blatzer Samba Member
Joined: June 27, 2007 Posts: 356 Location: Austintatious- aka ATX
Posted: Thu Mar 14, 2019 6:22 am Post subject: Seal question |
bought a used side vent window complete with seal, installed it and there is a gap between seal and body- use silicon to fill it, or buy new |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Mar 14, 2019 6:33 am Post subject: Re: Seal question |
rear vent, yes? they are notorious for being a pain in the ass to install. maybe just try again, because the new seal you buy could end up the same. How about a picture? |
Posted: Thu Mar 14, 2019 7:05 am Post subject: Re: Seal question |
its the drivers side 'smokers' vent seal
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Thu Mar 14, 2019 7:59 am Post subject: Re: Seal question |
I know this is rhetorical, but is the seal seated around the vent window frame properly before installing it to the bus? Did you remove the bigger window behind it or did you just remove and replace the vent window? If so, did you bend the tabs back into place that holds the front? How is the condition of the seal of the larger window that butts up to the vent window? When you installed it, did you use a lubricant such as soapy water to ensure it slides all the way in?
I swear VW put the rocket scientists and doctors in charge of designing this stupid window and made it way too complicated!
I replaced a windshield seal on my daughter's '73 F100 and had a gap in one spot. I used a little electrical insulation putty. Its remains flexible, waterproof, and best of all... easy to clean up since it doesn't really cure. _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Thu Mar 14, 2019 8:59 am Post subject: Re: Seal question |
in your first pic, where it is not against the body, I see a little flap of rubber hanging out. is this supposed to be tucked in, or possibly lipped around the window flange? |
Posted: Thu Mar 14, 2019 9:27 am Post subject: Re: Seal question |
the larger window had to come out to install the vent window, it went in without trauma, so- the 2nd question, what type of putty, caulk, etc |
Posted: Thu Mar 14, 2019 10:23 am Post subject: Re: Seal question |
I think you need to retry and tuck this in
Posted: Thu Mar 14, 2019 4:43 pm Post subject: Re: Seal question |
you are looking at the actual gap nothing to tuck i'm going with black silicone er you were right but i also had other issues
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 14, 2019 4:56 pm Post subject: Re: Seal question |
Before you get things all goopy pull the window and make sure the seal is seated properly in the vent frame, looks like it's not from here.
Or the bus it came from had a giant rust tumor growing there and it's petrified into the pushed out shape, some heat gun work may cure that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Mar 14, 2019 5:08 pm Post subject: Re: Seal question |
he does not want to hear anything except what to shoot in there. Just give it another go. Don't you get a good feeling from a job done well/right? |
Posted: Thu Mar 14, 2019 5:45 pm Post subject: Re: Seal question |
blatzer wrote: |
the larger window had to come out to install the vent window |
If you lift up on the vent rubber in front from the inside you'll see two metal tabs. If you bend them strait with a screwdriver, then the front part of the window can come out, then slide the back of the vent frame off of the larger window. The large window doesn't have to come out. I would remove it and make sure the seal is right, and the frame is good and free of rusty chunks. Use a lubricant installing it. I think those vent window seals (original) are the best seals the bus has compared to all of the other seals vw made.
Or throw liquid nails or silicone in there. I wouldnt. _________________ Tom
Posted: Fri Mar 15, 2019 8:27 am Post subject: Re: Seal question |
Ok, I got my vent window in this morning and had the same gap. I put the bottom in, then the top. I then put the top in, then the bottom and had the gap on the bottom. I pulled it out and realized the METAL tab on the vent window frame needs to be on the INSIDE of the bus. You have two openings on the bus window body frame. Push the metal tabs from the vent frame through the openings on the bus, then slide the window into place about an inch while working the seal. Hopefully these pictures shows the tab the needs to go on the inside. Good luck.
I stand corrected.... looks like removing the bigger glass is helpful to get the tabs in the openings. I guess my old window was so rusty there wasnt much for tabs left. _________________ Tom
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Fri Mar 15, 2019 8:53 am Post subject: Re: Seal question |
is that seal is old and dry? shrunk? _________________ once you realize im not impressed we will get along just fine |
Posted: Sun Mar 24, 2019 12:56 pm Post subject: Re: Seal question |
thanks mispeld- the tab was the issue, when vw notches a lip, pay attention- the vent window is installed about an inch to the back so the top window tab can get on the inside, as the window is pushed forward to seal the leading edge dont miss the two tabs top and bottom as well!
