
Posted: Fri Mar 01, 2019 3:23 pm Post subject: Re: Type IV machine shop in Southeast MI or Northern OH |
Bill Webner is the best! He doesn’t build a lot of engine anymore as far as I know. Mainly interiors. But he knows a lot of people. Rich Sedoris in You gstown is an amazing engine builder. |
