QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Wed Mar 27, 2019 2:50 pm Post subject: Riviera experiment? |
I didn't think it was physically possible but I actually managed to make Riviera's even uglier. UGH 😖💩👎
well this color didn't work as planned, next time I'll try the copper. |
QRP Samba Member
Posted: Wed Mar 27, 2019 5:13 pm Post subject: Re: Riviera experiment? |
The copper doesn't really look good either, 🤮
It looks like I will have to just go with boring old black. |
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Wed Mar 27, 2019 7:45 pm Post subject: Re: Riviera experiment? |
I've seen these done in a classic "Gold" Tone with Black accent in lug bolt holes and they look pretty good with a set of these "PI" center caps.
QRP Samba Member
Posted: Wed Mar 27, 2019 10:00 pm Post subject: Re: Riviera experiment? |
Typ3nut wrote: |
Those caps are pretty slick. Unfortunately for me they are for the O.G. Riv's with the larger center hole.
Mine have 2-1/2 center.
When I finally do figure out the right color I would like to find some shorter brushed aluminum caps. |
QRP Samba Member
Posted: Sun Mar 31, 2019 4:36 pm Post subject: Re: Riviera experiment? |
well here is round 3 of the Riviera wheel test.
this time I went with a matte black hammer finish, not as black as I was expecting but 10 times better than the other two. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
QRP Samba Member
Posted: Sun Mar 31, 2019 5:37 pm Post subject: Re: Riviera experiment? |
EverettB wrote: |
Definitely nicer, at least 10x
It looks sort of a really dark grey-silver to me in the pic, not sure if it's more black in person |
you're right it did come out more grey than black. but the can said matte black. 🤔
I'll stare at it for the next few days and see how I feel about it then.
The wheels aren't going on the Ghia anytime soon. |
QRP Samba Member
Posted: Mon Apr 22, 2019 12:15 pm Post subject: Re: Riviera experiment? |
finally decided on a color for these things. was gonna keep the matte black that I sprayed on the last one but I wasn't feeling it.
so I'm going with std. black hammer finish.
I'll let the back side dry for a few days then finish up the front.
also found some center caps in an unexpected place, will paint those to match the wheels. |
QRP Samba Member
Posted: Wed Apr 24, 2019 10:42 am Post subject: Re: Riviera experiment? |
got the final coat on this morning, should look better with some lug nuts. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Apr 24, 2019 3:34 pm Post subject: Re: Riviera experiment? |
My apologies if I missed it- what color is the car? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
QRP Samba Member
Posted: Wed Apr 24, 2019 5:31 pm Post subject: Re: Riviera experiment? |
ALB wrote: |
My apologies if I missed it- what color is the car? |
mostly orange
QRP Samba Member
Posted: Fri Apr 26, 2019 12:09 pm Post subject: Re: Riviera experiment? |
test fitting some 205/65r15 that I swiped off my bug ( going back to a 205/70r15 on the bug anyway) so far the fit looks good, a little close to the spring plate adjuster so I'll keep an eye on that during the test drive.
new lug nuts & studs are ordered and on the way. I'll be painting the center caps to match later on today . |
QRP Samba Member
Posted: Tue Apr 30, 2019 8:58 pm Post subject: Re: Riviera experiment? |
Well I got em all mounted up, I do like the way they came out "BUT" I do have some rubbing issues up front.
was hoping that the lower profile 145/65r15 up front would compensate for the wider 5.5 up front but it didn't work out as planned.
( was previously running a 4.5 wide with std 145s that worked OK )
I wanna keep the Rivs on so I might have to go back to the stock spindles and just use the adjusters to get ride height right, I'm already as high as the beam adjusters will go while running the dropped spindles.
I know I know . . the back could definitely go a little lower with a simple adjustment but thats not gonna solve my front rub problem. |
QRP Samba Member
Posted: Wed May 01, 2019 11:20 am Post subject: Re: Riviera experiment? |
was able to find a little more adjustment in front this morning, got it up another inch.
dropped the rear a little bit more to even it out a bit.
no rubbing during this mornings test drive . . getting close and lookin better.
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Wed May 01, 2019 12:30 pm Post subject: Re: Riviera experiment? |
QRP wrote: |
Funny...I was just going to post how wickedly right that rake looks. |
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
QRP Samba Member
Posted: Thu May 02, 2019 8:37 am Post subject: Re: Riviera experiment? |
Stock Steve wrote: |
Looking good!!! |
thanks Stock Steve |
QRP Samba Member
Posted: Tue May 07, 2019 12:37 pm Post subject: Re: Riviera experiment? |
put some miles on the Ghia this last weekend, suspension starting to settle in. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Wed May 08, 2019 4:40 am Post subject: Re: Riviera experiment? |
Nice ride height. And the rims look like cookie cutters at first. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
QRP Samba Member
Posted: Wed May 08, 2019 3:03 pm Post subject: Re: Riviera experiment? |
NJ John wrote: |
Nice ride height. And the rims look like cookie cutters at first. |
that's funny about the cookie cutters, its kinda what gave me the idea in the first place. LOL |
