dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Mar 28, 2019 3:33 pm Post subject: Re: Can this spindle be saved? |
^^^ Thanks... Any input on the spindle, Dan?
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17119 Location: Retired South Florida
Posted: Thu Mar 28, 2019 3:53 pm Post subject: Re: Can this spindle be saved? |
I read the new race was falling in. Again you could dimple the disc surface and some bearing lock, but why screw around? The race must remain secure.
The inner race needs to sit square with no wobble on the spindle. It's unlikely that is the case and there was discussion a while ago that the inner race does turn some on the spindle.
Those bearings carry a lot of load and they keep the wheel on and the brakes working. If you don't care about your safety think about those around you. You already had a failure and survived. Second times a charm? _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Thu Mar 28, 2019 3:56 pm Post subject: Re: Can this spindle be saved? |
Yikes
Sodo thinks your spindle is hopeless.....
You’d have to take the van in for “re-alignment” to the new direction that your wheel is pointed.
Which could be ‘variable’. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu Mar 28, 2019 4:16 pm Post subject: Re: Can this spindle be saved? |
OK yeah...never suggested I want to compromise safety to save a few $$$, not my style, I'm not that guy.
I posted because I literally have no perspective on this issue and looking for advice which I accept readily.
Already started shopping for used spindles & have a few sets of brand name rotors saved in my eBay summary.
So much for my tax refund...
"The WonderVan"
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Thu Mar 28, 2019 4:18 pm Post subject: Re: Can this spindle be saved? |
That spindle now scares the crap out of me. I have had a stub axle break and it was not good. The hub also should not allow the outer race to fall in like that. If it was mine I’d junk it all and replace. If I was in the middle of the outback I’d try to make it work until I reached civilization. YMMV.
The MB axle nuts are awesome and will never contribute to that sort of bearing failure unless they are over tightened just like the stock peaned nut could. _________________ Dave O
The Western Syncro build
Posted: Thu Mar 28, 2019 5:26 pm Post subject: Re: Can this spindle be saved? |
Is there a torque spec for the cap bolt on the MB nuts? Haven't seen that anywhere yet...
"The WonderVan"
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Thu Mar 28, 2019 5:31 pm Post subject: Re: Can this spindle be saved? |
It isn't torqued up per se - just done up enough that the washer can only just be moved around with a screwdriver - i.e. not tight but virtually no free play.
Then the bolt is done up on the MB nut - or the OEM nut is peened. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Thu Mar 28, 2019 5:41 pm Post subject: Re: Can this spindle be saved? |
^^^ Yeah...I'm asking about torque spec for the "lock" bolt that pinches the MB nut in place once on the spindle...???
- D _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Thu Mar 28, 2019 6:33 pm Post subject: Re: Can this spindle be saved? |
dhaavers wrote: |
- Dave |
mmmyeah... looks pretty FUBAR. there's way more going on than a SpeediSleeve would correct. look for a different stub. i've got one here on a donor but i need the chassis to roll around the yard so something would have to go back on. i bet you can find one already taken off and not covered in 3' of snow yet.
-dan _________________ -dan
www.thefixitworkshop.com |
Posted: Thu Mar 28, 2019 7:47 pm Post subject: Re: Can this spindle be saved? |
OK, here we go...I'm done with the old spindle, & WTB ad now active:
https://www.thesamba.com/vw/classifieds/detail.php?id=2266959
Please tell your friends and neighbors!
"The WonderVan"
?Waldo? Samba Member
Posted: Thu Mar 28, 2019 9:13 pm Post subject: Re: Can this spindle be saved? |
I thought some of the '85's also came with the later spindles. |
jlrftype7 Samba Member
Posted: Fri Mar 29, 2019 5:51 am Post subject: Re: Can this spindle be saved? |
Although getting new or good used is the way to go, here's a different take if the above was not available and you had more money to burn... Metalize the worn parts. I worked briefly for a firm in the later '80s that did this for worn metal parts that needed new metal to be sprayed onto the worn section, then machined back to the original spec.
Very cool process, just not cheap......
Plus, the people doing this can add alloys to the sprayed product to change the wear factor of the part if needed,like adding Case hardening in a sense or more corrosion resistance.
So, if this was a spindle from 'unavailable' brand of vehicle, it's a way to go to saving something like your spindle and hub. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Fri Mar 29, 2019 6:29 am Post subject: Re: Can this spindle be saved? |
Good to see that VW Classic Parts is making new spindles. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Fri Mar 29, 2019 7:39 am Post subject: Re: Can this spindle be saved? |
T3 Pilot wrote: |
Good to see that VW Classic Parts is making new spindles. |
Link, plz? Google-fu not strong today...
"The WonderVan"
jberger Samba Member
Posted: Fri Mar 29, 2019 8:14 am Post subject: Re: Can this spindle be saved? |
dhaavers wrote: |
- D |
As a general rule, all 8mm fasteners should be in the 16-20lbft range (except CV's). I just make them tight enough (pinch bolts on spindles that is)
J
Posted: Fri Mar 29, 2019 8:16 am Post subject: Re: Can this spindle be saved? |
That general rule is good, except remember that 8mm CV bolts which get 2X the torque. |
Posted: Fri Mar 29, 2019 9:15 am Post subject: Re: Can this spindle be saved? |
Nice...even with the exchange, that's only $380 brand new! Shipping is another matter, however...
(Compared to a Chicago parts house I just talked to, wanted $495 for used...)
Thanks for the link!
"The WonderVan"
Posted: Fri Mar 29, 2019 9:46 am Post subject: Re: Can this spindle be saved? |
dhaavers wrote: |
- Dave |
That's insanity.. I have a line on a used spindle for you. $60, just have to ship it from SF.
J |
