Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Mar 08, 2019 8:13 pm Post subject: What goop to seal a fuel tank fitting? |
Yesterday, I re-fixed a Asher hose fitting in the air box of my 1974 Super Beetle. I’ve had the trunk lid open, and when the wife got home she said she smells gas.
I’ve had a very slight fume leak for a while now, and previously replaced all hoses going to and from the tank. I did this about five years ago, and all the hoses have been leak free.
However, a few months ago, I noticed a very slight fuel smell (not enough to waft into the cabin), and I found the culprit—a male vapor nipple, just before the big filler neck. It should have been soldered when the tank was manufactured, and because it wasn’t, it allowed fumes to escape. I used JB Weld putty, and this worked for quite awhile, but now it’s leaking fumes again.
Is there better—fuel resistant—substance I can use that will take care of this issue for good?
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
bluebus86 Banned
Posted: Fri Mar 08, 2019 8:35 pm Post subject: Re: What goop to seal a fuel tank fitting? |
Tim Donahoe wrote: |
Tim |
If the nipple is loose do to lack of solder, or possibly brazing, then attempts to seal it may be in vain. A fuel proof tank sealer that is used to "repair " pin hole leaks in fuel tanks is a good option. Sealers such as Aviation Brand Form a Gasket are advertised as fuel proof. But again, if the nipple can move around do to lack of solder, even a fuel proof sealer may not work.
Good Luck.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Fri Mar 08, 2019 9:42 pm Post subject: Re: What goop to seal a fuel tank fitting? |
You might try this. It is good stuff. Cures hard as a rock and is chemical and fuel resistant.
https://repaintsupply.com/por-15-ppb-por-patch-black-sealer-p3334.html _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Posted: Fri Mar 08, 2019 9:47 pm Post subject: Re: What goop to seal a fuel tank fitting? |
Blue, the fitting isn’t loose at all. Thy just didn’t seal it up properly.
David, that product you mentioned looks promising.
I also found a Permatex product—a putty—that says it’s fuelproof.
Richard O'Brien |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Mar 08, 2019 10:28 pm Post subject: Re: What goop to seal a fuel tank fitting? |
I used jb weld liquid stuff on the sending unit for my old bronco, the pick up and return tubes were spinning on the sending unit so the tank wouldn't pass ca emissions. Jb weld and no problems. I'd scuff the surface really well first. |
Evil Clown Live
Joined: January 08, 2009 Posts: 1347 Location: Wacky Macs
Posted: Sat Mar 09, 2019 4:31 am Post subject: Re: What goop to seal a fuel tank fitting? |
Marine Tex works the best with gas _________________ CARRY ON
Quote: |
I'll take a Happy Meal with Prozac please |
Quote: |
kiss my airy VW ass |
Quote: |
German word for constapation:
Farfrompoopin |
Quote: |
Chinese word for constipation:
Hung Chow Chow.. & it was GR8! |
AlmostHeavenWV_VW Samba Member
Posted: Sat Mar 09, 2019 4:54 am Post subject: Re: What goop to seal a fuel tank fitting? |
JB weld epoxy
Is fuel resistant
Can be painted
Cheap
Easily purchased _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
slalombuggy Samba Member
Posted: Sat Mar 09, 2019 5:21 am Post subject: Re: What goop to seal a fuel tank fitting? |
Seal All is fuel proof and can get into the tiniest of cracks to seal them up. It is flexable so that if there is movement it won't crack.
brad |
74 Thing Samba Member
Posted: Sat Mar 09, 2019 2:27 pm Post subject: Re: What goop to seal a fuel tank fitting? |
I tried epoxies on the metal nipple of the expansion chamber which had loosened up but it never sealed properly. I finally soldered it and it is leak proof now. Be careful with the fumes though and heat (obviously). |
