ourv12 Samba Member
Joined: November 30, 2006 Posts: 492 Location: Great SouthWest Michigan
Posted: Sun Mar 24, 2019 4:35 pm Post subject: 91 Power Steering Intermittent ???? |
My power steering pump reservoir is full.....lines are dry with no leaks....but steering becoming intermittently more difficult everyday. Is that a sign the power steering rack is going bad??? |
?Waldo? Samba Member
Posted: Sun Mar 24, 2019 4:36 pm Post subject: Re: 91 Power Steering Intermittent ???? |
I had similar happen and it was indeed the rack. |
floodwood Samba Member
Joined: October 22, 2017 Posts: 164 Location: Cambridge, MA
Posted: Thu Apr 15, 2021 5:20 am Post subject: Re: 91 Power Steering Intermittent ???? |
I have been having some issues with my PS on my '91 that I have been having some issues tracking down. I farmed this out to my mechanic so the work is under warranty, but I want to get the job done right and understand if I am missing something in the system.
1. Original PS rack leaking, replaced with new PS rack.
2. New PS rack #1 developed play on drivers side, determined to be some metal that the pump pushed through the rack. Replaced pump and rack.
3. New PS rack #2 starting to work only intermittently (it's not really working) and I *think* I can feel play starting to develop again in the same location.
As far as I know and per Bently pg. 48.6, the system is relatively simple and is is comprised of the reservoir/pump in the rear, the hard lines leading to the rack, and the rack.
If the pump, fluid and rack have all been replaced, I am having a hard time figuring out where the issue could be coming from this second time and what else needs to be addressed in the system?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32602 Location: Reading Pennsylvania
Posted: Thu Apr 15, 2021 6:03 am Post subject: Re: 91 Power Steering Intermittent ???? |
Is it possible for one clogged filter to disrupt the entire system? Are there any other failure points I should address? The only thing I can think of is that I used PS fluid instead of ATF fluid, but I wouldn't think this would cause such a premature failure |
Squidfish Samba Member
Posted: Thu Apr 15, 2021 9:17 am Post subject: Re: 91 Power Steering Intermittent ???? |
Thanks for the link on FCP Euro for the filter DjKeev, I had forgotten about how solid that site is! It's been a decade probably since I flushed system/looked at my PS filter... I just grabbed a new PS filter and some Mann oil filters for a great deal. _________________ 1985.5 - Vanagon Westfalia Weekender Wolfsburg Edition - LH8U - "Penny"
- 2.6i 5-Cylinder 10v (2004) |
Posted: Fri Apr 16, 2021 6:49 am Post subject: Re: 91 Power Steering Intermittent ???? |
Just picked up the new filter and will install it next week when it comes in.
Any recommendations on what to look to next if the problem persists post- filter swap? |
bobhill8 Samba Member
Posted: Fri Apr 16, 2021 7:04 am Post subject: Re: 91 Power Steering Intermittent ???? |
Hey FW, Just a tip to handle that reservoir carefully. I broke one of the nozzles off my original one, and the top is notoriously difficult to take off. It is threaded but hard to get a grip on. I emptied mine and then flipped it upside down and put the cap in a vice, then was able to apply better pressure with both hands to turn the bottom off. Make sure you turn the correct way with it upside down. BTDT. _________________ 1986 Westy
1971 Squareback |
Chewbacca88 Samba Member
Posted: Fri Apr 16, 2021 7:11 am Post subject: Re: 91 Power Steering Intermittent ???? |
Hey thanks for that. I just rebuilt my PS system from behind the gas tank including a new pump. I got new metal lines made as well as new hoses from the pump. Didn't think to replace the filter. Ordering one now. |
Posted: Sat May 08, 2021 5:13 am Post subject: Re: 91 Power Steering Intermittent ???? |
Update: After replacing the filter, we determined the intermittent steering was due to the steering coupler between the rack and column binding up and rusting. After freeing it up and lubing it, I look to have normal steering function again. |
