vw76westy Samba Member
Posted: Fri Mar 22, 2019 10:46 am Post subject: Rookie starting Issues 76 fuel injected |
I have a Gremlin in my bus
My bus will start perfectly on the 1st crank
When its stone cold
Or when hot
But while it's warming up or after its warmed up
Any suggestions
I want to reaffirm it will start at "first crank" when cold or hot
But not quite hot
It sometimes stalls if it turns off it won't restart
Unless I walk away and wait for it to be cold
If I keep foot on gas during this stage
(First 5-10 min of driving, after 2-3 of idling)
It will be fine....
I'm assuming this issue is either the
Temp sensor under plenum
Or
the aux air
Problem is they test out when
Stone cold and hot
And
Its twilight when I have issues
I'd rather find the bad part
Than simply replace parts until problem goes away _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Fri Mar 22, 2019 10:51 am Post subject: Re: Rookie starting Issues 76 fuel injected |
Is this a poetry jam?
Before suspecting FI, basics:
Valve adjustment
Ignition timing (what do you have it set at?)
VACUUM LEAKS
This FI system is intolerant of vacuum leaks. Make a smoke tester and see what you've got. How old are the injector seals, the intake plenum boots, all the vacuum hoses? _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Mar 22, 2019 1:02 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Really.......
Since the bus starts and drives fine
Valve adjustment and timing has absolutely nothing to do
With issue
A vacuum leak is possible but then i would expect
Problem to be a more consistent while driving
And at all other times
If I did not know any better
You'd be sending me on a time wasting mission
Given the reliable consistency of my issue
The only other thing I can think of is
Is temp2 sensor or even the afm _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Fri Mar 22, 2019 1:54 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
the bus starts when it's warm
the bus starts when it's cold
I have a feeling that it's beginning to mold
is that poetry or a haiku? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 22, 2019 3:07 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
The bus starts when it's cold
But not when its warm
If I start bus let it idle for 2-3 min
Then turn it off
It won't restart
If I drive it 2, 3 blocks
To get food
It won't start after getting food
If I drive 50 miles to a car show
Then for the next hour or so I'll have no problem
Starting
As long as it hot....
The only time I have a starting issue
Is when the bus is warm..... _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Fri Mar 22, 2019 3:14 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
vw76westy wrote: |
Really.......
With issue
Is temp2 sensor or even the afm |
Jesus christ here we go again
¯\_(ツ)_/¯
Sure, throw parts at it. Maybe you'll get lucky _________________ 1965 Volkswagen 1500 Variant S
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Fri Mar 22, 2019 4:00 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
sjbartnik wrote: |
¯\_(ツ)_/¯
Sure, throw parts at it. Maybe you'll get lucky |
OMG! I just spit my drink out! Lolol. Can't make this stuff up! _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Fri Mar 22, 2019 5:29 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Try pulling the plug off your Cold Start Valve once it has been started cold and see if that fixes your problem. |
BoltonFTW Samba Member
Joined: February 18, 2017 Posts: 102 Location: San Francisco
Posted: Wed Mar 27, 2019 1:02 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Wildthings wrote: |
Would this mean the TTS is bad? or the CSV?
I have a similar ongoing issue to the OP-- and I feel like when I get the no-start condition (which seems to happen on a previously warmed up and now cooling down engine) if I pull the CSV it's more likely to start up-- when I don't pull it, it will turn over but not catch-- and smell like fuel when I go to the engine bay to investigate)
OP: did you resolve your issue? _________________ Drew
1978 Westfalia Campmobile Deluxe 2.0 FI w/hydraulic lifters
1977 Westfalia Weekender Tintop (very first car - SOLD )
1992 VW Corrado VR6 (SOLD) |
Posted: Wed Mar 27, 2019 1:08 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
BoltonFTW wrote: |
Wildthings wrote: |
OP: did you resolve your issue? |
It would be telling you that the TTS is activating the CSV when it should not. Easier to pull the plug off the CSV than the TTS though. |
SGKent Samba Member
Posted: Wed Mar 27, 2019 2:08 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
what it tells me Raul is that you should do a smoke test and look for a vacuum leak first. When cold the CSV gives a boost of fuel so it starts because the mixture is richer. When it is hot the air to fuel mixture is close enough it runs. When it is warm it is too lean and needs extra fuel because of the vacuum leak so it doesn't run.
The AAR acts like you open the throttle a little. If it idles fine the first three minutes if you hold the throttle open a little then it would be the AAR.
The CSV provides a little extra fuel. If it was still sending extra fuel when hot it would easily flood out.
All this assumes that you have checked the fuel pressure and have adequate pressure & that the relays or pump are not doing some kind of thermal trick. Also it assumes that the ignition switch is good. When they go bad they do some funny things. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Mar 27, 2019 4:24 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Also keeping in mind that the CSV only gets power when the starter is operating. If the TTS is providing a ground path when starter is operating, then CSV will fire. If it's too warm and TTS is not providing ground path, no CSV activation.
CSV, when wired properly anyway, does not get power unless the starter is operating so it cannot fire when starter is not operating.
It can leak though, but pulling the electrical plug would have no effect on that. _________________ 1965 Volkswagen 1500 Variant S
Posted: Wed Apr 03, 2019 9:36 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
OP, curious if you resolved your Gremlins _________________ Drew
Posted: Sat Jul 20, 2019 9:37 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Well after spending many stranded days
After spending countless hours
Testing things that work perfectly when I test them
After going threw the pain in the ass
Of changing out parts 1 by 1
1 week at a time
The entire problem was the ......
The........
" Temp2 " _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Sat Jul 20, 2019 9:54 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
A story only you vw people could appreciate
Got the gremlins out
Bus is reliable again.....
You guys all know this great feeling
So I decide to take the bus to meet up with friends on a fri night
As I get off freeway clutch cable breaks
Bus stalls.....
So I figured I'll start bus in 2nd gear to get somewhere safe
Except the battery decided it was not holding a charge any more
So after pushing it a block
I got my spare cable out and replaced clutch cable
Then realized I left jumper cables sitting on the ground
At my house
most people today dont carry jumper cables..... _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Sat Jul 20, 2019 10:54 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
vw76westy wrote: |
The........
" Temp2 " |
I had the exact same Gremlins from your original post which is why I was following. Replacing TS2 worked for me too. My old one seemed like it was on the fritz. Funny thing was that the first replacement TS2 that I ordered was DOA.. so when I put it in and it didn't fix the problem I looked elsewhere, TTS? CSV?
Finally I tested it. To verify it was DOA... found it to be a dud and ordered a second replacement. Installed the second replacement and bus has started fine ever since. _________________ Drew
airschooled Air-Schooled
Posted: Sat Jul 20, 2019 10:55 pm Post subject: Re: Rookie starting Issues 76 fuel injected |
Sorry that happened
Temp Two is always suspect
So is Spark, Robbie _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Abscate Samba Member
Posted: Sun Jul 21, 2019 3:41 am Post subject: Re: Rookie starting Issues 76 fuel injected |
I want to see this Gremlin. I can’t see it fitting in either the rear or slider door.
Stone cold.
Igneous or metamorphic?
If you walk 2-3 blocks to get food, that solves that problem.
Glad you are back on the road, Raul.
With the hosting comes the roasting. _________________ .ssS! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Jul 21, 2019 11:44 am Post subject: Re: Rookie starting Issues 76 fuel injected |
Abscate wrote: |
Stone cold.
With the hosting comes the roasting. |
I think it is igneous. From the Cretinous period......Or was it ingenious from the Mesozoic? Can’t remember. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
