Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Mar 30, 2019 12:54 pm Post subject: Crane for body lift off chassis? |
Has anyone on the forum modified one of these portable cranes in order to lift the body off a Beetle (or other small car)? I don't have five strong guys in my area who can do the heavy lifting for me. I do have an engine lift crane, and it would likely do the job, but the way they have those long legs that roll under the chassis prevent the chassis from being rolled away once the body is lifted clear. If one of these truck-mount cranes could be bolted to a concrete floor, and extended to the proper height, it looks like it might do the job. Comments, suggestions? (I also don't have a half-ton truck to mount one in ..)
_________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sat Mar 30, 2019 2:50 pm Post subject: Re: Crane for body lift off chassis? |
What is the ceiling like in your shop? _________________ "Albatross"! |
Posted: Sat Mar 30, 2019 3:51 pm Post subject: Re: Crane for body lift off chassis? |
My shop has a 10 foot ceiling, but the ceiling is not strong enough to support a block and tackle, or electric winch. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Mar 30, 2019 4:47 pm Post subject: Re: Crane for body lift off chassis? |
I personally haven't modified one, but I would think it all comes down to the breaking capacity of the wire and winch. It should be printed on the winch. Note it also doesn't lift directly up but at an angle, so there is some friction on the wire developed.
The beetle body is not very heavy and in the factory they used to suspend the whole body albeit without windows I think, by the outer edges of the four mudguards.
You should be able to just get a small lifting winch or block and tackle and just reinforce the ceiling joist on either side of the car with an a-frame of 4x2's or whatever you have lying around, reinforce the ceiling joist horizontally (if needed) and lift the body straight up. Of course you would not want the body to wildly swing when lifting to ensure the weight is bearing directly down so as to not dislodge the a-frame. Once finished you can just pull it down and use the timber for something else or wait until the body needs to be reinstalled and rebuild it.
If you modify the lifter you are contemplating, you would want to be sure that the attachment to the floor is very well planned. I assume you have concrete, so you would need to make sure the concrete bolts are very sturdy as the weight of the car will not be acting directly down on the steel support upright, but will tend to lean over and exert pressure on the outside concrete bolts. They get away with it on the back of the truck because they can have reinforcement plates above and below the truck bed with through bolts joining the two.
I would think that your engine type stand would work if it is tall enough. Just slide the body away from the chassis or vice versa carefully. Wouldn't it? |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 334 Location: Right Coast, Florida
Posted: Sat Mar 30, 2019 6:17 pm Post subject: Re: Crane for body lift off chassis? |
I think most people who don't have a hydraulic car lift use the floor jack and saw horse method. Which is what I did. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
Posted: Sat Mar 30, 2019 8:36 pm Post subject: Re: Crane for body lift off chassis? |
The hoist in the photo is sold by Harbor Freight for $149 USD. Checking into it a little further, it has 1000 lbs lifting capacity with the arm not extended, and 500 lbs with it fully extended, so lifting a stripped VW body should be no problem at all. However, not sure if the main post is extendable ...
The ceiling in my shop is finished, so I can't simple hook onto one of the rafters or joists. I've toyed with the idea of building a wooden gantry crane setup ...but that is expensive too.
Just doing some 'blue-skying' on this matter .....and may just end up the tried and true 'hydraulic jack and sawhorse' method. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Mar 30, 2019 9:50 pm Post subject: Re: Crane for body lift off chassis? |
I have a finished garage. There is a 2'X2' opening for storage above. There's allot of VW parts up there.
I hang a chain fall for lifting engines from my engine stand to dollies and visa versa.
If your garage has a access panel to the storage above. You can use a 4"X4"X8' to span a couple of joists for the chain fall to be suspended from to lift the 300lb stripped body of your VW.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Mar 31, 2019 9:34 am Post subject: Re: Crane for body lift off chassis? |
before I had the lift, I did it in my storage garage (pole building) What to do is lay a couple 4x4s across several rafters so it distributes the load. I then just use 3 or 4 come-alongs to raise the body. The body is not that heavy and as long as you got all the bolts loose (use jacks to make sure the body is completely free of the pan) you wont have that much stress on your rafters. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Mar 31, 2019 10:14 am Post subject: Re: Crane for body lift off chassis? |
Unfortunately, the access panel in the ceiling of my shop is not in the centre of the room ....its way over to one side, about a foot away from a wall. Cutting in a new access panel above the car is really not an option I want to pursue. A gantry crane (like the one Hannah built: www.youtube.com/watch?v=WXdqjG39JTM ) would certainly do the job, although I think her's is way over-built for a 300 lb lift. I also have a 65 Bug waiting in the wings, so I could justify the cost (ever priced out lumber lately? Wow!) ...and it could be taken apart and stored between projects. (BTW ...whatever happened to Hannah??) _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 31, 2019 8:12 pm Post subject: Re: Crane for body lift off chassis? |
If lumber is that expensive, search CL to see if someone is selling good used stuff for a lot less or even free. Also keep an eye out for any old heavy duty swing sets being dumped, and if you have any scrap yard out your way you might buy steel for just a bit more than scrap price they sell to their buyers. _________________ In Stereo, Where Available! |
parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Sun Mar 31, 2019 8:36 pm Post subject: Re: Crane for body lift off chassis? |
what i did in my garage is put 4x4 across several rafters and cut 2" hole in sheetrock and ran strap through hole. after that you just hook your lifting device from below. I was surprised how much i use my hanging strap. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Apr 01, 2019 12:20 pm Post subject: Re: Crane for body lift off chassis? |
That Harbor freight boom will not work for lifting your bug body. It is not tall enough unless it's mounted to a truck, If it is mounted to a truck, now you have to worry about the body of the truck & the bug intermingling, it is not long enough to reach over the side of the bed AND reach the center of the roof of the body shell which is necessary for balancing it.
Also, if it's mounted to the truck, you will be cantilevering all of the weight of the shell off the side of the truck, which is designed to bear the load in the center of the bed, over both wheels. While the boom has a steel plate to mount in the bed, you are bolting it to corrugated sheet metal & there is no brace to attach to the bed rail. The bed floor WILL bend & tear. I had one & immediately saw the necessity for a 2' triangulated brace to the bed rail
You would do better to buy a self supporting engine hoist/"Cherry picker" & modify it to work. The vertical upright needs to be extended 1'-2' for the boom to clear the drip rail as the body is raised. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Redlines Samba Member
Joined: June 07, 2009 Posts: 168 Location: Fredonia, NY
Posted: Mon Apr 01, 2019 12:56 pm Post subject: Re: Crane for body lift off chassis? |
Digger89L wrote: |
My shop has a 10 foot ceiling, but the ceiling is not strong enough to support a block and tackle, or electric winch. |
just playing devil's advocate, but if your ceiling wouldn't support a lightweight VW body, I might think twice about working under it! |
TryToBeOriginal Samba Member
Joined: July 23, 2012 Posts: 266 Location: Georgetown, Texas
Posted: Mon Apr 01, 2019 1:23 pm Post subject: Re: Crane for body lift off chassis? |
I use the engine hoist, lift it up pretty high and slide some saw horses under the bumper brackets then I remove the engine hoist and roll the chassis out I can do it by myself in about 15 or 20 minutes and with help in about 10. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Mon Apr 01, 2019 4:42 pm Post subject: Re: Crane for body lift off chassis? |
To Joey1320: I just love it when people pay attention, and read the previous posts before they chime in. Nice work. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Mon Apr 01, 2019 4:49 pm Post subject: Re: Crane for body lift off chassis? |
Digger89L wrote: |
To Joey1320: I just love it when people pay attention, and read the previous posts before they chime in. Nice work. |
Haha!
Didn't even see your last post.
Good luck with your project. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Mon Apr 01, 2019 6:17 pm Post subject: Re: Crane for body lift off chassis? |
I bought a Harbor Freight hydraulic engine lift . You know the king that rolls across the floor with the extended arm like the picture in the pickup.. Not the thing to use. If i do it again i would get the ceiling mounted chain hoist. i have done it all by hand too. Lifting one end of body onto sawhorse then the other end and roll the chassis out underneath. It only cost a week of pain and a cortisone shot in the elbow. _________________ its all up to you and me to make it better... |
Posted: Tue Apr 02, 2019 3:34 am Post subject: Re: Crane for body lift off chassis? |
Check out Unistrut, they make several different kinds of overhead trolley systems. Lagbolted to several ceiling joists may be just what you need. _________________ "Albatross"! |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Thu Apr 04, 2019 1:58 pm Post subject: Re: Crane for body lift off chassis? |
I used four come-alongs attached to the ceiling joist. Seemed like a better idea spreading the weight out over a larger area with four pickup points.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
