jimf909 Samba Member
Posted: Sat Mar 09, 2019 7:23 pm Post subject: Vanagon 4th gear visual: is it a .82 or .85? |
Can anyone confirm that the 4th gear (Vanagon 2WD manual 4 speed) in the picture below is a stock .85 4th gear?
41 teeth on the small gear / 48 teeth on the big gear = .85 which seems to be the stock ratio. Is that correct?
Thanks. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9619 Location: Western WA
Posted: Sat Mar 09, 2019 8:14 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
41/48=.8542
99% sure them’r OEM gears.
Smaller teeth are quieter, last longer. Provided they’re not being overloaded. My preference is smaller teeth cuz I’vm driving an RV, not taking jumps and landing with pedal-to-the-metal.
.82 4th (Weddle gears) have much bigger teeth. Big teeth are better for racing, shock loads, are noisier, and don’t run as long (on the highway). But less likely to bust in racing.
The bigger gear is called the “4th gear idler”. It spins on a needle bearing when you’re in 1st, 2nd, 3rd. When in 4th gear this idler is locked to the mainshaft by the 3rd/4th hub, thus its needle bearing is like a “spacer of cylinders.”
Smaller is called 4th gear pinion. ⚙️ Its splined directly to the pinion shaft (to the “P” of “R&P”. The “smaller gear of a pair” is called the “pinion”.
I’ve always been curious what is the purpose of the circumferential grooves. There’s 3 on the idler & 3 on the pinion. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sun Mar 10, 2019 3:57 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
Thanks for the explanation of the different gears.
This trans has 292K miles and was rebuilt once before in 2005 so there’s a good chance this 4th gear is new (edit! Steve Jobs thought I wanted to spell “new” when I spelled “oem”. O-E-M. Go back to sleep, Steve).
I’ve wondered about the grooves as well. My first 100% uneducated guess imagines they have something to do with oiling. That or noise. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Sun Mar 10, 2019 4:44 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
Jim I can’t think how it would oil any differently. They are certainly an intentional feature that has a cost therefore “a reason”. Maybe “gears” knows this one. He’s been preoccupied these days.
My 100% wild guess is something to do with VWs gear supplier/mfg or maybe dimensions/tolerances. Where the best tranny is built of gear pairs chosen with same # of grooves??
Another guess. They use a tool called a “gear hob” to cut teeth into a gear blank. Maybe the first 1xxx (new hob) get one groove, next 1xxx get two, then three etc. Where if gear tolerances aren’t working out, they know which gears came from which stage in the tool’s useful life. _________________
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sun Mar 10, 2019 7:13 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
The tiny grooves are merely to quickly pair the gears, and know which ratio they are. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Sodo Samba Member
Posted: Sun Mar 10, 2019 7:32 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
Dang the conjecture was more interesting....
Seems odd though, that anyone building these tranny’s would need an indicator. Wouldn’t it be .85s all day long? All week, or all year? Its not like the bolt &nut aisle at HomeDepot, where people pick them up then toss’em back in any old bin. _________________
E1 Samba Member
Joined: January 21, 2013 Posts: 6575 Location: Westfalia, Earth
Posted: Sun Mar 10, 2019 7:41 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
Never realized our gears were so groovy.
Sodo, curious about your theory on larger gears going less highway miles. I would think the opposite; bigger, stronger, and all that. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Mar 10, 2019 7:50 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
gears wrote: |
The tiny grooves are merely to quickly pair the gears, and know which ratio they are. |
Thanks for the insight.
I’ve read that VW matched spring rates of the same spec spring by using 1,2 or 3 stripes of the same color stripe such as brown. Brown is the same spring spec, 1, 2 or 3 stripes is a similar rate in the same spec (all w/in tolerance but more closely matched). _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Sun Mar 10, 2019 8:14 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
E1 wrote: |
Sodo, curious about your theory on larger gears going less highway miles. I would think the opposite; bigger, stronger, and all that. |
More teeth “can be” a smoother transmission of power, & smooth is good. 1st gear needs bigger teeth for strength. 3rd, 4th “enjoy” quiet running with more engagement and smaller teeth. _________________
E1 Samba Member
Posted: Sun Mar 10, 2019 8:24 pm Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
Thanks, Bud. 👍🏼 _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
gears Samba Member
Posted: Mon Mar 11, 2019 7:15 am Post subject: Re: Vanagon 4th gear visual: is it a .82 or .85? |
VW went to fine-tooth "low loss" 3rd & 4th gears during the '70s. Although the individual teeth weren't nearly as strong, the increased "overlap ratio" (number of teeth engaged) made up for this, for the most part. However, breakages would occur when the vehicle was subjected to abnormal shockloads.
When VW introduced the waterboxer engine with increased horsepower (and greater vehicle weight), VW also went with somewhat larger 3rd & 4th gear teeth.
Breakages may still occur, but not nearly as often as with the earlier gears. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
