Okrasa 5.5mm or 5mm valve stems
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Fri Mar 01, 2019 6:13 pm    Post subject: Okrasa 5.5mm or 5mm valve stems Reply with quote
Ok folks what are your thoughts about 5.5mm or 5mm valve stems ...ive got an okrasa and a Friend of a friend said he can machine the stock valve stems to 5.5mm or even 5mm's ...anybody think I would have any problems with such a small valve stems...
Alstrup
Alstrup is offline
PostPosted: Sat Mar 02, 2019 3:21 am    Post subject: Re: Okrasa 5.5mm or 5mm valve stems Reply with quote
Sure you can. But why. Unless you want to go extreme racing you will only be creating problems for yourself and make the valves live significantly shorter.
