finster Samba Member
Joined: May 26, 2012 Posts: 7839 Location: north o' the border
Posted: Fri Mar 15, 2019 9:50 am Post subject: 45 beetle for sale in australia |
looks like there's a '45 for sale in australia... the price showing on another site is £215000
http://richmonds.com.au/portfolio/1945-volkswagen-beetle/ _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
sled Samba Member
Posted: Fri Mar 15, 2019 10:39 am Post subject: Re: 45 beetle for sale in australia |
thats some serious money! quite a few funky details as well
the fender beading looks like garden hose! _________________ drive your split. |
kz1000 Samba Member
Posted: Fri Mar 15, 2019 11:39 am Post subject: Re: 45 beetle for sale in australia |
Nice genuine 1945 plastic wire tie. |
qwerty Samba Member
Posted: Fri Mar 15, 2019 12:02 pm Post subject: Re: 45 beetle for sale in australia |
I noticed the body number stamp under the front nameplate is 11995. I have had two 1946 beetles built end of Sept 1946, with body numbers 10086 and 10089. |
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Sat Mar 16, 2019 1:28 am Post subject: Re: 45 beetle for sale in australia |
.... and I would expect some grease nipples fitted to the beam too. |
mikeandkirsti Samba Member
Posted: Sat Mar 16, 2019 1:49 am Post subject: Re: 45 beetle for sale in australia |
No picture of tunnel serial number and ID plate looks home made, heater boxes are newer, dash VW plate should be a separate plate with a VW not KdF logo which supports the assumption that a 1946 body was utilized and logo swapped? Front axles has parts from 1943; 1945 king pins are much sturdier. Black vs British Military Green? KdF hubcaps vs no hubcaps/clips which was the setup from 1943 to 1946? Oval Beetle seats? Hardly worth the money even if the frame tunnel would be from 1945 (and nothing else?). |
Posted: Sat Mar 16, 2019 2:32 am Post subject: Re: 45 beetle for sale in australia |
I wonder if any of the antipodean members can provide any back story for this car? _________________ "we're here on Earth to fart around" kurt vonnegut
Posted: Sat Mar 16, 2019 3:02 am Post subject: Re: 45 beetle for sale in australia |
A knowledgeable friend pointed out that the serial number plate might be original but the year of production is clearly stamped "6" which would coincide with the body number (see under serial number). That would mean that the serial number cannot be 53238 but something else with the last digits "238". Also, the type 51 serial numbers in 1945 started with "5" not "1", as did the previously built 82e. |
originalo Samba Member
Joined: February 14, 2007 Posts: 358 Location: Germany
Posted: Sat Mar 16, 2019 10:07 am Post subject: Re: 45 beetle for sale in australia |
In 1945 the material supply and production means were extremely short and narrow. 1945 post war built bugs, of which survived only a very limited number into our days have a roof that is welded together from three pieces. The transversal edges in the roof on real 45 bodies are well noticeable.
Another 1945 only interesting detail is the shortnecked tank.
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sat Mar 16, 2019 3:36 pm Post subject: Re: 45 beetle for sale in australia |
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
pbaptist Samba Member
Joined: January 02, 2005 Posts: 1204 Location: Netherlands
Posted: Sat Mar 16, 2019 11:25 pm Post subject: Re: 45 beetle for sale in australia |
IN2VWS: Are the pictures from the unrestored car?
What do you know about that car
The number 1-053238 is mentioned in the registry here on the samba.
The seller confirmed me that the roof was made out of three pieces, but I have not seen pictures and I doubt if he really understand What I was asking. _________________ Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database |
IN2VWS Samba Member
Posted: Sun Mar 17, 2019 1:00 am Post subject: Re: 45 beetle for sale in australia |
Not sure, but I suspect the pan on the right might be the original pan found with the car.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sun Mar 17, 2019 1:38 am Post subject: Re: 45 beetle for sale in australia |
pbaptist wrote: |
The seller confirmed me that the roof was made out of three pieces, but I have not seen pictures and I doubt if he really understand What I was asking. |
1-053238 is not in the registry, it is 5-053238, 51 - British Military Beetle which would be correct for a Type 51. 1-053238 does not make sense.
5-053422 Type 51 is in Germany (maybe Grundmann?), it would be interresting to compare details. |
Posted: Sun Mar 17, 2019 2:46 am Post subject: Re: 45 beetle for sale in australia |
mikeandkirsti wrote: |
I see several 1-053xxx cars build in 1945 in the registry. Probably type 11 and type 51 were build next to eachother in 1945
Also 1-053814 and 5-053814. Is this a mistake? _________________ Dutch Karmann-Ghia and coachbuild lover.
Posted: Sun Mar 17, 2019 3:11 am Post subject: Re: 45 beetle for sale in australia |
Here is a ”real” 1945 Type 51
The first Type 11 was built on 22 November 1945 and had a 5-prefix serial number 5-052847 (although it was a normal Sedan) and a Kübelwagen engine 2-078290. Only 57 Type 11 Sedans were built in 1945 and a total of 699 Type 51 Beetles and 522 Kübelwagens.
Obviously existing chassis (and engines) were utilized so the serial number designation was not uniform.
The chassis 5-053238 was built 16 November so it was definitely a Type 51.
The engine number is 578572. That would place it to May 1953. |
