Poorjimmy5 Samba Member
Joined: July 11, 2016 Posts: 73 Location: Long Island, New York
Posted: Mon Mar 18, 2019 4:06 am Post subject: Gas Gauge "Vibrator" |
Took my speedometer out to fix the odometer and when I re-installed it the gas gauge didn't work. The only thing I did to the gas gauge, after I remove it from the speedometer, was to use some blue loc-tite on the two terminals to keep the loose nuts secure before re-attaching it to the speedometer. (Could THIS have screwed something up?) Used a voltage detector clipped to the dash board frame and the light lit up on both the terminals of the fuel level indicator. My question is, would the fuel indicator work WITHOUT the so called Gas Gauge "vibrator" in series? Would this be a good way of seeing if the Gas Gauge "vibrator" is bad? I have tried two "vibrators", but have a sneaking suspicion that they may be bag as the one already in there when I bought the Thing didn't stop the needle from wandering between full and empty and the one I bought to replace it if from very old stock and it is unknown if it actually works. |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Tue Mar 19, 2019 12:59 am Post subject: Re: Gas Gauge "Vibrator" |
the so called "vibrator" is necessary to reduce the voltage needed by the gas gauge. Its prone to malfunction in case of a lousy contact. Modern replacements are solid state.
By adding loctite you probably lost good grounding for the speedo. Please make sure you are grounding it properly. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Wed Mar 20, 2019 11:53 am Post subject: Re: Gas Gauge "Vibrator" |
perello wrote: |
By adding loctite you probably lost good grounding for the speedo. Please make sure you are grounding it properly. |
Well I just purchased a new version "vibrator", the solid state one - made in Denmark, and will see if that does the trick. When it comes I will take the speedometer out for the umpteenth time and not only connect the new "vibrator", but see if I can remove the Loctite. (Might even polish out the scratched in the plastic speedometer lens) After that I will post again and let you know. Stay tuned and thanks! |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Fri Mar 22, 2019 10:11 am Post subject: Re: Gas Gauge "Vibrator" |
Poorjimmy5 wrote: |
perello wrote: |
hey Poorjimmy5 - [about polishing the plastic lens]
I had to work on my speedo a few years back, stripped gear in there. Once that was fixed and I had the speedo pulled apart, I used a few micro-fiber towels and some "mothers brand headlight polish" from an old kit - it was their plastic polish, I actually was able to take out a scratch you could catch for fingernail on with that stuff.
took a bit of elbow grease doing it by hand on the kitchen table, but I put a microfiber towel on the table, laid the plastic lens on that and polished the crap out of it.
looks brand new!
have fun!!
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Hyatt181 Samba Member
Posted: Sun Mar 24, 2019 4:04 am Post subject: Re: Gas Gauge "Vibrator" |
What Denmark solid state vibrator are you referring too?
Is that the same one everyone is selling?
Poorjimmy5 wrote: |
perello wrote: |
Posted: Mon Apr 01, 2019 3:15 pm Post subject: Re: Gas Gauge "Vibrator" |
Pretty much, maybe not even that good. Said it was made in Denmark, but there are no markings that would even hint at that. Fingers crossed.
What do ya think? |
Posted: Tue Apr 02, 2019 12:31 am Post subject: Re: Gas Gauge "Vibrator" |
most people is fooled byt the danish brand JP group, which mostly distributes parts made in china.
the device you picture uses a feston lamp to reduce voltage, I had always bad luck with it, and you will have a hard time to fplace it in a Thing. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Wed Apr 03, 2019 7:44 am Post subject: Re: Gas Gauge "Vibrator" |
Why would I have a hard time mounting this in a thing? |
Posted: Thu Apr 04, 2019 1:21 am Post subject: Re: Gas Gauge "Vibrator" |
Poorjimmy5 wrote: |
because its big. Not much space left to fit, will touch something and a bad contact follows... _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
74 Thing Samba Member
Posted: Thu Apr 04, 2019 7:01 am Post subject: Re: Gas Gauge "Vibrator" |
You can make small wires with spaded connectors if necessary to install it and then make sure it is grounded well-that is an alternative if you cannot get it to fit on the back of the gas gauge and installed into the compartment. |
Posted: Thu Apr 04, 2019 10:14 am Post subject: Re: Gas Gauge "Vibrator" |
I see. Thanks. Scared to touch my speedometer now that it "mostly" works! LOL |
Posted: Mon Apr 08, 2019 7:02 am Post subject: Re: Gas Gauge "Vibrator" |
perello wrote: |
Ok, removed the speedometer again to clear the plastic lens and remove the loctite from the speedometer terminals.
Was able to remove all of the loctite and its residue with a fantastic little wire brush. Attached a 9V battery to the terminals and the needle moved. I am going to assume now that the gas guage works. Will reinstall after I buff out the issues with the speedometer "glass". |
Posted: Tue Apr 09, 2019 5:21 am Post subject: Re: Gas Gauge "Vibrator" |
I already have a new gasket, but might be interested in a new glass, but don't see it on Mike's website. Do you have a link for the new "glass"? |
Posted: Tue Apr 09, 2019 12:57 pm Post subject: Re: Gas Gauge "Vibrator" |
You have to email him. It is not listed. Originally the cover is some sort of plastic material that can scratch. He sells a real glass replacement. |
Posted: Wed Apr 10, 2019 10:53 am Post subject: Re: Gas Gauge "Vibrator" |
Roger, roger! Thanks! |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
