Paulbeard Samba Member
Posted: Sat Mar 30, 2019 9:07 pm Post subject: Re: Shop says I need a new transmission: what's recommended? |
jimf909 wrote: |
Goodness, that's worse than mine at 500 miles (from the same rebuilder).
Such a disappointment but Sodo isn't the only one who has warned us about this rebuilder (this is not AA). |
Yeah, es no bueno…I texted this to the dude I got it from (he has another trans — w Peloquin) and he seemed surprised. If Sodo's theory is right, that this is all just trash from the old parts, pre-rebuild, it's pretty embarassing. Who wouldn't clean out all of that before putting new bearings and cleaned parts back in there?
To be fair, it sounds better than my old one, no whining in all gears that I had gotten used to (my sound deadening doesn't: I hear everything). But this does make me wonder how many miles are in it. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
E1 Samba Member
Joined: January 21, 2013 Posts: 6530 Location: Westfalia, Earth
Posted: Sat Mar 30, 2019 9:31 pm Post subject: Re: Shop says I need a new transmission: what's recommended? |
Wow, that looks pretty bad.
Pardon my forgetting, but isn't your original tranny pretty low miles?
At this point, I do wonder about rebuilding yours and scrapping this replacement heap. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sat Mar 30, 2019 9:35 pm Post subject: Re: Shop says I need a new transmission: what's recommended? |
185k. Rebuilding it is an option, I still have it. Might be the long term play… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
E1 Samba Member
Posted: Sat Mar 30, 2019 9:45 pm Post subject: Re: Shop says I need a new transmission: what's recommended? |
Good. Hoping for better at your 500-mile check. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sun Mar 31, 2019 9:33 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Paulbeard wrote: |
But there is a gallon of FLAPS's best 75-90 in there for the flush cycle. |
I'm actually surprised you drained it at 20 miles, I thought you were fed up already.
You seem reluctant/torn/pessimistic about this effort in trying to get a ten-year transaxle under your van.
It can be done, it's just a lot harder to do in the state of WA.
Your fresh Swepco, sitting for some weeks could be crystal-clear by now. You might decant the clean oil into a clear gallon and look in the sunlight. (a clear water gallon from the super-market costs about $1). The Redline might be clear by now too. Months is better than weeks.
It's best to store the jug tipped like THIS so the heavy stuff goes down to the bottom corner.
Then when you tip it up, the heavy stuff is farthest away from the opening.
Lift the jug slowly and pour slowly (with good light below, such as white paper) until you see the narrow dark stripe appear center-stream, then you stop. The narrow stripe is the lighter-weight particles (above the steel level) so STOP, because the steel layer will be coming soon after. It will be about 95% super-clean oil.
GL-5 being only $16/gallon at FLAPS.... this is for the hobbyist of course.
Also for those who can tolerate the smell or mess
or don't wanna waste resources.
Anyway, you can assume I'd recommend flushing that trans until the magnet tells you it's "fairly clean" (if ever?). If you can get to "clean baseline" then run a 15,000 mile interval..... and come out "clean" again, that's really good to know about that trans.
Using the odometer works for newish, OEM transaxles that only "oxidize" their oil. The odometer is absolutely the wrong tool for rebuilt transaxles of old high-mile used parts that are currently deleting life-miles due to lubricant self-contamination. Self immolation, hari-kiri etc.
That's like checking your tire pressure by odometer intervals.
You could driver many miles on low pressure, causing damage.
IO know this is obvious, just making a point.
If that trans "runs clean" you can sell it with "pretty good conscience" after you get your "real" trans back from German Transaxle.
Agreed it takes some "work" to do this.
And it's possible that it won't ever run clean.
But it might.
Lots of Vanagon owners are out there running loads of trash right in their gear oil now, and the trans isn't failing tomorrow or next week.
Maybe next month (probably next year or two....)
Ten years would be nice, right?
Definitely SAVE any chunks found. Identifying it as "recent" or "previous trash" is very useful for "qualifying this trans".
For example if that chunk was part of the "3rd/4th slider hub" that would be "previous trash". _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sun Mar 31, 2019 9:45 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Haven't drained the Swepco yet…just hauled the trans up to the 6th floor yesterday as part of this exercise. I need to see how much comes out, for one thing, and see the magnet. I bet it's cleaner than the "new" one.
The Redline didn't look great. More like used motor oil than the golden syrup that I replaced it with. And since I only got three quarts, I'll need to add more anyway. If the magnet looks good next time, maybe the Swepco goes in.
The reason it has 20 miles and not just 5 or so was because I wanted to confirm that the shifter needs adjusting. Having trouble getting into 1st. Pulling away in 2nd is OK unless I am on a grade and I am surrounded by them here. My guy will take care of that this week. Once that's sorted, I'll drive it some more and do another decant and inspection. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
E1 Samba Member
Posted: Sun Mar 31, 2019 10:14 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
We all have varied perspectives for endless reasons, but...
If I were you, I'd see this fill-in tranny as two things:
1). A gift
2). A core
... and send your known one in for a rebuild while this core still functions.
Sounds like you have an agreed return of the core locally, all the better if the math says so.
Happy Shifting. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Mar 31, 2019 10:22 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
E1 wrote: |
1). A gift
2). A core
Pretty much how it is coming into focus for me…it relieves the pressure to Just Do Something, while allowing me to use the van. The drain/fill exercise is to stave off any potential for it to grenade on me.
I measured the dimensions so I can size a box to ship the core in but didn't write them down… I can do that when I drain the Swepco… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sun Mar 31, 2019 11:01 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Paul, don't panic. And don't let the one guy here who has the worst luck with transmissions pull you into his story. You might be just fine. In any case, you don't know yet, he doesn't know, and no one here knows, so just proceed in a measured way. Repeatedly flushes is a good idea until you don't see anything on the magnet. People buy used transaxles all the time and just run them. So one that was opened up and had some work done by a competent rebuilder is a step ahead of that in my book. I wouldn't rebuild a transaxle in advance and store it, because your warranty starts the day you get it.
You can try adjusting the shifter base yourself. Under the boot are 10mm nuts that you can loosen a little bit and move the plate around to get a better shift feel. What I do is loosen them and shift it into the gear that seems the hardest to find, then tighten them up. There is a bit of trial and error to it and you can keep a socket wrench with you when you go for a drive and make small adjustments until it feels the best. |
E1 Samba Member
Posted: Sun Mar 31, 2019 11:14 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Clarifying your second sentence would be fair play.
If you're implying Sodo, I do not concur, the man has invested an enormous amount of time helping others for zero gain. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
E1 Samba Member
Posted: Sun Mar 31, 2019 11:37 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Paulbeard wrote: |
E1 wrote: |
1). A gift
2). A core |
I measured the dimensions so I can size a box to ship the core in but didn't write them down… I can do that when I drain the Swepco… |
Good, Paul. 👍🏼 _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sun Mar 31, 2019 11:44 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
^^^Ditto E1. Not often one will share the trauma of things going bad when its bunches of bucks getting ground up - repeatedly. Trying to help others avoid said pitfalls is most welcome to this synchro trans owner.
Not panicking is sound advice and we don't have to listen to what the guys on soapboxes say...but when they make sense (and talk with pictures! ) I'm going to listen to it and consider the outcomes. Doesn't mean I'm going to do it ( ) but its much appreciated here. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Sun Mar 31, 2019 11:47 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
davevickery wrote: |
Huh. I didn't know it was that easy. I thought it would take a lot of fumbling around under the clamshell.
And yes, people buy used transaxles all the time, most of them already bolted up. The risk factors on this one are the rebuilder's rep offset by the fact that it has been gone through and (I hope) has new bearings and maybe even a better 4th gear. I hope to get the build sheet/receipt one of these days. I hope I don't appear to be panicking. This is all new to me but I am trying to be methodical and practical while actually putting the trans to work. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Sodo Samba Member
Posted: Sun Mar 31, 2019 11:50 am Post subject: Re: Shop says I need a new transmission: what's recommended? |
Sorry this program was defunded in 2007. There are no used transaxles, just “cores” sorry thats not really funny to someone in need.
Agreed. Who’s the competent rebuilder that doesn’t clean the parts? Does this builder inspect parts for serviceability before re-use? Then just slam it together and out the door?
2years @ 12,000 miles (a lot for an antique) is only 24,000 miles. A rebuilt should run 80,000 miles. Don’t put much faith on warranty past a few months. Scarcity is a real problem. Besides R&R is not offered in any tranaxle warranty and adds what....$600? In those cases it’s better to go to a shop where the shop is willing to accept that risk. Seattle area shops have been burned by our WA tranny shops though, they’re at the end of their ropes too.
PaulB I think you made a good choice (risk?) getting this Transaxle to take the heat off, and do your other one “right”.
Hmmmm. I wonder if Dave V is responding (in error) to the other guys new “Transaxle Problem” thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=716505 Where checking linkage (first) is the logical sequence. _________________
Posted: Sun Mar 31, 2019 1:11 pm Post subject: Re: Shop says I need a new transmission: what's recommended? |
Here's the old magnet after running on Swepco for a few thousand miles/15 months.
Nice and clean. Not sure I am going to reuse the Redline, considering how crappy it looked after 20 miles. This stuff looks super clean, bright blue, not oxidized (I assume?). The Redline looked like used crankcase oil, I presume from picking all the scuzz from the unclean case and re-used parts.
EDIT: just poured off the Swepco from the pan into a jug for settling. It looked good, no glitter or anything. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
