BJT Samba Member
Posted: Mon Mar 04, 2019 9:51 am Post subject: Engine skid plate question |
The PO replaced the Thing AM engine with an AE engine. not really sure where AE engines came from (bus or bug?). Anyone know if any of the Thing's stock engine skid plates, front, grill and rear, fit an AE engine? or were there Thing specific mounting holes on the AM engines? Thanks |
frogman_94 Samba Member
Posted: Mon Mar 04, 2019 1:22 pm Post subject: Re: Engine skid plate question |
My engine was replaced also and I had to drill and tap the holes for the rear engine guard. |
BJT Samba Member
Posted: Mon Mar 04, 2019 4:19 pm Post subject: Re: Engine skid plate question |
frogman_94 wrote: |
Thanks, was it only the rear guard that needed holes drilled? |
Joe 20 Samba Member
Posted: Mon Mar 04, 2019 8:34 pm Post subject: Re: Engine skid plate question |
AE engines were used in the early to mid 70's in Beetles and Ghia's. Go to the Technical section and look under Vin/Chassis Numbers. |
BJT Samba Member
Posted: Mon Mar 04, 2019 9:03 pm Post subject: Re: Engine skid plate question |
Joe 20 wrote: |
Thanks, I’ve looked around on various VW code identification websites, seen it listed as having been in T2 Buses as well...
But really, Im just trying to find out if any of the Thing engine skid plates will bolt right on. Sounds like the rear guard won’t. |
Posted: Mon Mar 04, 2019 10:01 pm Post subject: Re: Engine skid plate question |
I believe you need a bus case or a universal case. No expert here though. |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Mon Mar 04, 2019 10:18 pm Post subject: Re: Engine skid plate question |
Wildthings wrote: |
You are right the bus case and some universial cases have the 3 mounting holes or the blocks I will call them to mount the rear mount. All other cases have just 2 blocks
GB |
Posted: Tue Mar 05, 2019 1:59 pm Post subject: Re: Engine skid plate question |
BJT wrote: |
frogman_94 wrote: |
I only have the rear guard. |
Posted: Tue Mar 05, 2019 3:05 pm Post subject: Re: Engine skid plate question |
Yes only the rear guard needs the holes drilled in the block.
GB |
BJT Samba Member
Posted: Wed Mar 06, 2019 9:02 am Post subject: Re: Engine skid plate question |
germanbilly wrote: |
GB |
Perfect. Thanks! |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Wed Mar 06, 2019 9:38 am Post subject: Re: Engine skid plate question |
AE case will accept rear skid plate
No drilling required _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Thu Mar 07, 2019 7:56 am Post subject: Re: Engine skid plate question |
I have these parts for Hermann, with his AH case. I'm not sure what the sheet metal piece is for.
BNMike |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Thu Mar 07, 2019 8:08 am Post subject: Re: Engine skid plate question |
Hermann must be a '73 since I believe the sheet metal piece that's in the photo is a cover piece for the gas heater that should be under his hood. _________________ '74 Thing
'83 Westfalia |
BNMike Samba Member
Posted: Fri Mar 08, 2019 8:25 am Post subject: Re: Engine skid plate question |
wbailey2112 wrote: |
Hermann must be a '73 since I believe the sheet metal piece that's in the photo is a cover piece for the gas heater that should be under his hood. |
Yup, he's a '73, maybe two or three different '73's. Thanks, I couldn't figure out what good that piece of tin would do to shield the engine.
BNMike |
Lleach9 Samba Member
Posted: Sun Mar 17, 2019 4:12 pm Post subject: Re: Engine skid plate question |
I have a 73 that came with an AJ numbered case and no attach points for the skid plates. I’m a newbie, so when you say drill and tap into the case, how deep can you drill before worrying about the integrity of the case?
Thanks |
Posted: Mon Mar 18, 2019 12:07 pm Post subject: Re: Engine skid plate question |
Lleach9 wrote: |
Thanks |
My case had one upper hole drilled but not tapped so I was able to tap that hole then I could use the skid plate as a template for the other holes.
The 2 top bolts are 10mm X 1.50 and 30mm deep and the bolt is 46 mm long.
The bottom bolt is 8mm X 1.25 and 20mm deep and the bolt is 32mm long.
Make sure you mark it before you drill the holes. Hope this helps. And be careful on the top holes and do not go to deep. |
Posted: Mon Mar 18, 2019 9:18 pm Post subject: Re: Engine skid plate question |
Thanks, that is excellent information. I will see if it makes sense to retrofit my setup. |
BJT Samba Member
Posted: Tue Apr 23, 2019 7:41 pm Post subject: Re: Engine skid plate question |
Anyone have a complete list of bolts, including thread pitch for all the protection plates? The parts manual I have doesn’t list thread pitch, and it’s not clear how the front one is attached. Thanks |
LoveMyThing Samba Member
Joined: October 05, 2008 Posts: 89 Location: Los Angeles
Posted: Tue Oct 26, 2021 9:30 am Post subject: Re: Engine skid plate question |
Can anyone describe how to attach the skid plates? I have four pieces and no bolts. And an AJ case. |
