a2wolfsburggli Samba Member
Posted: Wed Mar 27, 2019 4:31 pm Post subject: Fuel overflow tank hose barb fix |
Somewhere along the way one of the barbs on the passenger side overflow tank got busted off and someone capped the rear vent tube on my fuel tank. I think this was contributing to my tank leaking.
Since I have the tank out and have access to everything I did a quick fix on the overflow with a nylon 1/4" fitting I found at the local hardware store.
Simply drilled an 11/32 hole and then pressed and turned the new fitting in. It went in hard and very tight till the threads got a good bite.
Simple, quick, easy. Figured I'd share my solution.
_________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
