Front suspension rebuild 1966
Era Vulgaris
Era Vulgaris is offline
PostPosted: Thu Mar 21, 2019 6:15 pm    Post subject: Front suspension rebuild 1966 Reply with quote
Well I'm deep into it! Laughing
The front beam has been cleaned and repainted, as has the entire napoleon hat area.
Alot of those parts won't be going back on the car. I'll be installing drop spindles, new ball joints, wide 5 discs, a new big bore dual circuit M/C, and a rack and pinion steering kit from Samba member -Alex77- Very Happy
1966 Karmann Ghia, under construction
1998 Porsche Boxster, silver, 2.5L overhauled by Jake Raby SOLD!
1967 Karmann Ghia, Black, 1500sp, 4 lug steelies SOLD!
1998 BMW Z3, Atlanta Blue Metallic, 2.8L I-6, 17" factory wheels SOLD!
1975 Porsche 914, Laguna Blue, 2270cc DRLA40's, 5 lug fuchs SOLD!
1972 Porsche 914, Signal Orange, 1.7 FI, 5 lug fuchs SOLD!
1974 Karmann Ghia, Black, 1600dp, bullet turn signals, steelies SOLD!
1974 Triumph TR6 with O.D., metallic blue, stock everything SOLD!
Era Vulgaris
PostPosted: Thu Mar 21, 2019 6:16 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Alex just sent me this pic of my newly fabricated R&P steering kit before he boxed it up to ship.
Here's some more info on this setup if anyone's interested:
https://www.thesamba.com/vw/forum/viewtopic.php?t=580737
Era Vulgaris
PostPosted: Thu Mar 21, 2019 6:33 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
New ball joints that were installed by the PO. Anyone see a problem? Mad
Not a single one out of the 4 that's lined up correctly!
I've got 4 new ones on the way
Disc
Disc is offline
PostPosted: Thu Mar 21, 2019 11:55 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Last year I ordered the "bracket" from Alex that holds the R&P, unwelded and also got the other parts from Ebay. Well unfortunately the bracket does not fit on the beam, some grinding is needed. The radius of the cut does not fit the OD of the beam. Some other modifications needed too, but I'm still not to that point, probably late this year.
The glory never gets old, just need new paint.
Nick
Era Vulgaris
PostPosted: Fri Mar 22, 2019 5:42 am    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Yeah I figured it would need some adjustments. Most non-stock things do. I'm used to taking things apart and modifying them before install Wink
When I decided to get another Ghia, it was under the condition that I was going to ditch the crappy OE steering box at all costs. Whatever it takes man!
Era Vulgaris
PostPosted: Fri Mar 29, 2019 4:52 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
I installed new ball joints yesterday, and cleaned and painted my trailing arms.
The last time I replaced ball joints was on my first Ghia about 6 years ago. I'd like to go on record as saying that I'll happily go another 6 years, or hopefully more, before I do that again! Laughing
I've got new trailing arm seals and it'll all go back into the beam once the paint has had a couple days to completely dry.
Era Vulgaris
PostPosted: Sun Apr 07, 2019 1:56 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
I'm still waiting for the R&P steering kit to show up. But in the meantime I've been able to reassemble the front beam, install the new drop spindles, and the wide 5 disc rotors. I used the AC Industries disc conversion kit with drop spindles from Socal Auto parts. But I ditched the KML bearings that comes with it, in favor of FAG bearings all around.
Test fit with the wheels looks pretty good! I couldn't get a direct-on side shot because our other car was in the way, but the car now has the slightest forward rake - like just a degree or two. If you just glanced at it, you'd think it was level. The stance is exactly what I was after. I'm glad I went with the drop spindles, and not an adjustable beam like I had originally considered doing.
Also, that's my new custom geared trans in the big box by the rear wheel! Very Happy Rear end rebuild will be happening after I finish the front end.
Era Vulgaris
PostPosted: Sun Apr 07, 2019 2:01 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
It also looks like I hopefully won't have an rub issues. The PO installed new 175/65/15 tires in 2017. We'll see how it behaves under load once I get the car running. But at full L and R there's clearance galore.
Everything I'd read said that a stock width beam with drop spindles and a wide 5 disc conversion would definitely rub, so I was just kind of crossing my fingers and hoping I'd be ok. I guess maybe with stock 80 aspect ratio tires it might be an issue, but the with the 65's it seems like there's tons of room.
Era Vulgaris
PostPosted: Wed Sep 11, 2019 9:45 am    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Well, I haven't updated this in a long time. As it does, life gets in the way. I got married at the end of April and then the honeymoon and traveling! We had a blast! And then after we got back home, the brutal summer NC heat and humidity in July and August really de-motivated me from getting much of anything done on the car until this month.
Also another thing that kept me from making progress was Alex's bracket. As Disc mentioned, it just did not fit, and the positioning of the mounts made it impossible for it to ever fit correctly. I sent the whole thing back to Alex and got a refund, less his "restocking fee" Rolling Eyes
Anyway, I picked up another R&P kit from Kerscher Tuning in Germany, and this install has been flawless. Everything fit right, everything went together great. There are a few small bits that aren't included in the kit, and if you're interested on details PM me.
I've pushed the car in and out of my garage and around my driveway, and even at what is probably 1mph it's a totally different world. No slop, no play, just direct precise steering feel. I can't wait until I have the car running and I'm out on the road!
Also, I did a test spray in the area under the gas tank with L444 Malachite Green, just to see how the color looks in real life. That's going to be the color when I'm done with this build! Very Happy
rbsurfguy
rbsurfguy is offline
PostPosted: Wed Sep 11, 2019 12:08 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Is this the version you bought?
Conversion kit on rack and pinion steering gear
Conversion kit on rack-and-pinion steering gear for VW models Type 11/15 (1200/1300/1500) and Type 14
(Karmann) with crankshaft axle
from year 08/65
Would this fit later years like a 71? Their website isn't too clear, even using translator.
Thanks, Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Era Vulgaris
PostPosted: Wed Sep 11, 2019 12:33 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Their website has an English version. There's a German flag and British flag off to the left. Click the British flag for English.
You can also email them. I did with several questions. Their English is pretty good.
Here's the kit:
https://www.kerscher-tuning.de/kaefer/index.php?gruppe1=Lenkung&gruppe2=Lenkung
There's a ball joint beam version (8/65 and later), and a link pin beam version (7/65 and earlier). Those are build dates, as August 65 was the beginning of model year 66.
You'd want the ball joint version for your 71, same as on my 66.
You have to cut your steering column down, and weld in the column adapter that fits into the steering u-joint. That was the scariest part - the measuring and the cutting. I don't know if your 71 has the earlier solid steering column, or the later crash-safety steering column. I had free reign to cut wherever I wanted. I don't know if the late accordion steering columns could pose a problem or not.
Other than that, everything else is bolt on. But you do have to source your own tie rod ends (two stock ghia right hand thread ends), tie rod end nuts, and tapered tie rod jam nuts (you can get these from ISP West. Otherwise hard to find).
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Sep 11, 2019 1:44 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Oh HELL NO! You don't get a "restocking fee" when your crap product doesn't fit. You need to lean on his ass to get your full refund. You also need to mention this, AND the fitment issues, in the feedback section.
Era Vulgaris
PostPosted: Wed Sep 11, 2019 5:00 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Yeah, if I had bought the parts from some big corporate entity that had piles of cash to spare I'd be right there with you. But I looked up his address on google maps; he's just some guy in a podunk town in Finland trying to make his way. At no point was he ever rude or impolite, and he never acted like he was trying to rip me off.
To be fair it had been 3 or 4 months since I'd bought the parts from him, which is waaaay beyond most big companies' return window. I was thinking I was going to have to eat the whole cost at that point because I'd been out of town and then procrastinated during the summer heat on actually trying to fit the parts.
I think sometimes you just have to assess a situation based on how someone's behaving. He was professional and polite, and listened to the fitment issues I told him about and hopefully he makes the brackets better in the future. As a self-employed small business owner myself I can relate to his situation, and sometimes you take a small hit and the best thing is just to move on and not dwell on it. I'm not interested in bashing Alex. If someone is interested in his products and does their due diligence by searching this forum, they'll find this thread.
kiwighia68
kiwighia68 is offline
PostPosted: Wed Sep 11, 2019 6:29 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Era Vulgaris wrote:
TDCTDI wrote:
Era Vulgaris wrote:
I sent the whole thing back to Alex and got a refund, less his "restocking fee" :roll:
I applaud you for your attitude. A little understanding goes a long way.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
TDCTDI
TDCTDI is offline
PostPosted: Wed Sep 11, 2019 7:18 pm    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Unfortunately, his product fits more than just Ghias & the next unsuspecting buyer may not think to search here. I still suggest, at the very least, posting your experience of his product in his feedback thread.
Think of it as doing the community a favor.
rbsurfguy
PostPosted: Thu Sep 12, 2019 6:10 am    Post subject: Re: Front suspension rebuild 1966 Reply with quote
Thanks for the follow up info Era. I have the late model crash safety accordion steering column, so if I went this direction, would have decide if that would work or use an earlier version. Not anywhere near doing this now, but something to think about at a later date should I get tired of the drifty feeling I always felt my Ghia had previously.
And I always get concerned when it comes to making precise cuts, I'm better trained and more skilled at breaking things or damaging beyond repair, damn Army!!!
Jeff
2012 Passat-Sold
