Jack point repair
av8shunmeckaneck
av8shunmeckaneck is offline
PostPosted: Thu Mar 07, 2019 11:14 pm    Post subject: Jack point repair Reply with quote
Started repair on the right rear jack point. Couldn't find pictures of what the box above the back point is supposed to look like so i just started bending some sheet metal.
av8shunmeckaneck
PostPosted: Tue Mar 12, 2019 10:26 am    Post subject: Re: Jack point repair Reply with quote
Here is the finished product. I trimmed off the skirt bead and welded it back to the repair panel. Too much rust on the section that I cut out to try and reuse it. I forgot to weld the fwd lower fender nut back in during the repair so I used a rivnut. Turns out it was probably the better way to go anyway.
