fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Wed Mar 06, 2019 12:46 pm Post subject: What filter fits original Kadron air cleaners? |
Ended up with some original Kadron aircleaners and would like to know what air cleaner fits these? The are slightly smaller than the Empi chinese versions. Any ideas on this or what brand/model number might work? I can put the newer filter in, but then I can't use the origiinal round piece with all the holes stamped into it.
Thanks, Mike
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Wed Mar 06, 2019 7:02 pm Post subject: Re: What filter fits original Kadron air cleaners? |
fifthcenturycheese wrote: |
Ended up with some original Kadron aircleaners and would like to know what air cleaner fits these? The are slightly smaller than the Empi chinese versions. Any ideas on this or what brand/model number might work? I can put the newer filter in, but then I can't use the origiinal round piece with all the holes stamped into it. |
The original PN is K 33002 - 80mm height - 100mm diameter. |
BG Brian Samba Member
Joined: July 25, 2010 Posts: 175 Location: sw washington
Posted: Wed Mar 06, 2019 10:11 pm Post subject: Re: What filter fits original Kadron air cleaners? |
Wix 42087 or napa gold 2087 I believe they were listed as a corvair air filter |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Thu Mar 07, 2019 8:36 am Post subject: Re: What filter fits original Kadron air cleaners? |
Is there not a small diameter mesh type of filter available as kadron's fitted to a ghia mean the boot lid springs cant be fitted and a boot lid prop must be used instead.
A mate is having this issue right now |
Posted: Thu Mar 07, 2019 9:59 am Post subject: Re: What filter fits original Kadron air cleaners? |
Kaddie shack have a selection of different styles for bugs and ghia's. |
Olli from NJ Samba Member
Posted: Thu Mar 07, 2019 10:40 am Post subject: Re: What filter fits original Kadron air cleaners? |
My '71 Ghia that I bought about a year ago came with Kadrons and there was no issue with the decklid springs.
It turns out that the previous owner had installed the Kads with low profile manifolds that he got from the Kaddie Shack. (My Kads are for sale)
https://shop.kaddieshack.com/Refurbished-Aluminum-Low-Profile-Manifolds-Ghia-Preferred-KS-13.htm
Olli
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Thu Mar 07, 2019 12:00 pm Post subject: Re: What filter fits original Kadron air cleaners? |
I have a pair of Kadron filters like that, and they use a round metal "insert" (a metal mesh) that fits inside of those filters, and has foam / Uni Filter material wrapped around it.
Thanks, Mike
_________________ 1963 Manx copy
1968 Bus |
