Murt Samba Member
Joined: October 01, 2017 Posts: 301 Location: Suffolk, England
Posted: Tue Jun 08, 2021 9:53 pm Post subject: Re: My 1776 is coming together |
Cheers @Teeroy
She’s back from paint hopefully on Friday, when I’m back in the workshop, I’ll get some decent photos of my set up, and post up for some further advice
Murt _________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
Murt Samba Member
Posted: Sat Jun 12, 2021 5:24 am Post subject: Re: My 1776 is coming together |
So, it’s probably about a week away from trying her out on the road with the new Engine in 🤩 It’s Glass back in this week, followed by Engine, and interior soundproofing. I ditched the rear tarboard and will run just painted. I had bought a new tarboard, it was the Empi one, and let’s say I wasn’t bowled over by it 😂😂
I’ll definitely post up some photos of the cooling tinware, and hopefully a video of the Engine running 😂
Murt Samba Member
Posted: Thu Jun 17, 2021 9:30 am Post subject: Re: My 1776 is coming together |
So
I’ve had to work long hours this week at the Plant 😩 and haven’t been able to get over to the workshop at all. I’m really hoping to be back on the road by next weekend, as we have been invited to my wife’s goddaughters wedding, and said we’re coming in the Beetle. It’s only 35 miles away, and should be a nice proving run ?
Just got in, and stoked to have a mail from my buddy Steve to say he’s had some time spare today, and decided to refit the engine.
This is what he said
Hi Dave
Started getting it all together, then had to pull it all out 🙈🤪
Who would’ve thought that putting a washer behind the engine to gearbox bolts x4.. to spread the load and by giving it half turn extra to make sure they’re good and tight would stop the engine turning over!!
Needless to say it’s a fine line between rendering a gearbox useless and having the desired clearance for the new flywheel
Also took the opportunity to modify the fibreglass rear engine to bulkhead tin so it can’t rub the new paint of the bulkhead and a little extra clearance to the engine as it was trying to fold in toward the box when tightened up, only little bits I guess, but it all adds up.
No one wants rubbing, and extra vibrations and strain on the starter motor = not starting when required… like outside a wedding when one needs to look coolest 👍
Just about to put the engine back in for the third time, and hopefully the last.. thank frick for the rear end removability
Steve
Murt Samba Member
Posted: Thu Jun 17, 2021 11:05 am Post subject: Re: My 1776 is coming together |
Coming together now 😉 can’t wait to fire her up again this weekend 😬
I’d like to know what you guys think 🤔 regarding running in the engine ? Oil changes/intervals etc ? _________________ 1966 VW Beetle ‘Jules’
Murt Samba Member
Posted: Fri Jun 18, 2021 10:48 pm Post subject: Re: My 1776 is coming together |
Very close to running now, some more to do tomorrow, but nearly there at last.
I know it’s not to everyone’s taste, but I love my Beetle, and just want to drive her again, as I said earlier, would appreciate advice on a running in procedure? as this engine has only been bench tested, and ran for 10 minutes on the car before the rear end mods were done.
VW AS 41 case
Bergman 69mm c/w VW crank kit
VW 311 rods
Engle 110 cam kit
Barrel/Piston kit 90.5/1776cc MAHLE
Mofoco 042 heads 40x35.5
Full flowed Schadek 26mm oil pump kit
Dual Dellorto 40 mm carbs with CB manifolds and Vintage speed linkage
Bergmann Porsche fan kit
No Heat
Murt Samba Member
Posted: Thu Jul 15, 2021 2:04 am Post subject: Re: My 1776 is coming together |
https://www.youtube.com/watch?v=Xe2NHMkf_h4
Engine Running now, few more little jobs to do, and then run her in _________________ 1966 VW Beetle ‘Jules’
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Jul 15, 2021 7:43 am Post subject: Re: My 1776 is coming together |
Awesome work, the engine compartment is very clean and simple.
It may be the picture, but check your pushrod tube seals, when I zoom in it looks like they are cracking...hopefully just the photo |
Murt Samba Member
Posted: Mon Aug 09, 2021 10:47 am Post subject: Re: My 1776 is coming together |
OK
Sled tins etc fitted, pushrod seals are good and
100miles done, and about to change Oil again 😀 I’ve just fitted new LED rear lights from Chip Birk over in Utah, had them mailed to a friend who works at the same plant as me over here, and he brought them back over from New Jersey 😂 they really make a difference in my opinion, plus I’ve also added an extra stop light as well 😉
Generally I’m really pleased with her, she runs and ticks over sweet, but, I’m a bit concerned that she’s not breathing properly ? I’m thinking about a solution to this, and wanted some options on breather kits ? What do you guys recommend ? I’m also going to fit Stand off brackets, sourced here in the UK.
https://www.youtube.com/watch?v=2KeMzx6r_Tk
I like the ease of these, and the ability to be able to close the deck lid as per stock. I’m also running a 64 Vert deck lid on her so should be getting plenty of air when I’m done ?
As I said, I’ve got lovely tick over, really good oil pressure, and excellent oil temperature, she just seems to stumble a bit. I have been running in for approximately 100 miles, I’ve been really careful with the revs, and the speed, I’ve not gone past 50, most of the driving has been 30 to 45 mph, revs between 2500 and 3000. Lack of pulling is more noticeable in 3rd, but she’s a nice lazy engine, I change to 4th and she just laps it up 😂
Your thoughts appreciated ? Murt
This is Mrs Murt and the Pooch at the weekend 🤪🤪
Someone came in a shorty ? Don’t get it 😂😂
