KW-VW Samba Member
Joined: March 15, 2019 Posts: 16 Location: Montgomery, Alabama
Posted: Fri Mar 15, 2019 10:16 am Post subject: Engine stand test on 71 autostick |
First time post and newbie to vw world. I am assembling 1600 on engine stand using a bus trans mount and wondering what I would need to add to back of motor to try and bench test engine? Torque convertor and starter still in car and I assume I can take the starter out and use for bench testing.
I have read multiple threads on engine stands but too new to understand what I need to mount to engine to get the starter to engage using the bus trans mount.
71 super beetle
1600 Autostick
Thanks for any help or guidance. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2387 Location: Seekonk,Massachusetts USA
KW-VW Samba Member
Posted: Sat Mar 16, 2019 9:41 am Post subject: Re: Engine stand test on 71 autostick |
I was able to view some youtube videos and although I could not find one that specifically showed the autostick being started on an engine stand I did see where the torque converter actually has a flywheel/flexplate . So I guess I can take that out of my car and use to bench start the engine.
My plans are to try that after I drain the trans fluid out and see if that bolts up and works with the bus trans bell housing I found to mount on the engine stand. If anyone has done this and wants to confirm the procedure that would be great. Thanks. |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Sun Mar 17, 2019 8:23 am Post subject: Re: Engine stand test on 71 autostick |
To start an autostick engine on a manual transmission bellhousing, you will need to swap the flexplate for a manual flywheel. It would also be a good idea to make sure there is fluid in the ATF pump and loop the lines so it doesn't run dry. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
KW-VW Samba Member
Posted: Sun Mar 17, 2019 3:24 pm Post subject: Re: Engine stand test on 71 autostick |
Thanks for the reply. I was wondering what to do with the ATF side of the pump. Would it damage the pump if I ran a hose and just plugged the end. I will have to read up on how that cycles when in the car. Thanks again. |
Raymond73 Samba Member
atomicbug Samba Member
Joined: November 06, 2010 Posts: 9 Location: South Carolina
Posted: Sun Mar 17, 2019 4:02 pm Post subject: Re: Engine stand test on 71 autostick |
You really do not want to plug the hoses (stop the flow) on the automatic trans fluid side of the pump. It is a gear pump which means that it is a positive displacement pump (as opposed to a centrifugal pump). Positive displacement pumps put out a specified amount of fluid per rotation no matter what. If you block the flow, the pump will build up more and more pressure until it busts something. The fluid has got to circulate. Make it flow in some kind of loop. |
KW-VW Samba Member
Posted: Sun Mar 17, 2019 4:16 pm Post subject: Re: Engine stand test on 71 autostick |
Thanks for the replies. I am about ready to try and start up engine soon so I will find a flywheel and then make sure that I circulate the ATF side. I should be able to use the reservoir off the car and route the hoses to loop through so the fluid can circulate Thanks again for the advise new to vw world certainly new to Autostick. |
