My possibly backwards coil
TryMy66VDub
TryMy66VDub is offline
PostPosted: Fri Mar 08, 2019 12:26 pm    Post subject: My possibly backwards coil Reply with quote
So here it goes...the car was like this when I bought it and it’ll crank n run as long as I pour gas n the carb. Someone said my coil is hooked up backwards. Help me get it straightened out please. If u have pics of yours ran correctly, I’d appreciate it greatly. I don’t do do well with just diagrams. Its a 66 wthats been converted to 12volt. Thanks n advance
Some people like cucumbers better pickled. If you or a loved one has been diagnosed with mesothelioma, please get help. Mesothelioma is the #1 cause for death in men and women.
sjbartnik
sjbartnik is offline
PostPosted: Fri Mar 08, 2019 12:32 pm    Post subject: Re: My possibly backwards coil Reply with quote
It's the same answer as before, ignition wire goes to 15. The wire to the cutoff valve and choke also goes to 15.
Wire to condensor goes on 1.
Done. Ain't nothing to it but to do it.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Pruneman99
Pruneman99 is offline
PostPosted: Fri Mar 08, 2019 12:59 pm    Post subject: Re: My possibly backwards coil Reply with quote
I will only run when you drown the carb with gas because the idle cut off is hooked up to the wrong side of the coil.
Just hook it up as instructed above. This isn't rocket math.
don1357
don1357 is offline
PostPosted: Fri Mar 08, 2019 1:23 pm    Post subject: Re: My possibly backwards coil Reply with quote
The coil needs electicity to feed the spark plugs, so an electric wire from the ignition, 12v, goes on the side with the number 15.
Your carburettor has a cutoff valve that also requires a 12v, so it is also connected to number 15 on the coil. Mind you, it has no specific need to be connected to the coil, it is just convenient as that electric cable turns on with the ignition, which is when that cutoff valve needs to be powered.
The condensor on the distributor connects to the other end of the coil, labeled #1.
And the big fat cable goes to the middle of the distributor.
Mind you, the problem may be a bad cutoff valve. Once you wire it correctly turn the ignition switch, go to the carburettor and disconnect/reconnect the cutoff valve. You should hear a clicking. If you don't it is not letting gas get into the carburetor so it would only work if you mama eskimo gas into it yourself.
Cusser
Cusser is offline
PostPosted: Fri Mar 08, 2019 2:26 pm    Post subject: Re: My possibly backwards coil Reply with quote
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
TryMy66VDub
PostPosted: Fri Mar 08, 2019 3:01 pm    Post subject: Re: My possibly backwards coil Reply with quote
Would you happen to have a picture of how yours is ran? I’m normally pretty decent at mechanics n stuff but wiring freaks me out bad. I always feel like I’m gunna short everything out.
sjbartnik
PostPosted: Fri Mar 08, 2019 4:03 pm    Post subject: Re: My possibly backwards coil Reply with quote
Don't sweat it. I can see the terminal numbers printed on your coil from here! (in your pictures) Very Happy
Make sure the key is off before proceeding. You can't fry anything if the key is off - key is off = no power flowing to coil.
Plug all the wires onto the side marked "15" except for the single wire that goes to the condenser on the side of the distributor.
That's it.
If it helps you see the terminals better, you can unbolt the coil (clamp and all) from the fan housing.
2000 Kawasaki W650
TryMy66VDub
PostPosted: Fri Mar 08, 2019 5:37 pm    Post subject: Re: My possibly backwards coil Reply with quote
Thanks man
!! Can’t b put any easier than that.
That's it.
TryMy66VDub
PostPosted: Fri Mar 08, 2019 6:54 pm    Post subject: Re: My possibly backwards coil Reply with quote
So the condenser is the wire coming from the bottom of the distributor?
That's it.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Fri Mar 08, 2019 7:45 pm    Post subject: Re: My possibly backwards coil Reply with quote
That's it.
Yes.
It's usually a green wire. But sometimes they are black or yellow.
Or if there is a PO hack, RED! Twisted Evil
Good Luck.
TryMy66VDub
PostPosted: Fri Mar 08, 2019 8:26 pm    Post subject: Re: My possibly backwards coil Reply with quote
So I think I got it. Along with removing rust from coil. Does this look ugh? Can I put power to it now?
That's it.
Yes.
Good Luck.
TryMy66VDub
PostPosted: Fri Mar 08, 2019 8:39 pm    Post subject: Re: My possibly backwards coil Reply with quote
Black ignition- +1
Black( maybe green) coming from bottom distributor +15
+15 wire going to carb
rcooled wrote:
It's really not clear what's connected to what in your photos.
Just run the wires as shown in Cusser's post above. So as not to confuse you even further, I've removed the back-up light circuit from the diagram.
It really can't be explained any more clearly than this...
TryMy66VDub
PostPosted: Fri Mar 08, 2019 8:41 pm    Post subject: Re: My possibly backwards coil Reply with quote
Sorry, correction——distribrter +1
Carb +15
Black ignition wire-+15
TryMy66VDub wrote:
Black ignition- +1
TryMy66VDub
PostPosted: Fri Mar 08, 2019 8:47 pm    Post subject: Re: My possibly backwards coil Reply with quote
I’m about to try it...pray for me electric ⚡️
Carb +15
TryMy66VDub wrote:
Black ignition- +1
Luft kühl
Luft kühl is offline
PostPosted: Fri Mar 08, 2019 10:44 pm    Post subject: Re: My possibly backwards coil Reply with quote
sjbartnik
PostPosted: Sat Mar 09, 2019 6:17 am    Post subject: Re: My possibly backwards coil Reply with quote
Carb +15
Yes this is correct
2000 Kawasaki W650
calvinater
calvinater is offline
PostPosted: Sat Mar 09, 2019 6:37 am    Post subject: Re: My possibly backwards coil Reply with quote
Did it start?
"War...War Never Changes"
"three is the magic number"
TryMy66VDub
PostPosted: Sat Mar 09, 2019 6:41 am    Post subject: Re: My possibly backwards coil Reply with quote
It did start and ran great!! Just gotta get throttle cable n I b good! Man I appreciate y’all a help fareal!!
calvinater wrote:
Did it start?
TryMy66VDub
PostPosted: Sat Mar 09, 2019 7:06 am    Post subject: Re: My possibly backwards coil Reply with quote
So it doesn’t run great.....it does however fire right up. It’s like it’s flooding out or something. I have to pump the gas to keep it running. Any insight on that one?
calvinater wrote:
Did it start?
sjbartnik
PostPosted: Sat Mar 09, 2019 11:37 am    Post subject: Re: My possibly backwards coil Reply with quote
I mean there are a million possibilities, vacuum leaks, choke adjustment, ignition timing, etc etc.
One of the easiest things is to check whether your electromagnetic cutoff valve on the carb works. That's the cylindrical device on the left side of the carb with the wire going to it.
That wire should go to terminal 15 on the coil (same one as the ignition wire).
What that device is is a solenoid-operated plunger. When you turn the key on, it retracts a plunger from the idle fuel circuit so the engine can run at idle.
When you turn the key off, the plunger springs back to plug the idle circuit. The idea behind this device was to prevent the engine from running on (dieseling) after the key was turned off.
To make sure it's working, turn the key on and carefully pull the wire off the cutoff valve (don't let it touch any ground points).
Then touch the wire to the terminal on the cutoff valve. You should hear it click as the plunger retracts. If you don't hear it click it may be dead.
2000 Kawasaki W650
