SevenOaks Samba Member
Joined: April 24, 2012 Posts: 264 Location: Friendswood, TX
Posted: Sun Mar 03, 2019 7:39 am Post subject: Can This Case Be Saved? |
Type 1 H case. 10mm head stud in 14mm case saver pulled out of the case when torquing the head. Is there any way to repair this or am I buying a new case?
_________________ David
1974 9-passenger bus
1969 Single cab
1966 Beetle |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Mar 03, 2019 8:40 am Post subject: Re: Can This Case Be Saved? |
I found that, too, when searching for a solution. Unfortunately, that calls for a 31/64” drilled hole but a 1/2” drill bit is loose in the existing hole. _________________ David
1969 Single cab
1966 Beetle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Sun Mar 03, 2019 10:16 am Post subject: Re: Can This Case Be Saved? |
Could just make an insert any size you need. Example, take a 5/8 bolt. Cut the threaded end as long as the saver needs to be then tap the inside to 10x1.5mm. Now tap the hole to 5/8 and be done with it. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Sun Mar 03, 2019 10:40 am Post subject: Re: Can This Case Be Saved? |
Might try the next size up: I've used 5/8-11 TPI savers. Requires drilling to .531" (17/32)".
Looks like an H0 case & BTW the saver to the immediate left of that pulled one appears ready to "exit" as well ....... how did that guy hold torque? _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sun Mar 03, 2019 4:29 pm Post subject: Re: Can This Case Be Saved? |
WOW, that is awesome! I’ve searched high and low on the internet with no results. Then totally failed trying to drill out a 5/8” bolt and about ready to admit defeat. I’ve emailed the seller and if I manage to get my hands on one (or more) may pay a professional to install since I’m about done screwing up this project. Thanks a bunch for the link! _________________ David
1969 Single cab
1966 Beetle |
gt1953 Samba Member
Posted: Sun Mar 03, 2019 6:03 pm Post subject: Re: Can This Case Be Saved? |
I would go that route by replacing the case saver. Happened to us last century on an engine. The machinist called it an over size case saver. Worked great. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sun Mar 03, 2019 8:26 pm Post subject: Re: Can This Case Be Saved? |
I’ll have two case saver savers on the way to me tomorrow. Thank you all for the tips! _________________ David
1969 Single cab
1966 Beetle |
Slow 1200 Samba Member
Posted: Mon Mar 04, 2019 1:27 am Post subject: Re: Can This Case Be Saved? |
not saying you shouldn't repair this case, but since it originally didn't have case savers that means it's already been fixed before and probably has had a rough life....make sure it's worth saving |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1172 Location: San Angelo, Texas
Posted: Mon Mar 04, 2019 7:45 am Post subject: Re: Can This Case Be Saved? |
Slow 1200 wrote: |
That's the trouble with these things. Use something 60 years, and all of a sudden, it flys all to pieces. Sorry POS. Lol. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
nsracing Samba Member
Posted: Mon Mar 04, 2019 8:38 am Post subject: Re: Can This Case Be Saved? |
Yes of course it can be saved. It will take some machining is all. |
Posted: Mon Mar 04, 2019 9:20 am Post subject: Re: Can This Case Be Saved? |
If the repair fails then I’ll buy a new case. It’s worth the $5 investment in a case saver saver to give it a try. Engine was running strong before. I only took the heads off to replace leaking push rod tubes. _________________ David
1969 Single cab
1966 Beetle |
Posted: Mon Mar 04, 2019 9:37 am Post subject: Re: Can This Case Be Saved? |
Do not torque the heads down any more that 22 ft/lbs. If the head gets too hot it will pull studs again. The problem is 10mm head studs are tooo strong for the case. If the first case savers installed were 8mm stud inserts you would not be having this problem.
Dan |
fuguboy Samba Member
Posted: Mon Mar 04, 2019 10:24 am Post subject: Re: Can This Case Be Saved? |
Anyone sell 8mm studs with 10mm threads ? |
Posted: Mon Mar 04, 2019 12:04 pm Post subject: Re: Can This Case Be Saved? |
Years ago Rimco would grind down the non thread area of 10mm studs but afaik they are NLA. Dan |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Mar 04, 2019 1:53 pm Post subject: Re: Can This Case Be Saved? |
In 30+ years, that has only happened to me once. I threw the case in the garbage. If you can pull one stud insert, what's to stop the other ones from pulling? And for what, an H case? It seems like a very unnecessary risk to take when building a motor. I certainly wouldn't sell somebody one with a fix like that and put a warranty on it. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Mar 04, 2019 3:51 pm Post subject: Re: Can This Case Be Saved? |
Again, I only took the heads off to replace leaking push rod tubes. It’s not a rebuild. Every step I take with this engine is a learning process. You can learn more about engines with an old problem one than a shiney new one. I won’t mind having a new one someday, even if that’s sooner rather than later but in the meantime I’m starting to learn how to do some stuff for myself. _________________ David
1969 Single cab
1966 Beetle |
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Mon Mar 04, 2019 4:45 pm Post subject: Re: Can This Case Be Saved? |
I found out that the "H" cases are some of the softest case VW made. when i redid my H5 case i pulled a few threads, case saved anythin g that pulled. |
