The 1500 Club
Page: Previous  1, 2, 3 ... 185, 186, 187 ... 190, 191, 192  Next
Joerg Fischer
Joerg Fischer is offline
PostPosted: Sun Jul 22, 2018 2:53 pm    Post subject: Re: The 1500 Club Reply with quote
bob-on wrote:
Hi folks,
Can anyone please tell me the difference between these rear wheel cylinders.....
311-611-067B - 22.2 chassis 76 300 to 221 974
361-611-069B - 25.4 chassis numbers as above
361-611-067 - 23.8 chassis 221 975 to 483 592
Apart from the obvious bore differences is there anything else? Could any of these be used on any of the early chassis?
My car is listed as needing 361-611-067 but I'm having trouble finding a NOS pair Ate. Thanks for your input
Hello from Germany,
Yes, there is an interesting difference, and therefore VIN 221974/975 is important:
You always have to combine the rear wheel cylinders with the correct anchor plates. Up to #221974 the mounting of the wheel cylinder is "down" at the anchor plate. From #221975 it is "up".
If you combine brake cylinders and anchor plates correct, the "bleeding nipple" (I am missing the correct expression in English language) is above the brake lining.
If you combine wrong, the "bleeding nipple" is below (!) the brake lining, where it does/might happen you do not get all the air out of the system. Not funny with a single brake circuit system.
In +30 years working on type 3 I have seen the wrong combination several times.
If it is not clear what I mean, I can scan the page of the spare parts catalogue with my marks on this issue, where one can see the difference!
Best Regards, Jörg.
pedro sainz
pedro sainz is offline
PostPosted: Sun Jul 22, 2018 9:19 pm    Post subject: Re: The 1500 Club Reply with quote
Joerg Fischer wrote:
bob-on wrote:
Hi folks,
Hello from Germany,
Best Regards, Jörg.
Very Happy
68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There
Joerg Fischer
PostPosted: Mon Jul 23, 2018 1:07 pm    Post subject: Re: The 1500 Club Reply with quote
Thx Pedro, a picture is sometimes better than a hundred words... Cool
Jason37
Jason37 is offline
PostPosted: Thu Dec 27, 2018 5:28 pm    Post subject: Re: The 1500 Club Reply with quote
I know it won’t be correct, but my aluminum fan shroud is heavily pitted. The standard was to run them bare, but in this case it will look terrible. I am going to have it powder coated, and was thinking of utilizing the same grey as the intake, heater elbows and muffler. To me the colour looks very close to ASA61 grey, which is a standard on most electrical equipment. Anyone have any other suggestions? Also, does anyone repop the label on the air cleaner?
ibjack
ibjack is offline
PostPosted: Thu Dec 27, 2018 8:23 pm    Post subject: Re: The 1500 Club Reply with quote
I get my shrouds powder coated in a silver tone or have the blasted and then clear coat or run bare. I think Scott Taylor (t3kg) has the decals for the air cleaner.
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
Jason37
Jason37 is offline
PostPosted: Fri Dec 28, 2018 9:12 am    Post subject: Re: The 1500 Club Reply with quote
Thank you for the info. Do not want to blast my air cleaner until I have the label.
As for the shroud, it is blasted and will need to be coated.
ibjack
ibjack is offline
PostPosted: Sun Apr 07, 2019 5:52 pm    Post subject: Re: The 1500 Club Reply with quote
On a recent trip of 1000+ miles to pick up an NOS rear apron and hang out at the Bob Baker show in San Diego, 1500 club member Eric Hand offered to bring me a tool box he just picked up. While delivering it, 40 miles south of where he was staying, I asked if I could see the apron to see how far off the apron of the early notch I'm working on is. While comparing and taking pictures he offers to leave it with me. So grateful for the friends I have because of the car I drive. Thank Eric👍🏻
the1500club.com
bad1916
bad1916 is offline
PostPosted: Sun Apr 07, 2019 7:29 pm    Post subject: Re: The 1500 Club Reply with quote
Nice to hear about stand up guys in the hobby. 👏🏻
SEMPER PARATUS!
1963 SQUAREBACK
Peters Van
Peters Van is offline
PostPosted: Mon May 20, 2019 4:03 am    Post subject: Re: The 1500 Club Reply with quote
thought this would be the best place to ask for some single carb motor pics.
trying to get the panelvan motor looking as close as i can get to stock.
i have just had the fuel pump rebuilt so i can cross that off the list.....
any help would be welcomed...... cheers
1965 Type 3 Panel Van
1963 EH Holden Station Wagon
Erik G
Erik G is offline
PostPosted: Mon May 20, 2019 9:38 am    Post subject: Re: The 1500 Club Reply with quote
plug wires are too modern and shouldnt be 90 angle
black short coil, Bakelite matching the distributor cap patina would be preferred
not sure about the oil pressure switch, look modern as you have it.
I generally don't use hose clamps on the fuel lines but I don't think anyone will fault you for it
notchboy
notchboy is offline
PostPosted: Mon May 20, 2019 10:33 am    Post subject: Re: The 1500 Club Reply with quote
What is the date stamp on your air cleaner? Ive never seen an early type with the four linear depressions on the top like that? Im betting its from a later standard type of T3 like 68-73 ish.
Looks similar to a FI cleaner.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Erik G
Erik G is offline
PostPosted: Mon May 20, 2019 1:57 pm    Post subject: Re: The 1500 Club Reply with quote
my old '63 for comparison.
notchboy
notchboy is offline
PostPosted: Mon May 20, 2019 4:12 pm    Post subject: Re: The 1500 Club Reply with quote
A 66 Standard.
Needles to say, Kneicht and Mann were the two primary manufactures of the filters. Australia may have a third? Or a licensed variation there of??
1964 1500 S
Peters Van
PostPosted: Tue May 21, 2019 2:41 am    Post subject: Re: The 1500 Club Reply with quote
thanks for the replies and the pics.....
where is the date stamp on the oil bath ????
as far as im aware this is the original oil bath.
i also have some spares i will look at over the weekend for comparison.
i wasnt a fan of the blue coil so looks like some painting to be done there.
it doesnt have to be factory stock, just trying to get it not to look out of place.
i will post up some pics of the oil bathes
notchboy
notchboy is offline
PostPosted: Tue May 21, 2019 6:43 am    Post subject: Re: The 1500 Club Reply with quote
It looks great now brother. These pointed out details only .3% of the people at shows will notice. So no one Wink Laughing
Date stamp is on the outer rim.
1964 1500 S
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Tue May 21, 2019 10:16 am    Post subject: Re: The 1500 Club Reply with quote
One of the little tiny details lost to history is that originally early 1500 side draft engines got blue plug wires and S engines got red from the factory. Knowing the Germans, there were likely more internal differences than just the color but what those differences were is lost.
Blue and red wires went away around the time of the end of red needle gauges and push button dashes and all became black.
L-shaped connectors at the distributor cap became necessary in 1968 for fuel injected models only due to added distributor body height because of the D-Jet trigger points now affixed under the breaker plate. The L shaped connectors are ONLY correct for 1968-73 with fuel injection, even though everyone and their grandmother (including Bosch!) sells them as "Type 3 wires".
Also- original wire and plug brand was Beru if memory serves in the early days. Not sure when they became Bosch but I am thinking when they went to all black wires.
Now, if you'll kindly excuse me, I need to go geek out over my collection of pocket protectors. Twisted Evil
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
Peters Van
PostPosted: Wed May 22, 2019 12:59 am    Post subject: Re: The 1500 Club Reply with quote
being an australian assembled CKD we ended up with all sorts of different stuff.
i dont ever recall seeing this with any other than black plug wires and no 90 bends....but in saying that the bends stop the plug wires rubbing through the foil on the underside of the engine lid and i can live with grey for the time being.
i would assume also that we got bosch plugs and wires as part of the local content rule at the time... thanks for all the info
Peters Van
PostPosted: Fri May 24, 2019 9:30 pm    Post subject: Re: The 1500 Club Reply with quote
so found a couple of my spare single carb oil baths (or is that bathes) anyway
1 of them is the same with the 4 depresions and the other 1 is flat on top.
they are both knecht brand and have lb641 and part no 311 129 611 d stamped on top. can someone show me a pic of the date stamp because i cant see any on either of these...
notchboy
notchboy is offline
PostPosted: Fri May 24, 2019 9:41 pm    Post subject: Re: The 1500 Club Reply with quote
1964 1500 S
Peters Van
PostPosted: Sat May 25, 2019 2:38 am    Post subject: Re: The 1500 Club Reply with quote
thanks for the pics......now i can have a better look.....
Page 186 of 192
