challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Tue Jun 04, 2019 1:36 am Post subject: Re: Craigslist 1970 bug |
3 years since it was first 'built' and I use that term loosely, it's finally back together! Hoping it lasts longer than a dyno session this time.
2276
Dpr 82mm crank and flywheel
Cb 5.5 H beam rods
Mahle 94mm pistons
AA Cylinders cut to length
Raptor 00808 cam
Tp lightweight lifters
Logmech dual tapered aluminium pushrods
Jeff Denham heads 42x37 valves
Lightweight springs titanium retainers
Vw speedshop efi and crank trigger ignition
Vw speedshop ss hideaway exhaust
Full hvx mods inside. |
Posted: Sat Jun 15, 2019 9:16 am Post subject: Re: Craigslist 1970 bug |
Been working on wiring and some other bits and pieces and the to do list is getting considerably shorter day by day so I'm nearly there.
Gauge panel fitted and all wired in
Wiring loom for the engine management all done and routed through the same locations as the main loom. I've a panel on the floor opposite the battery where the ecu and relays will bolt down on.
All cleaned up underneath while the body was in the air.
New firewall kit and regulator and coil pack mounted on the firewall.
Hopefully get the body and pan together over next couple of days, after that it's fingers crossed everything works when I hook it all up. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sat Jun 15, 2019 10:25 pm Post subject: Re: Craigslist 1970 bug |
Dp
Posted: Sat Jun 15, 2019 10:26 pm Post subject: Re: Craigslist 1970 bug |
joey1320 wrote: |
Wow great color.
That's going to be a great car. |
Thanks dude it's been long time coming together and has taken 5 years to collect all the parts I have for it, actually longer, I first bought the wheels almost 15 years ago! It better be worth it
Doing it all myself has been satisfying too as I hadn't a clue when I started the project and I've had to wing most of it. It's my first engine build and first time doing anything with efi and the necessary wiring and plumbing that goes with it.
If you want something done right though I've learned that you have to do it yourself. |
Posted: Mon Jun 17, 2019 1:28 pm Post subject: Re: Craigslist 1970 bug |
A little closer to the finish line.
Gonna test the fuel system tomorrow and provided there's no leaks then I can bolt the body down. Will probably fit the engine to the gearbox first too, as should be easier than trying to juggle it in later. |
Posted: Sun Jun 23, 2019 5:00 am Post subject: Re: Craigslist 1970 bug |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Jun 23, 2019 9:21 am Post subject: Re: Craigslist 1970 bug |
IT IS ALIVE!
Looking good! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Jun 23, 2019 11:29 am Post subject: Re: Craigslist 1970 bug |
Thanks Jimbo yes finally! Got to get it mapped and then I can get to drive it at last. |
Posted: Sun Jun 23, 2019 10:26 pm Post subject: Re: Craigslist 1970 bug |
joey1320 wrote: |
Engine sounds super healthy 👍 |
Thanks joey should sound a lot better once it's set up properly |
Posted: Sun Jun 23, 2019 10:38 pm Post subject: Re: Craigslist 1970 bug |
So much fun to drive with a bigger engine!
You are going to love it! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Jun 24, 2019 11:10 pm Post subject: Re: Craigslist 1970 bug |
VW_Jimbo wrote: |
You are going to love it! |
Should get to drive it tomorrow I hope, bringing the car up to bugbitz in Armagh where Dave will help me get a base map sorted. I'll put a few miles on it then before hitting a dyno for a full mapping session. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Tue Jun 25, 2019 10:39 am Post subject: Re: Craigslist 1970 bug |
Buggeee wrote: |
Ok... So a pan off restoration on this particular cream-puff survivor would not have been my first guess.
Awesome work on an awesome car! |
I'll let you in on a secret, I pulled the body to put it on my 69 pan which was already molested to fit dual fuel lines and mid mount brackets. Saved molesting 2 cars and I get to keep the 70 pan intact with matching numbers engine and gearbox. I'll restore it to stock as time progresses. |
catbox Samba Member
Joined: May 16, 2007 Posts: 866 Location: Portland, Oregon
Posted: Tue Jun 25, 2019 1:11 pm Post subject: Re: Craigslist 1970 bug |
Super cool what you have done to the car. _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
Posted: Wed Jun 26, 2019 11:59 am Post subject: Re: Craigslist 1970 bug |
catbox wrote: |
Super cool what you have done to the car. |
Thanks dude!
9 hour return trip to see Dave today, got a base map sorted, learned a lot about mapping and the engine didn't blow up
Gonna dump the oil and check valve lash in the morning and hopefully take it out for a drive.
Posted: Thu Jun 27, 2019 11:20 am Post subject: Re: Craigslist 1970 bug |
baz76 wrote: |
Buggeee wrote: |
Sweeeeeet! The best of both worlds. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Posted: Fri Jul 12, 2019 10:43 am Post subject: Re: Craigslist 1970 bug |
Wow! Barry, hard to believe that's the same car I shipped.
I'm happy to see you're enjoying it.
Leslie _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
Posted: Fri Jul 12, 2019 10:22 pm Post subject: Re: Craigslist 1970 bug |
RixiesRide wrote: |
Leslie |
Hi Leslie how are you? The car sure looks different, its amazing what a good cleaning did for it. I knew it was a good one from the first pics I saw of it, now you can see why I was so keen to make sure I got it.
I can't thank you enough for your help, you made me feel totally at
ease and I knew the car was in good hands right from the get go with you. You're a diamond Leslie and I hope you are keeping well.
Ps the key tag you left on the key is in the glovebox and will stay there forever.
Here's the bug the day it left your place I believe
